my jeep wont crank when weather is cool - JeepForum.com
post #1 of 5 Old 07-09-2013, 11:36 AM Thread Starter
keithd1
Hey folks. I have a 1994 wrangler that will not crank when it's cool outside. It started when it was really cold outside, but now wont crank when it is 70 degrees outside. when I try to crank it, they relay box starts ticking real fast. I can remove both the fuel pump relay and the auto shutdown relay and the ticking stops. Replace them and the ticking continues. When the ticking eventually slows down and stops, it will try to crank. it takes a little bit, but will. it acts like it's flooded and you can smell gas pretty strong like. Help me please.
Keith
keithd1 is offline
post #2 of 5 Old 07-09-2013, 11:39 AM
OKwranglerYJ
http://www.jeepforum.com/forum/f12/c...rs-ecu-492597/
It's the Ecu, the capacitors go bad. Is your engine a 2.5 or 4.0.
OKwranglerYJ is offline
post #3 of 5 Old 07-11-2013, 09:50 AM Thread Starter
keithd1
2.5
keithd1 is offline
post #4 of 5 Old 07-11-2013, 09:55 AM Thread Starter
keithd1
where are you at in Oklahoma? I'm in Altus.
keithd1 is offline
post #5 of 5 Old 07-11-2013, 10:39 AM
OKwranglerYJ
Sweet I'm in carnegie, I have an extra Ecu that has had the caps replace if you don't want to deal with replacing them. Do you have Facebook?
