My six cylinder solution to my 4cyls towing anemia - JeepForum.com
 14Likes
post #1 of 171 Old 08-12-2015, 07:43 AM Thread Starter
fishadventure
EDIT: October 28, 2016 the following is a midstream discourse of my project. It's matured as my YJ knowledge has matured, and it's morphed as available finances and available parts have come up or gone by the wayside for reasons practical and financial. This has been a project over four years in the making and it's been full of stops, starts, and interruptions, 4.7 stroker thoughts and parts, and even vacillating between two jeeps. At this point the two will become one, eventually.
I want to record this to maybe shorten up the research others will need to make the same kind of capable build. I'm not wanting over-over-the-top but just something solid and dependable without breaking the bank. So the first post below starts a while back and jumps and jerks but stabilizes to a good direction before page two. I hope my heep's journey is useful to you- some really knowledgable and most helpful forum members have posted in here. /EDIT
BEGIN: I have two YJs: my 89 DD and the 91 project. In the course of things I have two 4.0 donors, a couple of 258 cranks, and a 70s 258 block. The 91 will eventually contain a stroker with the "heavy" 12 weight crank, but that's a long term project than I'd hoped.
The DD on the other hand has a perfectly good running TBI 2.5 without enough horsepower for how I am always towing stuff. So the 258 with a standard crankshaft and a 4.0 head is looking pretty attractive. And inexpensive on the relative scale.
I need a cam... The wear pattern doesn't look great on the one that was in the block. So new lifters, too, and while I am at it, timing set makes sense. I notice there is an OMIX cam for like $130, but I am concerned with how it will wear. I see a Comp Cams kit for like $330 on Amazon which is still not insanely priced. And I have always had an affinity for anything Crower or Edelbrock. Edelbrock has a basic cam and lifters for like $180.
I am inclined to order the Comp Cams kit or the Edelbrock. So after reading a bunch of cam threads this AM I decided to look for input because the only reason the OMIX looks appealing is cuz a stock grind will probably suit my needs, but a little torque and HP peak 2500-3000-rpm would be nice. But I certainly don't want a high rpm power band. There isn't a lot of real spendy difference between the OMIX and the Edelbrock $50ish on Amazon.
Shackles and D-rings: different things!
Cranking IS turning over
fishadventure is offline
post #2 of 171 Old 08-12-2015, 08:07 AM
crackedcornish
I'd go Edelbrock over Omix for internal engine parts any day
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #3 of 171 Old 08-12-2015, 10:40 AM
jsawduste
2006 YJ Wrangler
If the 4.2 you have now is a 81-90 your running
190 @ .050/.403
The 91-95 4.0
197/424
Comp 68-115-4
192/416 Intake
200/416 Exhaust
Melling MC809
197/424 (same as 91-95 4.0)
If it was me I`d look at the Comp or the 4.0 grinds
Get good lifters.....Not parts store imports....and break the cam in properly.
Edlebrock leaves much to be desired in there cylinder heads. I`d wouldn`t get overly excited about a camshaft.
calpbs likes this.
jsawduste is offline
post #4 of 171 Old 08-12-2015, 02:36 PM Thread Starter
fishadventure
Originally Posted by jsawduste
If the 4.2 you have now is a 81-90 your running 190 @ .050/.403 The 91-95 4.0 197/424 Comp 68-115-4 192/416 Intake 200/416 Exhaust Melling MC809 197/424 (same as 91-95 4.0) If it was me I`d look at the Comp or the 4.0 grinds Get good lifters.....Not parts store imports....and break the cam in properly. Edlebrock leaves much to be desired in there cylinder heads. I`d wouldn`t get overly excited about a camshaft.
I momentarily forgot there was someone here who committed all the specs to memory
My 258 block is 1978.
What got my attention on the Comp kit is that it had lifters and bearings. I am a little partial to the idea of the cam manu providing the bearings and lifters.
I also have a running 4.0 from a 98 XJ I forgot about. A real short cut would be to pop that in if I found a TBI intake and comp. But it wouldn't be new.
Re: Edelbrock- but I trust their metal. Not going to wear out too fast. At least that used to be the case...
post #5 of 171 Old 08-12-2015, 07:47 PM
jsawduste
2006 YJ Wrangler
Assuming your 258 is unmolested it should have the 12 cwt casting #3214723 with a 64mm nose. I save those 12 cwt cranks for "special" builds. Most often use the 4 cwt crank from an 81 + or a Scat.
The 98 XJ would bolt in. If your simply running a carb then an adapter plate could be made for the (4.0) intake and the carb switched over. Just an idea........Or you could use your old intake on the 98 with a little grinding at the dowels.
Keep in mind your 98 will have a 54 mm nose on the crank. You will need a spacer for the HB. If you go that route then let me know. I can hook you up with a spacer through Russ Pottenger.
