My Jeep ate its engine ! - need advice on engine swap... - JeepForum.com
post #1 of 6 Old 04-28-2009, 06:39 PM Thread Starter
ymibuyingmore
I got my 1994 YJ about a month ago knowing that it had a slight engine knock but the price was right. Well last night while pulling itself out of a mud hole it decided that it was time for a new engine and thru the rod out the side of the engine block. Jeep people are great though... another Jeep saw it happen, laughed his *** off, then pulled me out . I need advice on how to go about upgrading the drivetrain enough to have some weekend fun without sinking a ton of money into it. Right now it is a stock 4 cylinder with auto trans and 231 transfer case. I was told that changing it out with a Jeep 6 is more trouble than it is worth. I was wondering which trans with bolt up to the existing transfer case and if a Chevy V-6 or V-8 is a better overall fit for an everday driver to do a little mudding on the weekends with. Or if it is better in the long run to just buy one already with the mods done...Any help is greatly appreciated... Thanks !!
ymibuyingmore is offline
post #2 of 6 Old 04-28-2009, 07:16 PM
bob082484
My jeep did the same thing about a month ago. I just put in a new motor from atk. It would be best to just find a solid low miles junkyard 2.5 rather than buying a new one. I spent about a week trying to find all of the little parts that i needed. If you get a junkyard motor it should come with everything.
bob082484 is offline
post #3 of 6 Old 04-28-2009, 07:17 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Others will be able to advise you on SBC swaps, but it is a big job with many details. Many others find the 4 screaming squirrels to be adequate. Supporting the latter group there are many folks who may have access to a used 4 cyl they took out when they did some type serious upgrade, or they could be available in the junkyards to be rebuilt, put in as-is, or you can source them thru engine rebuilders online.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 6 Old 04-28-2009, 08:11 PM
SteveJcoYJ
i just threw in another 4cyl i found from a younger YJ, with a TJ trans an t-case
overall cost for everything came to about 500$
SteveJcoYJ is offline
post #5 of 6 Old 04-28-2009, 08:24 PM
stu1021
I have a 4cyl long block you can come pick it up in MD.
'90 YJ Wrangler - 4.3L Chevy
'91 GMC 3500 Bus - Tow Vehicle
'87 MBenz 300D Turbo
'02 MBenz E55 AMG
'55 Piper Apache
stu1021 is offline
post #6 of 6 Old 05-03-2011, 03:31 PM
bvk
seems like an appropriate place for these photos then. This happened on Saturday.
my rig looks like this
it did this:
hole in oil pan
hole in block
broken rod
bvk is offline
Advice on an engine swap breatheasyman YJ Wrangler Technical Forum 6 10-19-2009 05:38 PM
4.0 engine swap electrical advice oakblue YJ Wrangler Technical Forum 12 05-15-2009 03:53 PM
Looking for engine swap advice JpBill YJ Wrangler Technical Forum 1 03-08-2009 02:04 PM
engine swap, any advice? gman30 YJ Wrangler Technical Forum 2 10-09-2008 10:04 AM
engine swap advice needed three YJ Wrangler Technical Forum 5 04-16-2007 06:27 PM
