my jeep gets flooded inside - JeepForum.com
post #1 of 19 Old 08-11-2011, 08:32 AM Thread Starter
SrdjanDV
Hello Guys;
Here is the thing, everytime that rains my jeep gets a lot of water inside, I am not totally sure from where the water comes in, but it seems the water seeps somewhere between the windshield and the bulkhead. So has anyone of you guys been able to solve this problem? or has anyone had water entering into the jeep? I thought it was the cowl rubber seal, so I had replace it, but the problem persist, therefore I have been thinking on the grid through which the air gets into the heating system.
Any help will be very appreciated
Thanks
SrdjanDV is offline
post #2 of 19 Old 08-11-2011, 08:44 AM
Jarred2
Sometimes jeeps just leak. Lol but alot of mine came through my windshield frame even after I replaced the rubber. I noticed my leak came through the vent on the hood and ran all the way through to my heater core. It was cracked somehow so I just sealed it up and it solved the leak for the most part.
She lets me ride her whenever i want. I buy her shiny things all the time. Give her a kiss and hug every morning and night. Think about her all day and dream about her at night. We have the perfect relationship. Me and my jeep that is.
The way I see it, a Jeep is like sex-when it's good it's terrific, and when it's bad it's still pretty good!
Semper Fidelis
Jarred2 is offline
post #3 of 19 Old 08-11-2011, 08:57 AM
jhumphrey
Originally Posted by SrdjanDV View Post
Hello Guys;
Thanks
First thing is to find where the water is coming from. Check out this thread on how to find it and how to fix it:
http://www.jeepforum.com/forum/f12/t...up-how-628941/
jhumphrey is offline
post #4 of 19 Old 08-11-2011, 10:23 AM
Matt24138
I have been chasing a leak forever I have done all the suggestions. First check the drain hose on the firewall and cut off the bottom where it is tapered. Helps to avoid clogs. I am now replacing my windshield frame and doing my 4th cowl seal. If you do the seal make sure you loosen the hinge bolts and push down on the frame. This helps get proper preassure on the seal. Good luck I have spent several hundred dollars and a bucket of money on this issue. I wouldn't care except the water dumps on my fuse block and I lose my headlights and wipers. Not good in the rain lol.
Matt24138 is offline
post #5 of 19 Old 08-11-2011, 11:30 AM
jhumphrey
You mean to tell me that not doing this on your jeep is not the norm?
"A woman's body is a work of art. A man's body is a utilitarian. It's for gettin' around. It's like a Jeep." - Elaine Benes
post #6 of 19 Old 08-11-2011, 11:36 AM
Matt24138
I didn't say that just sharing the joys of jeep ownership with the unsuspecting lol.
post #7 of 19 Old 08-11-2011, 11:37 AM
Matt24138
I meant hours and buckets of money
post #8 of 19 Old 08-11-2011, 11:38 AM
Jarred2
^^^ lol Thats the truth
Semper Fidelis
Jarred2 is offline
post #9 of 19 Old 08-11-2011, 11:54 AM
Matt24138
It's a love hate relationship. When things are good I love my jeep like my kids. When it's not I want to strap a bomb to it and never look back. Thankfully the good tines have been outweighing the bad so far. Sorry a bit off topic.
post #10 of 19 Old 08-12-2011, 02:01 AM
kphimself
Jeeps just leak from everywhere. I carry a bottle of every fluid in the YJ and I haven't had the drian plugs in for almost a year.
kphimself is offline
post #11 of 19 Old 08-12-2011, 07:07 AM
jhumphrey
ISN'T that the truth!?!?!
You, my friend, need to find the leaks lol. My yj doesnt leak from anywhere, but it's almost a full time job to keep the leak gremlin from shacking up in my jeep. Once he establishes a home there, he invites his relatives. Not in my jeep!
The FAQ I referenced earlier is a great one. It shows pretty much everywhere a leak can come from. If you have other leaks into your cab that are not water related, then you need to track it down ASAP. Most likely, your heater core is busted if its antifreeze leaking in (from under the passengerside dash). If you have brake fluid coming in from under the driverside dash, then your clutch master cylinder is going out. Ask me how I know about all those leaks
post #12 of 19 Old 08-12-2011, 07:25 AM
Berniebikes
Here's what I found behind my hinges, after chasing around every place I could find looking for a leak. You might want to check that out. I tried all the usual stuff, cowl seal, drain from the cowl, sealing the body panels, etc. nothing worked until I dealt with this. BTW no rust anywhere else on the entire body!
Berniebikes is offline
post #13 of 19 Old 08-12-2011, 07:51 AM
Matt24138
I found a complete windshield frame locally for 50.00 from a guy parting one out rust free and including wipers and motor. Score! I am painting it this weekend with rattle cans of duplicolor gm matched paint. I am expecting to find the same under my hinges. If this doesn't fix my issue I am going to spray foam a solid block under my dash lol.
post #14 of 19 Old 08-12-2011, 08:20 AM
hrt4me
makes me want to take a look under my own YJ's hinges this weekend...
hrt4me is offline
post #15 of 19 Old 08-12-2011, 02:06 PM Thread Starter
SrdjanDV
Hi Guys;
What I have already done was:
1.- replace the old rusted windshield frame by a brand new one.
2.- replace the cowl rubber seal between the windshiedl frame and jeep body
3.- replace the windshield glass seal, BUT..................
It's still getting water into.
HELP!!!!!!!!!
SrdjanDV is offline
jeep flooded with water--what to look for?? restorod TJ Wrangler Technical Forum 7 07-22-2010 08:44 AM
Flooded Jeep - What to check/replace? SimonTuffGuy YJ Wrangler Technical Forum 25 11-17-2009 04:00 PM
Ever used propane to start a flooded Jeep? NEPhillyJeep YJ Wrangler Technical Forum 3 02-17-2007 06:19 PM
Jeep wet on inside Monrozombi TJ Wrangler Technical Forum 14 01-19-2006 04:32 PM
Jeep is flooded?! jeep_chinto TJ Wrangler Technical Forum 19 10-25-2005 04:01 PM