Intakes can be had for cheap. In fact from RockAuto you can buy a brand new 99+ intake for around 130 bones. The engine itself will need to have the sensors switched to OBD1 parts as the terminals and connectors are different. Don`t forget the flexplate/flywheel with the notched for the crank sensor signal.
post #6 of 171 Old 10-24-2015, 08:15 AM Thread Starter
fishadventure
Well. This might seem haphazard and I appreciate the help and info so far. It will be useful on future stuff, but right now I am changing directions slightly. I have a plan in motion to save time since summer is past and its 26 degrees F this morning. Winter is here.
PLAN: I am saving out the 4.2 for a future use and just using a '98 XJ 4.0 straight up since it runs good and doesn't need rebuilding. I have a pre-95 OBD1 4.0 intake and a selection of AX15s on hand. Also have a '94? 4.0 MPFI computer. I am swapping out my rusted 2.5 frame with a 4.0 frame so motor mounts are covered as well. And I've got a bunch of driveshafts. So mechanicals are covered.
Where I am going to need help is that I am essentially swapping in a '95-or-earlier OBD1 MPFI 4.0 into a '89 2.5 TBI setup. So computer harness and engine harness aren't so simple. Got some great info http://www.jeepforum.com/forum/f12/l...e-pics-668796/ from leans thread, but my bookmarked 4.0 swap thread has become obsolete with many dead links: http://www.jeepforum.com/forum/f12/4...63/index2.html
So I had a thread saved with stuff from Queue I can't seem to come up with detailing some stuff for the '89 2.5 TBI to 4.0 MPFI swap. Weird cuz I thought it was my thread??? Whatever. If anyone has that please post up the link for starters.
FIRST QUESTION: should I piece back together the 1993-ish 2.5 MPFI harness and swap it into my '89 or deal with what remains of the '94 4.0 harness and swap that in?
This is my DD so I plan to have everything lined up before I go for it. Fairly likely I'll even install a pair of 3.73 D30/D35 axles I have along with the motor, driveline, brake lines, fuel tank, and steering and simply deposit the tub on a roller. That way I'll only have bolt-ups and the wiring debacle in question to deal with. I want to have the harness mods done and prepped of course. Then I'll have a running '89 2.5 in a frame with driveline for sale...
post #7 of 171 Old 10-26-2015, 07:30 PM Thread Starter
fishadventure
bump
post #8 of 171 Old 10-27-2015, 07:34 AM
Que89YJ
Fish I am confused on what on have and what you want to do.
Que89YJ is offline
post #9 of 171 Old 10-28-2015, 07:45 AM Thread Starter
fishadventure
I am going to put 94 4.0 YJ computer and put it in my '89 2.5 to run a 98XJ 4.0 motor with YJ 4.0 sensors.
I have a previous owner cut up '93? 4.0 YJ harness and a '92 2.5 MPFI YJ harness to choose from.
I am assuming the '92 2.5 MPFI harness is a better place to start. Wanting advice and/opinions on which and maybe some double spots might be averted. If the '89 were MPFI it would be a no brainer...
post #10 of 171 Old 10-28-2015, 07:50 AM Thread Starter
fishadventure
Ya sorry for the confusion. I *wanted* to do other things but time, money, and logistics with the season and garage space have convinced me to just be very very very simple since this my DD. I just need a few more cubic inches for towing. Plain 4.0 will do it. And I probably won't have to buy anything.
I've just started and stopped too many times and have to work and have life and sleep now and again.
post #11 of 171 Old 10-28-2015, 08:03 AM
Que89YJ
If you have an unmolested 92 harness that is the way to go. Set up the harness before you start so it just drops in.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #12 of 171 Old 10-28-2015, 08:06 AM
Que89YJ
The 92 will be closer to your harness and you can pull and add to the harness to make it work. Add 2 injectors and lengthen the wires where needed.
Fault codes:
No Start:
Que89YJ is offline
post #13 of 171 Old 10-29-2015, 07:38 AM Thread Starter
fishadventure
Thank you thank you thank you. That's what I was thinking but no experience to base it on... The 92 harness was cut off clean under the dash so the fix is diagram free.
Q: I haven't looked yet but will I even need to change the bulkhead connector and stuff under the dash? (I thought you answered this for me a year or so back but I can't find the thread???)
post #14 of 171 Old 10-29-2015, 08:42 AM
jsawduste
2006 YJ Wrangler
No, the underdash is the same for both 4 and 6.
post #15 of 171 Old 10-29-2015, 09:10 AM
Que89YJ
You have to move pins on the bulkhead but the harness can be left in tact. I just took a quick look and there are at least a dozen circuits you will need to deal with between the 2. Gauges, blower, feeds, etc. changed between the years.
Que89YJ is offline
