Quantcast My heater blower puts out more air when not running, here's why - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My heater blower puts out more air when not running, here's why
Old 12-26-2007, 08:04 PM   #1
Nitrox73
I've read about guys with jeeps that bake them out after a couple minutes and was jealous because mine didn't. My heater blower wasn't putting out any air hardly at all while the YJ was running. However, if I just put the key in and turned it without starting it, it blows very hard.
I used the search feature and couldn't find anything that covered this.
After checking voltages and other things, I pulled my hood vent cover off. It was spotless and had zero debris inside. I noticed that the vent intake door was open. When I started the jeep up it closed with the heater control on defrost/heat/vent. When I shut it off the door re-opened. Both intake vent doors are controlled by the vacuum switch attached to the heater controls. It has three ports and two vacuum tubes connected to it.
It turns out my tubes had been plugged into the wrong ports! So when the jeep was off the intake doors were open and when running the vacuum closed the doors so no air was coming in from the hood vent.
As the proud owner of jeep that no longer requires a hooded sweatswirt to stay warm in, I hope this post might help somebody else out.
Everybody knows.... It's hip to be square... Well at least square headlights!
Nitrox73 is offline   Reply With Quote
Old 12-27-2007, 06:11 PM   #2
ctm
Could you please post a picture or a diagram as to which tubes go to which port. All I know is that one is for the vacuum source on the intake manifold, one goes to the door, and the 3rd one is for A/C? Does that mean when you have A/C hooked up it is the one that _closes_ the door to recycle cool air?
Anyway, it would be cool to document this. It is not documented in the FSM or anywhere else as far as I can tell.
ctm is offline   Reply With Quote
Old 01-02-2008, 09:09 PM   #3
V8Wrangler
1990 JK Wrangler
Yea someone how are these supposed to be hosed? Help a brother out!
V8Wrangler is offline   Reply With Quote
Old 01-02-2008, 10:56 PM   #4
jcourt667
Man, you mean I've been freezing my arse off all those years for nothing...
94 Sahara YJ 4.0L HO, 30x9.5x15 on AR 39's. 253K miles on the clock...Still going! Stock everything else.
Best vehicle I've ever owned!
jcourt667 is offline   Reply With Quote
Old 01-03-2008, 11:24 AM   #5
tony673
OMG, I think I have the same problem. I guess I know where I'm spending my day off tomorrow.....under the dash of the YJ!!
I've had a draft that just won't quit ever since I replaced the body tub. I've tried everything!; duct tape, masking tape, electrical tape, spray in foam insulation, cloth-you name it. Still, my legs feel a breeze.
Maybe I messed up the tubing placement on that vacuum thingy you speak of.
07 Wrangler Unlimited Rubicon
02 Liberty Sport
www.SpartanDefense.net <---- AR15, AK Accessories
tony673 is offline   Reply With Quote
Old 01-03-2008, 04:40 PM   #6
rhdeese
This may work for me.....I'll try.
rhdeese is offline   Reply With Quote
Old 01-03-2008, 06:45 PM   #7
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Oh man, 10* here this morning, post a pic or a diagram!
Richmond88yj is offline   Reply With Quote
Old 01-03-2008, 07:59 PM   #8
Shenandoah
I agree, it would be helpful.
Turn a wrench, save a tree
Shenandoah is offline   Reply With Quote
Old 01-04-2008, 09:04 AM   #9
jeepthg
X7
Bump to the top
.... any ideas from anyone else where to find this???
89 YJ 4.2L 33X12.5X15
upgrades since i bought it
4" lift : 33's :Rugged Ridge soft top : Dynomax exhaust : Rugged Ridge 7" flares : MC2100 :TFI : lights and dual tube front bumper: nutter bypass thanks to Richmond 88 YJ
more upgrades to come as the wife allows
jeepthg is offline   Reply With Quote
Old 01-04-2008, 11:33 AM   #10
schizm99
Huh
Was this a teaser thread or what?
89 YJ 4"rough country lift.
32-11.50-15 swampers
8000# black mountain winch
front lunch box lockers w/posi-lok
uniden cb, gt steering wheel, 4.10 gears
and anything else homemade
schizm99 is offline   Reply With Quote
Old 01-04-2008, 03:09 PM   #11
doug_1994
My heat allways roasts me out. If you want me to take a pic of mine I can.
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline   Reply With Quote
Old 01-04-2008, 04:48 PM   #12
Shenandoah
Doug
I would like to see how it is attached. Mine have been disconnected amny time by accident and I have gone through the attach and check procedure. But no manual (to my knowledge) shows the correct attachments.
Please post a pict, Doug.
Old 01-04-2008, 06:34 PM   #13
doug_1994
Sorry guys, I went out to take a pic, but I got AC, and the air plenum is in the way. I tried to put my digi camera up behind it, but it wouldn't take.
Doug
Plato
Old 01-04-2008, 08:17 PM   #14
Shenandoah
Doug:
Could you give us a diagram of the connections? It may help.
Old 01-04-2008, 09:23 PM   #15
doug_1994
I can't even get my camera in there, let alone my fat head!
But if I ever take apart my dash, I'll take a pic.
Doug
Plato
Glock Forum
