#1 | |
My LS1 Project
I just obtained an LS1 and tranny from a 98 Z28 to install in my 88 YJ. I am new to this so have a lot to learn. This will be a daily driver, mostly road use, little offroading.
What else should I be look at or thinking about to start this? I don't want to hotrod it too much so am thinking of doing the following upgrades in the near future. • CAM - LS6 cam. • Intake - LS6 or aftermarket manifold with NOX fittings. • Headers - limited due to space and steering shaft. Would like long tube but not sure if this is possible. • Fuel pump - it is my understanding that I need a positive pressure fuel pump which can be installed in the cell. IS it possible to install one inline on the fuel line outside of the cell? • Engine mounts - looking at the Novak kit. I would be fine with something like the Advanced Adapter bolt on saddle mount as I don't weld but I don't see a model for the LS1.
#2 |
An LS1 is a 350, you have the aluminum new school 350. So, just get a motor mount kit you like thats fits a 350(or 5.7) and your good. There are tons of write ups, build threads for people that have done 350 swaps on this board. You can search me out and see the progress, and problems people had. Good luck.
Rock Krawler Suspensions |
#3 |
LS1 is a great engine ... even if its a Chevy ha ha.
On a serious note, are you going to do a full rebuild on this engine? Or are you just wanting to swap cams? I would find Chevy builders in your area or online and ask them about cam choices. Selecting the wrong cam can leave you with results that hurt you. I run a full cell in the back of my jeep behind the rear seat and use a pump inline. Works fine....but I'm also only running a chevy tbi ontop of my Mopar. So the fuel needs are less than what you'll need. I'm sure you'll be fine though. |
#4 |
The engine has 93,000 miles ont it. From the research I have done, it is not worth rebuilding until around 130,000 or more. At this point I would rather put the money into finishing the project and will rebuild later.
I have read a lot on CAM choices, how to chose, etc. I understand matching heads with a CAM, etc. but that is not what I want to do. I really only want to change the CAM and do some bolt on's. I have also read the the rockers and springs that come with the engine are fine with a CAM like the LS6, but I think if I buy that CAM kit from a Chevy dealer it come with everything. |
#5 |
no genius...but I think you need four wheel drive tranny
#6 | |
The LS6 cam/intake is a good setup. You will need different valve springs too. Even a stock LS1 is fine. There is a lot of power to be made on a stock motor with a free flowing intake/exhaust, and a good dyno tune.
I don't know what's commercially availible for LSX motor mounts because I make my own using plate and poly spring eye bushings. It's pretty easy. Longtube headers won't work because the front driveshaft will be in the way. You need shorty headers. Center outlet blockhuggers are the easiest to build an exhaust off of. I have Doug Thorley LS1 headers which are really nice but Speedway, Hooker and a few others also make good ones. You can use an inline pump. There are many that will work. I have a Walbro 255 lr/hr (Walbro 392) that can be had for around $100. Quote:
lightyears ahead |
#7 |
LS1
GM LS1 engine from the Chevrolet Camaro GM LS1 engine from the Chevrolet Corvette C5 The LS1 shares little other than similar displacement, external dimensions, and rod bearings, with its predecessor. It is an all-aluminum 5.7 L (5,665 cc/345.7 cu in) pushrod engine and was rated between 305 - 350 hp (227 to 261 kW) and 335-375 ft·lbf (454-508 N·m) of torque in North America, depending on the application. In Australia, continuous modifications were made to the LS1 engine throughout its lifetime, reaching 382 hp (285 kW) in the HSV's YII series and a Callaway modified version, named C4B, was fitted to HSV GTS models producing 402 hp (300 kW). Yeah, sorry, you have a 345.7
#8 |
I think he's just saying that there's more to it than just taking an old 350 and building the exact same thing out of aluminum.
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S 1987 YJ Laredo |
#9 |
The mounts on the LS1 are different than standard "small block Chevy" mounts. You might have to fab up your own mounts.
2004.5 Dodge 2500 Quad Cab 4x4 Cummins Diesel 1995 Jeep Wrangler YJ 1946 Willys CJ-2B Flat-fender 1971 Plymouth Duster |
#10 |
OG style 350 motor mounts can be adapted to a Gen III block easily. But it's not much more work to make your own from scratch.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
