My heater blower puts out more air when not running, here's why - Page 3 - JeepForum.com
post #31 of 105 Old 01-06-2008, 06:11 PM
jeepthg
jeepthg's Avatar
ok now im headed back out to verify that this is what mine does....
i have a great heat now when i had little to none before. but if this can possibly give me more then im going to have to check it out.
89 YJ 4.2L 33X12.5X15
upgrades since i bought it
4" lift : 33's :Rugged Ridge soft top : Dynomax exhaust : Rugged Ridge 7" flares : MC2100 :TFI : lights and dual tube front bumper: nutter bypass thanks to Richmond 88 YJ
more upgrades to come as the wife allows
jeepthg is offline
post #32 of 105 Old 01-06-2008, 06:23 PM
ctm
Also, does anyone have a fix for those little heater cable clips with the tabs that tend to break off? I tried rigging up some nylon clips held by a sheet metal screw but it doesn't work that great. hate to shell out $$ for all new cables and/or a new control box that comes with the cables.
ctm is offline
post #33 of 105 Old 01-06-2008, 08:16 PM
jeepthg
jeepthg's Avatar
go to advanced or autozone and check out there clips they have a bunch of clips in a single isle. should take care of that
as for my vent doors....
my stuff matches everyone elses in function opening and closing when it should.. now tommarrow aint going to do any good for testing
it's supposed to be 70 so richmond yj you'll have to wait till this weekend it always gets cold on the weekend when everyone is off
jeepthg is offline
post #34 of 105 Old 01-06-2008, 10:30 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Originally Posted by ctm
I'm still not clear on which of the three ports the manifold vac plugs into. On Shenandoah's pic it is plugged into the the port 'on the right'. does it matter? I know it's not the center one, that goes to the air door?
The lil rubber connector has 3 holes.. Center for green tube going to flap, inboard one is black, this goes the the vac supply on intake manifold.
Empty Green Black
hole1 hole 2 Hole 3 - Plunger
The black one goes on the plunger side, green one in the middle
- Ernie
Richmond88yj is offline
post #35 of 105 Old 01-06-2008, 10:32 PM
Richmond88yj
Eat, Sleep, Jeep
Good to hear Bailey, got your voicemail, sorry didn't get it till late though, call ya back tomorrow. Thanks for the help, looks like we have it all working now.
Ernie
- Ernie
post #36 of 105 Old 01-06-2008, 11:17 PM Thread Starter
Nitrox73
Nitrox73's Avatar
Sorry I didn't reply quicker, having issues with my home computer...
Everybody knows.... It's hip to be square... Well at least square headlights!
Nitrox73 is offline
post #37 of 105 Old 01-07-2008, 12:54 AM Thread Starter
Nitrox73
Nitrox73's Avatar
Here's the "YJ Heater Guide" for everything you wanted to know about the heater operations... enjoy
When your controls are set to off
Your blower motor should not be energized, both vent doors inside your hood intake should be closed
and your vent door inside the cab on your passenger side should be closed
Driver Side-Closed
Passenger Side-Closed
Inside Vent-Closed
Nitrox73 is offline
post #38 of 105 Old 01-07-2008, 12:55 AM Thread Starter
Nitrox73
Nitrox73's Avatar
When your controls are set to defrost/heat
Your blower motor will now be energized with three speeds, the vent door inside your hood intake on the passenger side only will be open, and the inside vent will be shut
Passenger Side-Open
Driver Side-Closed
Inside Vent-Closed
Nitrox73 is offline
post #39 of 105 Old 01-07-2008, 12:56 AM Thread Starter
Nitrox73
Nitrox73's Avatar
When your contorls are set to vent
Your blower motor will not be energized, both vent doors inside your hood intake will be open, and the inside vent will be open
Passenger Side-Open
Driver Side-Open
Inside Vent-Open
Nitrox73 is offline
post #40 of 105 Old 01-07-2008, 12:57 AM Thread Starter
Nitrox73
Nitrox73's Avatar
The vacuum switch attached to the heater control has three ports. The hole closest to the plunger should have the black vacuum line in it. The second hole will have your green line in it. The third hole which is farest away from the plunger is left open.
You may have to tighten the switch itself up where it attaches to the heater control. If not the plunger may not be making contact with the heater switch.
I had to use new screws to get it tight as you can see here, this picture is taken from below the control
When the heater is in the Off position, the plunger should be pushed all the way in like this
Inside the hood vent intake; the passenger side vent is controlled by vacuum, while the driver side is cable controlled. If the black vacuum line is not connected to the switch on the heater control, the passenger side intake vent should remain open at all times.
Nitrox73 is offline
post #41 of 105 Old 01-07-2008, 04:43 AM
Richmond88yj
Eat, Sleep, Jeep
Thanks Nitrox, but pics aren't showing up, just red X
- Ernie
post #42 of 105 Old 01-07-2008, 05:37 AM
workn4livn
workn4livn's Avatar
I see them fine. Nice job, well done
workn4livn is offline
post #43 of 105 Old 01-07-2008, 06:42 AM
Richmond88yj
Eat, Sleep, Jeep
Well that's weird. 3 different browsers on 3 different workstations and I can't see em at all. Logged in or logged out. But... when I paste the url of the pic in my browser, I see them, then return to thread and I can see the pics I pasted int he browser. So if you don't see the pics, copy.paste the pic URL
- Ernie
post #44 of 105 Old 01-07-2008, 08:16 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Yea the same thing happened to me. I've had to do the copy/paste thing on other threads too, but rarely. We must have some security setting that stops them at first. What I do is copy and paste them into another web page that I have opened up, and then they miraculously show up on the other web page.
Great job Nitrox. You should submit this to Technical Articles & Write-Ups.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #45 of 105 Old 01-07-2008, 09:25 AM
sstaurus
sstaurus's Avatar
Can't see them here at home...?
'02 Sienna Pearl TJ Sahara
sstaurus is offline
Heater blower constantly running K_2 YJ Wrangler Technical Forum 20 10-30-2008 05:46 PM
Still no Heater Blower! GreyfoxVt YJ Wrangler Technical Forum 3 11-09-2007 02:42 PM
Heater Blower triplnet TJ Wrangler Technical Forum 0 12-27-2004 01:22 PM
heater/ac blower sulldoggy TJ Wrangler Technical Forum 2 11-03-2004 07:20 PM
Heater A/C blower motor not running, need wiring diagram! carrot1 TJ Wrangler Technical Forum 3 08-03-2004 02:51 PM
