My heater blower puts out more air when not running, here's why - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My heater blower puts out more air when not running, here's why
TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lNitro Gear Packages Now Available at Rockridge 4wdFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-07-2008, 09:55 AM   #46
Nitrox73
Submitted Mr. B, thanks I never thought about putting it there.
Everybody knows.... It's hip to be square... Well at least square headlights!
Nitrox73 is offline   Reply With Quote Quick reply to this message
Unread 01-07-2008, 04:53 PM   #47
ctm
i never saw the pics, no red X, no url, nothing.
ctm is offline   Reply With Quote Quick reply to this message
Unread 01-07-2008, 06:12 PM   #48
workn4livn
I still see them fine.
I vote yes for sticky
workn4livn is offline   Reply With Quote Quick reply to this message
Unread 01-08-2008, 06:42 PM   #49
Nitrox73
Think I've fixed the links. Can anybody see them now?
Unread 01-08-2008, 06:58 PM   #50
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Yup, thanks. Once again awesome write up. This has been added to the heater FAQ as well.
Thanks!
Richmond88yj is offline   Reply With Quote Quick reply to this message
Unread 01-26-2008, 08:48 AM   #51
madmax79
I'm Old Gregg!
madmax79's Avatar
After reading this I was curious if mine was correct or not. I don't know if the guy on the assembly line didn't care which way he installed the vacuum valves or what, but mine was aparently backwards too. Switching this around did seem to help the amount of heat in the vehice. Pics follow. I also took a clearer pic of the hook-up of the vacuum lines to the heater.
'88 YJ, getting newer one part at a time. Details on my profile, you should fill out your profile too.
Early YJ Club, Member #1, Check out our group: Early YJ Club
Epic adventures usually start with something like: "I was looking at a topo map..."
www.matanzasjeepclub.com
madmax79 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2008, 10:31 AM   #52
nic99007
great write up, I vote STICKY
nic99007 is offline   Reply With Quote Quick reply to this message
Unread 02-02-2008, 02:54 PM   #53
Amadameus
Originally Posted by tony673
OMG, I think I have the same problem. I guess I know where I'm spending my day off tomorrow.....under the dash of the YJ!!
I've had a draft that just won't quit ever since I replaced the body tub. I've tried everything!; duct tape, masking tape, electrical tape, spray in foam insulation, cloth-you name it. Still, my legs feel a breeze.
Maybe I messed up the tubing placement on that vacuum thingy you speak of.
I can sympathize - my Jeep had, for some reason, a draft coming in around my ankles all winter. The heat comes in strong, so I really didn't have much to complain about - however my passengers were feeling the worst of it.
Turns out there was a nice big vent on the right side under the dash, around ankle height, that seemed to go straight to the outside air.
I could see no reason for there to be a passive cold-air vent in an already chilly vehicle (I say 'passive' because there appeared to be no motors or airflow when idling, the air was forced in at highway speeds) and so I taped it up with some good ol' Duct Tape and paid close attention to the Jeep for a few weeks afterward. I noticed no change, so I guess there was a useless air vent just... chilling out...
I do not profess to be a car-guy, I'm seriously 85% retarded when it comes to vehicles. However, the thing appeared to be useless and served no purpose that was missed once I taped it up. And the Jeep is several times warmer!
[COLOR="Blue"][B][FONT="Courier New"]You may be interested to know that your computer is off and I am speaking to you from inside your head.[/FONT][/B][/COLOR]
Amadameus is offline   Reply With Quote Quick reply to this message
Unread 02-02-2008, 03:07 PM   #54
Shenandoah
Are you referring to the outside air vent? Maybe the cable came loose and it was stuck open?
Turn a wrench, save a tree
Shenandoah is offline   Reply With Quote Quick reply to this message
Unread 02-19-2008, 07:03 PM   #55
Redskybri
Originally Posted by doug_1994 View Post
My heat allways roasts me out. If you want me to take a pic of mine I can.
Doug
Mine roasts me to. I have to open the draft window even when I turn the fan down.
Black 2004 Tj...
www.myspace.com/bchoag
Redskybri is offline   Reply With Quote Quick reply to this message
Unread 02-19-2008, 08:43 PM   #56
dlnagold
So, I have read through this post, can anyone explain to me this: I have the a/c in my 95. When I have the heat on, it only comes through the defrost and the floor vent, none of the settings enable the heat to come out of the vents under the radio, that is where the a/c comes out when turned on....is there a way to get the heat to come out of those vents? I regularlly drive with the doors off; however, lately I have been freezing my bottom off....
dlnagold is offline   Reply With Quote Quick reply to this message
Unread 02-20-2008, 01:02 PM   #57
jaminb
you could try and route the ducting into the a/c vents, but i dont think it would work to well. a lot of space to move air through.
jaminb is offline   Reply With Quote Quick reply to this message
Unread 02-20-2008, 04:01 PM   #58
johny1i
dlnagold -
Someone jump in if I'm wrong, but your AC system is a packaged unit under there that is totally independent of the heater/defroster system in terms of both controls and ducting. In other words, you could run your heater and AC at the same time. I've heard that the AC systems were dealer-installed options--whether that's true or not I don't know, but it is definitely stand-alone. Nothing wrong with your system based on what you described.
Currently an '86 CJ-7 and a '77 CJ-7 Golden Eagle---#4 and 5 following a '01 Sahara, '90 Sahara, and '85 CJ-7....
johny1i is offline   Reply With Quote Quick reply to this message
Unread 02-21-2008, 02:50 PM   #59
papa_panda
I just checked under my hood, and it's like the first picture, but when I disconnected it to flip around the black tapered side is clearly marked V A C... the stem on the blonde end is also much thinner, so I'm going to say it is already on correctly and it's not meant to be flipped around, and if it worked better for you after you ran it backwards, it's probably defective. I looked under my dash and the vacuum lines are where they're supposed to be. I guess my heater core is clogged after all.
'92 White YJ w/Grey soft top, 2.5L from '97 TJ, original 5-Speed, Silver Grizzly Alloy rims from 2001 TJ with Goodyear Wrangler GS-A 225/75R15
Marine Corps Jeep Club Member #7
White Jeep Club Member #350
papa_panda is offline   Reply With Quote Quick reply to this message
Unread 02-21-2008, 03:32 PM   #60
jaminb
i flipped mine around, it does not make the air any hotter, if anything is is colder, but it puts more air out, which helps it get around the cab more. So when it really cold out, its still going to be rather cold in the cab.
