My Jeep Cranks And Cranks But No Start!!! - JeepForum.com
post #1 of 6 Old 01-13-2009, 10:18 PM Thread Starter
b1ack2tar
my jeep wrangler, in cold weather, takes about 8 to 10 minutes to start. i will sit there and crank and crank and crank and it just takes forever to start, however. when its about ready to start my light that tells me to shift up will turn on when turn the key, that is how i know its about to start. ive replaced the crankshaft position sensor and it still does it. anyone!!!! please help!!!
b1ack2tar is offline
post #2 of 6 Old 01-13-2009, 10:23 PM
1998zj
It is your ECU going bad. There is no use cranking until the light comes on. You need a new one or there is a couple threads on here on how to repair it yourself.
1998zj is offline
post #3 of 6 Old 01-13-2009, 10:56 PM Thread Starter
b1ack2tar
what exactly is the ECU?
post #4 of 6 Old 01-14-2009, 06:59 AM
Alexsdad
Engine Control Unit...under your windshield washer bottle on the firewall.
My Son's Wrangler (I wrench it)
1994 2.5L AX-5
Alexsdad is offline
post #5 of 6 Old 01-14-2009, 08:14 AM
Anonymous6915
2009 JK Wrangler
good luck...im currently trying to fix this problem also try the brain surgery heres a link;http://www.jeepforum.com/forum/f12/crash-course-brain-surgery-replacing-capacitors-ecu-492597/
good luck tho...id did that and im still having problems...if you do this and it doesnt work, it might be a bigger problem then just the caps...
Anonymous6915 is offline
post #6 of 6 Old 01-14-2009, 08:23 AM
titoheadfaceman
There are probably 10,000 threads titled almost this exact thing. Just do a quick search and see what you find. You will more than likely find what you need. If you already did that, then just disregard what I said!
Good luck! Hope you get back to wheelin' soon!
titoheadfaceman is offline
Cranks and Cranks, cranks some more and she wont start. crzylgzz YJ Wrangler Technical Forum 37 12-09-2011 03:44 PM
Jeep won't start, cranks all day cyrdg3 TJ Wrangler Technical Forum 32 04-22-2009 09:17 AM
Jeep Cranks But Wont Start 442Wrangler YJ Wrangler Technical Forum 8 04-19-2009 03:33 PM
Jeep Cranks But Won't Start UTmike TJ Wrangler Technical Forum 4 04-14-2009 10:58 AM
Jeep cranks but won't start??? Krazy302 TJ Wrangler Technical Forum 1 02-23-2009 06:59 AM
