-   -   my jeep smells (http://www.jeepforum.com/forum/f12/my-jeep-smells-7264/)
zuck2001 10-23-2001 07:06 PM
my jeep smells
I'm not sure when it started happening, but my jeep smells like sulfer from time to time. I have no idea what it is, but it is produced by the engine in some way or form. Should i be concerned; what is it?
Jefff 10-23-2001 09:20 PM
Cut back on the re-fried beans & eggs :)
zuck2001 10-23-2001 10:20 PM
Funny, haha, but seriously i have no clue what it is and if it is some by rpoduct that i am burning. I've noticed a lot of soot on the tail pipe and my engine runs real bad sometimes (see other related topics). I'm not sure if it's all part of the same problem.
Willis91YJ 10-23-2001 10:46 PM
Check the compression in the first cylinder. You may be getting half burned gas-air mix blowing past the rings. Also do you have any evidence of oil in the air filter or airbox? Notice a high pitched wooshing sound? I have a sooty tailpipe (borla no less) and mine smells too. Let me know whatcha got and I'll help you the best I can
Willis
Morgster 10-24-2001 03:26 AM
This sounds like a job for cat converter cleaner. Go to your local auto parts store and get a can. (About $5.00) Use it in your gas, or pour it down your carb for a faster fix. (read instructions)It will say right on the can "for that rotten egg smell"
:rolleyes: :eek: :o :D :cool:
Morgster 10-24-2001 03:30 AM
By the way... don't worry...This is just your smog systems way of saying "remember me" :D
HJ 10-24-2001 08:34 AM
Check out your battery - it could be dry! (a sulphated cell!) this can be the source of the smell if it is sulphurous.
Best wishes - Hwfa :confused:
skyj35 10-24-2001 09:43 AM
It definitely sounds like it is your cat. Although cats are designed typically to outlast the vehicle, they sometimes for fail. I would first try getting a can of cat cleaner, but if that doesn't work, you may be in the market for a new one. That's alright though, because you can find reasonable deals from catalogs like Essentials that sell high-flow cats that will even let your jeep breath better, while still remaining emissions legal. :(
zuck2001 10-24-2001 12:52 PM
I just got a new exhaust system , and the problem has persisted. It included a new high flow cat. The battery is fairly new also, but i'll chack that and the compression ratios all the way around. Thnaks for all your help guys.
Jeff M 10-24-2001 04:11 PM
Does the smell get significantly worse when going up hills or when the engine is working hard?
Mine makes a funny smell too. Not sure what it is but it kinda burns my eyes after driving it for a long distance.
I'm stumped!
Jeff M
90 4cyl
zuck2001 10-24-2001 06:03 PM
I have no clue, but i'll look for it next time i drive. Yeah, I'm pretty stumped.
jeepinkid 10-26-2001 10:29 AM
if you have a stick it is most likely burning the clutch if you don't go so hard on the clutch pedal
12345Wolfie 10-26-2001 11:08 AM
There was a recall on the Cat. Converter on 89 and 90 yj's. Had mine replaced for free in 96 or 97.
zuck2001 10-26-2001 02:03 PM
Well thanks guys, I've figured it out. The clutch hasn't been hanged, ever. I noticed the smell and correlated the with the rough shifting and found that y clutch is alomost fried. It's kind of convenient because my tranny is going out too. Time for a NP4500 with an Atlas II and a centerforce 3.
The time now is 12:25 AM.
