my lift - JeepForum.com
post #1 of 6 Old 09-09-2001, 05:46 PM Thread Starter
Bassili
my lift
Hey all,
I don't really know anything at all about hardcore jeeping but here's my problem:
I want to lift my 88 YJ (4.0 v6 i think) and I was planning on a 3 inch body lift with some 33 inch all terrain tires and new rims. I REALLY want to keep costs down which works out nicely because I'm not really going to be doing anything really crazy with my jeep that needs a suspension lift. Anyways, the question is, is this a good route to take for my situation and what problems should i be expecting from this route? Thanks a lot for your time.
88 YJ Laredo 3 inches suspension, 33x12.50s, 4x Warn driving lights
Bassili is offline
post #2 of 6 Old 09-09-2001, 06:38 PM
RodeoRob
RodeoRob's Avatar
Its an okay route to if you're looking at keeping costs down. typically people suspension lift first, and only resort to body lifts when suspension lifts have been exhausted. the only bad part about the BL, it won't help your ground clearance like a suspension lift would.
not sure if you can clear 33's with only 3" of body lift. I know my friends 2" body lift won't clear 33's. is your's an auto or a manual? with 3" you'll need to extend both shifter and steering linkages. you'll have to loose the fan shroad, or drop the radiator.
if i could make another suggestion, maybe consider a SOA (spring over axle) conversion. The technical factor is a lot higher, but this can be done cheap (especially if you or a friend can weld) and will yield 4-5" of suspension lift keeping the stock ride. IMHO, would be a better route to go to.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 6 Old 09-10-2001, 05:26 PM
Cinderella
Hi,
tend to follow rodeobob's ideas:
stay away from body-lifts as long as you can, it will force you to adapt ( if you are going over 1" BL ): brake lines, gear-box, steering and other linkages, radiator position etc, etc, (in fact everything which is in between the body and "chassis") ... GO for a suspension lift: up to 2.5" you won't have any problems BESIDES realigning the rear differential ( facing more "up") to the transfer-case. And this will safely clear 31-32" tires. Why do you want to go for 33" ? Don't forget big might be beautifull but ... "does size matter?"
JOS
92YJ (2,5L 4cyl, K&N-Cyclone-restrictor.removed..., HP-exhaust,HD clutch, 2,5"SL,1"BL, Rancho, SYE, Revolver, Quick Disconnects, telescopic track-bar, 33*9.5*15MT)WARN9000
Cinderella is offline
post #4 of 6 Old 09-10-2001, 05:48 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
I am comfortably running 33 x 12.50 tires with my 4" suspension lift. I got the cheapest lift possible, which is very stiff, great for mud racing, but not all that great for rock-crawling.
I am also against body lifts, unless everything else is exhausted .. my next modification that I am planning is BushWacker's new PocketStyle "CutOut" fender flare .. looks like I might be able to fit 35" tires using them with my 4" lift .. for a stock YJ, I'd imagine a 32" tire would be able to fit. Mix that with the 2.5" suspension lift and you might fit 33" tires .. might be the easier way to go ..
Something to check out .. (btw: I can't find information on BushWacker's site about these flares yet, only in the magazines).
Laters!
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #5 of 6 Old 09-10-2001, 10:45 PM
NaeKid
NaeKid's Avatar
Hey Bassili,
Just received your private message, but the way my email works, its difficult to reply back.
Hey,
sorry to bother you but I just have a question for ya. I noticed you have an 88 laredo and I think I read that you have 33s. Im looking to put a 3inch body lift and 33s on my 88 laredo and I'm just wondering what problems u ran in to at all. I don't really know anything at all about fixing stuff myself so I will be getting it installed but will I have to change anything else besides getting new rims? Thanks a lot.
Well, as a starter, the 3" body lift would not be enough to clear the tire without rubbing .. as an '88 Jeep, your springs are probably sagged out (mine sure were) and the shocks are just about gone as well. If you replace your springs and shocks with stock units and a body lift, you might be lucky to fit (with minimal rubbing). Look at your rear springs .. which direction are they sitting .. do they have a downward arch, flat, or upward arch? If they are flat or upward, the springs are sagged out and the 33" tires will not fit with only a body lift.
Hope this helps you in your decision making.
Take a peak at my Jeep at HardCoreJeep.com under "Jeep Shots" if you are interested ..
Silver
NaeKid is offline
post #6 of 6 Old 09-13-2001, 08:09 PM
87yj350
Bassili, I got your message and I put info on my jeep back where the picture is. Go back and read about it there.
Thanks
87yj350 is offline
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
