my jeep wants to turn off - JeepForum.com
post #1 of 9 Old 07-14-2009, 02:51 PM Thread Starter
metalroses
i let it warm up and the carburetor is new, the rpm is at 5 in drive and with the ac on almost four. does the spark plugs or the gas filter has to do with anything of this?
metalroses is offline
post #2 of 9 Old 07-14-2009, 04:22 PM
4.7stroker
Can't you just increase the idle rpm?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #3 of 9 Old 07-14-2009, 08:22 PM Thread Starter
metalroses
i did but the rpm increases only on parking and nuetral. reverse and drive keeps on 5 to 4 and park a N at 9 rpm i don know whtas happening
post #4 of 9 Old 07-15-2009, 03:33 AM
snareik
any error codes?
snareik is offline
post #5 of 9 Old 07-15-2009, 05:43 AM
Sxinc
Check your air valves in the front.. oh i cant think of what they are... in front of the carb.. I have been fighting with my jeep for the past month with diening out and rough idle and the works... I cleaned the needle out in the fuel inlet to the carb, new fuel filter and found i had a bad plug, replaced it and messed with the air valves in front of the carb and the choke was off some how, Runs so smooth can hardly tell its running.. What kind of carb are you running.. check for AIR LEAKS! Spray carb spray around it and if it idles higher you have a leak... Also another problem I had was air intake into the carb was all messed up.
edit: SHUT THE AC OFF.. TOP AND DOORS OFF!!
Sxinc is offline
post #6 of 9 Old 07-15-2009, 07:32 PM Thread Starter
metalroses
ive cheked all the valves and no air leaks man, ihave a holley carburetor also im changing the fuel filter tomorrow to see if he stops choking. any more tips for me to chek?
post #7 of 9 Old 07-15-2009, 09:14 PM
Sxinc
Nutter Bypass? Clean the needle in the fuel line? Plugs? Fuel filter? PCV Valve?
Sxinc is offline
post #8 of 9 Old 07-16-2009, 06:01 PM Thread Starter
metalroses
ok ill try those things man
post #9 of 9 Old 07-20-2009, 01:58 PM Thread Starter
metalroses
jum tried the sparks and the fuel filter and yet still the same! damn it!
Jeep won't turn over jeffmc TJ Wrangler Technical Forum 21 03-06-2011 06:41 PM
Turn singal does not turn off when I turn left. MWguy101 YJ Wrangler Technical Forum 31 02-14-2010 04:21 PM
jeep won't turn over robhalifax TJ Wrangler Technical Forum 3 10-10-2009 05:36 PM
Jeep won't turn off 93YJNewf YJ Wrangler Technical Forum 20 05-22-2007 08:34 PM
jeep doesn't want to turn off :( Brack YJ Wrangler Technical Forum 8 01-21-2004 11:06 PM
