my jeep smells - JeepForum.com
post #1 of 14 Old 10-23-2001, 06:06 PM Thread Starter
zuck2001
my jeep smells
I'm not sure when it started happening, but my jeep smells like sulfer from time to time. I have no idea what it is, but it is produced by the engine in some way or form. Should i be concerned; what is it?
'89 YJ w/ 4.2L I-6, 2.5" Rancho SL, 2" BL, 1.25" SHKLL, Uniden CB, 2 JL Audio Subs and Banpass box with a 300/1 2 channel Earthquake Amp, 33X12.5 Cooper S/T, no sway or trac bars, no bump stops, 2 titanium KC's.
zuck2001 is offline
post #2 of 14 Old 10-23-2001, 08:20 PM
Jefff
Cut back on the re-fried beans & eggs
Jefff is offline
post #3 of 14 Old 10-23-2001, 09:20 PM Thread Starter
zuck2001
Funny, haha, but seriously i have no clue what it is and if it is some by rpoduct that i am burning. I've noticed a lot of soot on the tail pipe and my engine runs real bad sometimes (see other related topics). I'm not sure if it's all part of the same problem.
zuck2001 is offline
post #4 of 14 Old 10-23-2001, 09:46 PM
Willis91YJ
Check the compression in the first cylinder. You may be getting half burned gas-air mix blowing past the rings. Also do you have any evidence of oil in the air filter or airbox? Notice a high pitched wooshing sound? I have a sooty tailpipe (borla no less) and mine smells too. Let me know whatcha got and I'll help you the best I can
Willis
Black 91' YJ with fresh 4.0, Sitting on 31x11.5 Mickey Baja MTX's on 15x10 AR767, Borla Stainless cat-back, free flow cat, it seems like I keep breaking necessary parts just about the time I get enough money together for the fun stuff!!!
Willis91YJ is offline
post #5 of 14 Old 10-24-2001, 02:26 AM
Morgster
This sounds like a job for cat converter cleaner. Go to your local auto parts store and get a can. (About $5.00) Use it in your gas, or pour it down your carb for a faster fix. (read instructions)It will say right on the can "for that rotten egg smell"
Morgster is offline
post #6 of 14 Old 10-24-2001, 02:30 AM
Morgster
By the way... don't worry...This is just your smog systems way of saying "remember me"
Morgster is offline
post #7 of 14 Old 10-24-2001, 07:34 AM
HJ
Check out your battery - it could be dry! (a sulphated cell!) this can be the source of the smell if it is sulphurous.
Best wishes - Hwfa
Hwfa
HJ is offline
post #8 of 14 Old 10-24-2001, 08:43 AM
skyj35
It definitely sounds like it is your cat. Although cats are designed typically to outlast the vehicle, they sometimes for fail. I would first try getting a can of cat cleaner, but if that doesn't work, you may be in the market for a new one. That's alright though, because you can find reasonable deals from catalogs like Essentials that sell high-flow cats that will even let your jeep breath better, while still remaining emissions legal.
94 YJ
6" Skyjacker Monolinear Rock Ready
3" Body Lift
35" Boggers
4.56's w/ lockers
skyj35 is offline
post #9 of 14 Old 10-24-2001, 11:52 AM Thread Starter
zuck2001
I just got a new exhaust system , and the problem has persisted. It included a new high flow cat. The battery is fairly new also, but i'll chack that and the compression ratios all the way around. Thnaks for all your help guys.
zuck2001 is offline
post #10 of 14 Old 10-24-2001, 03:11 PM
Jeff M
Does the smell get significantly worse when going up hills or when the engine is working hard?
Mine makes a funny smell too. Not sure what it is but it kinda burns my eyes after driving it for a long distance.
I'm stumped!
Jeff M
90 4cyl
Jeff M is offline
post #11 of 14 Old 10-24-2001, 05:03 PM Thread Starter
zuck2001
I have no clue, but i'll look for it next time i drive. Yeah, I'm pretty stumped.
zuck2001 is offline
post #12 of 14 Old 10-26-2001, 09:29 AM
jeepinkid
if you have a stick it is most likely burning the clutch if you don't go so hard on the clutch pedal
jeepinkid is offline
post #13 of 14 Old 10-26-2001, 10:08 AM
12345Wolfie
There was a recall on the Cat. Converter on 89 and 90 yj's. Had mine replaced for free in 96 or 97.
99 TJ Sahara
"May the trail rise up to meet you and the wind be always at your back!"
12345Wolfie is offline
post #14 of 14 Old 10-26-2001, 01:03 PM Thread Starter
zuck2001
Well thanks guys, I've figured it out. The clutch hasn't been hanged, ever. I noticed the smell and correlated the with the rough shifting and found that y clutch is alomost fried. It's kind of convenient because my tranny is going out too. Time for a NP4500 with an Atlas II and a centerforce 3.
zuck2001 is offline
jeep smells as gasoline metalroses YJ Wrangler Technical Forum 12 08-06-2009 12:48 PM
My jeep interior is wet and smells ? chaznad TJ Wrangler Technical Forum 10 07-02-2009 04:29 PM
How to eliminate smells from the Jeep MB98XJ TJ Wrangler Technical Forum 29 01-10-2009 09:42 PM
Jeep problem: Check engine comes on, idle raises, smells like gas Hotimportcrx YJ Wrangler Technical Forum 4 07-18-2008 05:52 PM
Jeep still smells hot months after SYE install 01amberfirewv TJ Wrangler Technical Forum 7 12-25-2006 08:42 AM
