My Leafs are flat as a pancake.... - JeepForum.com
post #1 of 17 Old 02-23-2010, 02:53 PM Thread Starter
Gunmetal
Is that normal? I mean, I don't know what they should look like if they are new, but I know the leaf springs on my dodge ram were not flat. People talk about sagging, but in order to notice sag you have to have something to compare it to. Since I just got my jeep I am not sure if they are supposed to look like that.
If they are sagging, what is the best fix? A new set? How about just a set of add a leafs?
Gunmetal is offline
post #2 of 17 Old 02-23-2010, 03:23 PM
Elsahara
Mine on the 90' where pretty much flat. I still managed to fit some 31 bfg ats on. But the black diamond lift on our 89' has alot more arch then the stock leaf springs had (obviously). I would guess to say that the majority of stock leaf springs will be relatively flat or have just a small about of arch, after 20 years of use. I doubt they came with that much to begin with tho.
Maybe its time for a lift?
What you could do, depends on what you "want" to do
I had add a left on one of my toyota trucks and it worked nicely so as to not to sag in the rear.
If you were to get a new set, In my opinion, you should consider getting a small lift kit. Get new shocks (those alone could make a world of difference if yours are oem) and and maybe a 2" lift set of springs.
Guess it really depends on what you want to do with your jeep.
Use the search and the picture forum if your curious what a lift would look like on your rig.
Elsahara is offline
post #3 of 17 Old 02-23-2010, 03:25 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Stock YJ springs from the factory had little to no arch in them.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #4 of 17 Old 02-23-2010, 04:19 PM
89-YJ
I just pulled mine off and they were pretty flat too. Im in the middle of an SOA swap..bought some 3.5 lift springs. Should be set
89-YJ is offline
post #5 of 17 Old 02-23-2010, 07:52 PM
College94YJ
I always wondered this too, Mine has 130k on stock leafs so I just thought they were saggy. I'm going to a 3" lift when I get the money though
College94YJ is offline
post #6 of 17 Old 02-23-2010, 09:36 PM
CreepyCrawler95
can i have them
CreepyCrawler95 is offline
post #7 of 17 Old 02-23-2010, 10:26 PM
Uberjeep
If you are handy with a wrench, can scrounge a pick 'n pull yard, and have an afternoon to kill, do a bastard pack lift. Worked wonders for mine. Can do both front and rear the same way, but in my case the rears were totally flat with some arc left in the fronts so I have only done the rear so far. I am doing a 75% driveline swap (scout dana44 front axle/nv3550 trans/dana300 transfer case) this summer, so I will do my fronts then.
http://www.jeepforum.com/forum/f12/s...led-yj-752903/
Originally Posted by 2003Rubi View Post
Make sure you get a sticker that says "Jeep" in Japanese lettering, that mod is good for about 20-25 hp right there.
My Jeep has only ever killed three things. A deer, a dog, and my wallet.
*retired* Low Output Jeep Club # 135
Uberjeep is offline
post #8 of 17 Old 02-24-2010, 06:04 AM
VACJ5
I am hoping the stock springs I just picked up are nice and flat when I go SOA... better ride and flex. High arch = stiffer spring and less flex.
And 89-yj... SOA with 3.5" lift springs is going to put your wayyyy up in the air. Guys run 42's on SOA yj's with 1.5 and 2" springs.
79 CJ5 Silver Anniversary Edition... revived & sold *sniff
91 YJ 4.0 L, with some stuff bolted to it...
91 2 door Cherocar... in progress
Custom CNC cut Jeep parts & more
VACJ5 is offline
post #9 of 17 Old 02-25-2010, 12:06 PM
89-YJ
I read through a few build threads and i see guys running soa with 3in springs and 37's. I dont know how to get 42's on with out completely hacking your fenders...assuming you want room to articulate.
89-YJ is offline
post #10 of 17 Old 02-25-2010, 04:45 PM
VACJ5
highline tube fenders and comp cut and you would be good to go. You dont need a ton of uptravel, maybe 4-5 inches max, it is the droop which means the most. 3" springs are going to be pretty stiff and not flex nearly as well. But some dont really care about flex, just wanna clear "big tires"... so I guess it is all preference.
VACJ5 is offline
post #11 of 17 Old 02-25-2010, 07:16 PM
YJ Ynot
that is gonna be huge..soa gets 5 1/2 alone if you need more go with
a BL..
TOMMY
1994 YJ
4inch Suspension Lift, 35x15x14,2.5
I'll stop procrastinating tomorrow...
YJ Ynot is offline
post #12 of 17 Old 02-25-2010, 11:33 PM
89-YJ
Oh i know the jeep is going to sit really high. I bought it wrecked and its just going to be something fun for the trails. We'll see how it turns out.
89-YJ is offline
post #13 of 17 Old 02-26-2010, 07:34 AM
leadsled01
There is a local junk yard really close to Akron, Ohio called MARS . They have a yj wrangler with 3" lift springs for $55 a spring, if you are interested in a used spring lift.
leadsled01 is offline
post #14 of 17 Old 02-26-2010, 07:39 AM
CreepyCrawler95
wht size tire are you planning on running cause a 3.5" SOA is around 9" o lift. 40-44 im thinking. or you can run 31x10.5's haha get more flex
post #15 of 17 Old 02-26-2010, 09:09 AM
YJhobby
Currently my stock suspension springs sit about the exact same as everyone says... flat, or the slightest amount of arch. Mine has the 4.0 and a hardtop too, so I know mine aren't too worn cause they're not inverted .
I have 31's on it and They rub when I drive on anything rough at all, so until I lift it I'm stuck on the road
~Steve~
Originally Posted by SnowdogMarc
YJ's don't get stuck....they get temporarily impeeded in their forward progress.
I'm patiently waiting for the "foot-in-mouth" moment to end... but since I've posted, its not today
YJhobby is offline
Making a flat belly very flat Recoil TJ Wrangler Technical Forum 6 09-19-2009 10:24 PM
how flat should my rear leafs be? TylerMidthassel YJ Wrangler Technical Forum 3 11-02-2008 09:44 AM
XJ leafs??? jeepnphreak YJ Wrangler Technical Forum 1 01-22-2008 05:06 PM
Leafs on a TJ? Hydro TJ Wrangler Technical Forum 21 08-12-2007 12:58 PM
4 leafs all around? Crotalus YJ Wrangler Technical Forum 8 02-05-2004 10:25 PM
