My little build - Page 33 - JeepForum.com
post #481 of 501 Old 08-06-2012, 12:46 PM
Jeffro06
Jeffro06's Avatar
Looks good, I need me some 35's.
Jeffro06 is offline
post #482 of 501 Old 08-28-2012, 03:31 PM Thread Starter
93jeepREDSOX
Thanks jeffro
So this weekend I am going to have to do some repairs on the jeep, wheel bearing hub assembly is shot on my drivers front and the rear main is leaking pretty good. Also need front pads and gonna go ahead and change the fluid in the tranny to 10w-30. Hopefully I will get everything fixed on it.
Also was talking to my mechanic friend and he has recently gotten the tools to do gears. Im pretty excited about that cause he will help me free of charge pretty much.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #483 of 501 Old 09-04-2012, 07:46 PM Thread Starter
93jeepREDSOX
So this weekend thanks to a friend of mine, got the jeep fixed. Replaced the rear main and after doing one I must say they aren't that bad to do, plus it saves a lotnof money. Also got the axle hub/wheel bearing, it was do bad it actually slung out 2 of the bearings. Jeep runs great now.
The build thread
post #484 of 501 Old 04-21-2013, 09:34 AM Thread Starter
93jeepREDSOX
So its been a while since i have updated, going through a divorce so thats fun. Pretty broke right now but i did manage to find a 95 dana 30 with the matching 3.73 gears that i have in the 8.8, only 150. So i have cut off the springs and just gonna clean it up and throw it in. Finally have 4wd again.
The build thread
post #485 of 501 Old 04-21-2013, 09:37 AM
bbacus
Great Job.
Problem with jeeps is they keep getting better with age.....lol.
bbacus is offline
post #486 of 501 Old 04-21-2013, 09:51 AM Thread Starter
93jeepREDSOX
Here is the axle, not too bad. Plans are when I get the money is to get a high steer kit and replace the ball joints and axle shaft u-joints
And the pile of stuff I cut off
The build thread
post #487 of 501 Old 04-21-2013, 05:26 PM
Louie4
Nice start. I cleaned up my D30 a month ago while doing some maintenance on seals.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #488 of 501 Old 06-09-2013, 11:48 AM Thread Starter
93jeepREDSOX
So a little update, i have replaced the upper and lower ball joints and cleaned up the axle got a coat of paint on it. Still need to replace the axle u-joints and put those back in and replace the vacuum actuator. Then i can throw it in and have 4wd again. I also scored a set of full hard doors for $100 and full cj soft doors with the double window for $100. THe full doors need a little work and the soft doors just need the latches. Also bought a new header and need to put that in and replaced my cavi seats with some vinyl seats, nothing special just something to hold me over till i can get some new bestop seats. Well thats it for now, hopefully the next time i update i will have some pics and some offroad shots.
The build thread
post #489 of 501 Old 06-09-2013, 12:43 PM
flashy
Awsome build! Just out of curiousity, how are the 35's with 3.73 gears?
Time and budget build...lots of pics::::
94 YJ slightly modified
00 WJ stock
flashy is offline
post #490 of 501 Old 06-09-2013, 07:25 PM Thread Starter
93jeepREDSOX
surprisingly they are pretty good. The acceleration is decent in town and on the high way i can get up to about 80 but the hills are still pretty ruff. but for a daily driver it does pretty good, good enough for the time being, until i go soa with 37 s and ill probably go to 4.88
The build thread
post #491 of 501 Old 07-05-2013, 10:58 AM Thread Starter
93jeepREDSOX
So finally got around to putting in a new header this past weekend. I got it from rockauto.com and it was 175 shipped unpainted. So I used that rustoleum high temp paint. So the install took Mr and a friend about 6-8 hours can't remember exactly but it pretty much took all day Saturday. But went on with no problems. It sounds so much better and quieter, there is definitely a power gain and a slightly better fuel economy. All in all I am very satisfied with it.
Next I still and working on the Dana 30 hopefully get that installed next month and then a mml will be the next purchase. Then I can throw on the mml and body lift on at the dame time.
The build thread
post #492 of 501 Old 07-05-2013, 03:51 PM
DpDave
Wow... that's a long thread, timewise. Glad to see you are still flogging away on the old Heep. Keep it up, it's a damn fine looking example.
I'm getting started on my own build, and had planned to go in a few stages, but it seems to have gotten entirely out of hand.
Anyway, good luck with the thing, I'll be looking to see more from you...
If yer gonna fight, fight like the third monkey on the ramp to Noah's Ark.
My Build Thread:
DpDave is offline
post #493 of 501 Old 07-05-2013, 06:24 PM Thread Starter
93jeepREDSOX
Yea i have been building it for a while, but its also my dd so i have had to take it slow, and i was married and that pretty much halted the build, now that im single again the build is back on.
The build thread
post #494 of 501 Old 08-15-2013, 05:35 AM Thread Starter
93jeepREDSOX
So sadly as some of yall know, i got into a wreck with the jeep, front end damage, busted motor mount, bent leaf spring, and whole in the radiator. The fenders and grill are bent up but the hood is still fine and of course my bumper, bull bar, hella lights and maybe winch took most of the blow not sure if the winch still works. So insurance totaled it so with the money i will be getting Im gonna get an xj, and rebuild the yj. It may be slow because im thinking about going ahead and upgrading where i can, gonna replace the motor mounts with brown dog 1" mml, stock radiator has been fine so ill just get another, new leaf spring from RE, and im thinking of making the big purchase and getting some metalcloak overline fenders. Plus i still have the the other dana 30 to put in, so thats the build plan for the next few months. It will be a slow process but hopefully when done it will be better than before
The build thread
post #495 of 501 Old 08-23-2013, 07:52 PM Thread Starter
93jeepREDSOX
Alright, So i got a 96 cherokee, 4.0, 5sp, with 126k, for 2400. That will be the new dd after i fix the death wobble that it has. It has a 3" lift but needs some tires hopefully thats all thats all it need.
Back to the yj, i have a new radiator and brown dog 1" mml on the way. I have been searching craigslist for a new fender and grill. Will just have to deal with no bumper for a while till i can afford a new one.
The build thread
My YJ Build - Yet another build thread!! bluexj YJ Wrangler Technical Forum 28 07-11-2012 12:23 PM
My YJ Build provinT13 YJ Wrangler Technical Forum 1203 06-14-2011 09:29 PM
06flex's build (my build up) 06flex TJ Wrangler Technical Forum 131 07-03-2010 10:26 PM
Build advice for a high-line type build The Rat YJ Wrangler Technical Forum 1 02-11-2009 02:21 PM
how would you build it? dharmabum TJ Wrangler Technical Forum 4 07-27-2006 11:05 PM
