Is my manifold gasket on right? - JeepForum.com
post #1 of 5 Old 04-12-2010, 06:57 PM Thread Starter
stickfight
I've had this Jeep since mid summer and knew it needed some work when I bought it. I put a new carb on a little while ago and somehow did not notice this. Put a new fuel pump on and noticed this:
A couple of the bolts could be turned with fingers. Think I might have a leak?
stickfight is offline
post #2 of 5 Old 04-12-2010, 08:23 PM
timatoe
timatoe's Avatar
Yep, it's two gaskets attached together. They're notorious for getting loose that's normal tighten them to spec and wheel it.
timatoe is online now
post #3 of 5 Old 04-12-2010, 08:27 PM
Rhino70
In my opinion....Pull the bolts out and replce them with 3/8 by 1 1/4?? grade 8 bolts. Be sure to put anti-seeze on them. Doing this will help prevent bolts breaking. Been there and done that!
Rhino70 is offline
post #4 of 5 Old 04-12-2010, 09:29 PM
Burnerman
Burnerman's Avatar
What carb are you running? I ask because that lawnmower fuel filter you have there. You don't have any return line anymore?
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #5 of 5 Old 04-12-2010, 09:49 PM Thread Starter
stickfight
Motorcraft 2100
That filter setup is temporary...just what I had on hand. Return line is capped at the moment. The pump is weak so I'm going to replace it all at once.
fix gasket or whole new manifold? ayeohellucks TJ Wrangler Technical Forum 8 08-12-2008 01:22 PM
OEM gasket or gasket that came with the header/manifold? glorytown TJ Wrangler Technical Forum 2 07-03-2008 06:37 PM
manifold gasket 88Wranglerdude YJ Wrangler Technical Forum 2 08-25-2007 08:15 PM
Need HELP!!! Manifold Gasket... topfuel83 TJ Wrangler Technical Forum 3 06-30-2005 08:50 AM
Manifold Gasket? rmagers TJ Wrangler Technical Forum 1 05-22-2005 06:48 PM
