My Jeep is Possessed.. Heeeelp! :) - JeepForum.com
post #1 of 5 Old 05-08-2007, 10:10 AM Thread Starter
denwagh
So.. the ignition buzzer buzzes in time with bumps, etc on occassion.. It sounds like a herd of bee's in my dash.. Anyone ever seen this issue? I'm guessing it's a short someplace, perhaps a ground for the buzzer itself or a bad ignition switch? Does this buzzer do anything else that I don't know about (Like alerts for gauges, I doubt it but what the heck..)
Anyone.... Bueller?
denwagh is offline
post #2 of 5 Old 05-08-2007, 02:20 PM
kwboom
just a thought but it might be the buzzer for the seatbelts...... Just disconnect the plug at the base of the seatbelt mount and see if it still does it...... There is a little switch in the female part of the seatbelt that detects when you have the belt insterted and will not ste off the buzzer unless the belt is not in there.....
kwboom is offline
post #3 of 5 Old 05-08-2007, 02:23 PM Thread Starter
denwagh
Weird.. I usually end up not riding with my belt bad I know.. But I'll try it.. I didn't know it had that in the old YJ's... But that would make sense..
denwagh is offline
post #4 of 5 Old 05-08-2007, 02:32 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Problem solved, always wear your seatbelt.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is online now
post #5 of 5 Old 05-08-2007, 03:02 PM
NewdRiver_
It might be the door buzzers. The PO broke the drivers side one taking it out, and left it hanging there. I got random buzzes all the time driving around. Turns out it was the switch touching the kicker panel and making a ground.
NewdRiver_ is offline
Possessed Jeep.....TIPM issue?? Lights, horn wipers, etc.... Busa196 JK Wrangler Technical Forum 40 12-31-2015 06:01 AM
Help jeep is possessed. electrical failure? btn2020 YJ Wrangler Technical Forum 7 11-22-2009 03:44 AM
My Jeep is Possessed - HELP! w8r TJ Wrangler Technical Forum 6 03-25-2009 11:58 AM
LJ is possessed!!!!!!!!! None TJ Wrangler Technical Forum 21 03-05-2007 07:34 PM
HEEEELP! Panic Attack!!!!! Alex70 YJ Wrangler Technical Forum 3 02-24-2005 06:56 PM
