My jeep whistles! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My jeep whistles!
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 01-11-2009, 01:28 PM   #1
JeepMud02
My jeep whistles!
Very weird problem, my jeep whistles at a high pitch after driving for a couple minutes. It never starts right away, you have to drive it for a bit. It also only whistles when i let off the gas or depress it to about 10%. To me it seems like a vacuum issue because once i step on the gas its gone. It will whistle at idle most times, but once i open the hood to find whats going on, it usually stops. The whistle sounds like its coming from the way back of the engine bay, but i can never figure out whats causing it. I also recently had a new manifold installed with the mopar metal gasket. Any ideas?
2000 TJ I-6 5spd
2inch BB 31x10.50 Trxus M/T's / 15x8 AR 767's / Safari top / Windjammer / Duster / JKS Quicker Disconnects / M.O.R.E. 1" MML / Durabacked Tub
[CENTER][COLOR=blue]The Almighty 2" BB Jeep Club Member #19[/COLOR][/CENTER]
JeepMud02 is offline   Reply With Quote
Unread 01-11-2009, 02:28 PM   #2
unideluxe
How is your cooling system?
I had the same problems where it was whistling but it ended up being a hole in the radiator, letting out air..especially when the engine was under load.
1993 BLACK Wrangler, 1.5" shackle lift, CJ hardtop, rest is stock....dang it college.
Originally Posted by Ribramax View Post
If you ain't bustin' it you ain't usin' it. If you ain't usin' it you don't need it.
Support Jeep Forum!! Equipment Drive
unideluxe is offline   Reply With Quote
Unread 01-11-2009, 02:32 PM   #3
TheNewbie
This reminds me of Jeff Dunham talking about Gay Man.
But sorry, no help on the actual problem.
TheNewbie is offline   Reply With Quote
Unread 01-11-2009, 02:39 PM   #4
jeepercreeper77
check the manifold bolts. they do come loose and will cause the problem your having.i also have a weber on mine with the aftermarket air cleaner and when i'm driving down the road the carb does make a whistling noise.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
jeepercreeper77 is offline   Reply With Quote
Unread 01-11-2009, 02:43 PM   #5
JeepMud02
all the manifold bolts are tight, the whistle is much louder in the back of the motor, so i cant see it being the radiator. I just got a wash, and i could not get it to whistle at all, so now i have no clue why water is stopping whatever is whining
2000 TJ I-6 5spd
Unread 01-11-2009, 05:08 PM   #6
JeepMud02
bumppppppp
2000 TJ I-6 5spd
