my headlights keep turning off and going back on - JeepForum.com
post #1 of 18 Old 06-09-2008, 02:06 PM Thread Starter
YJ_95
so my head lights keep turning off randomly and go back on like 5 seconds later. it happened to me like 7 times last night within 10 minutes. I am thinking its wiring but what do you guys think? Also what should i check and where is it. Any help is appreciated.
YJ_95 is offline
post #2 of 18 Old 06-09-2008, 02:19 PM
denalione
I'd try the switch first. I just had all of my panel lights go out and it was/is the switch.
denalione is offline
post #3 of 18 Old 06-09-2008, 02:23 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Trace out the ground as well, IIRC, it is on the driver's side inner fender, towards the front. I will check/verify in my FSM tonite, but there are about 3 wires grounded here.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #4 of 18 Old 06-09-2008, 02:57 PM
pasinbuy
Sounds like the switch to me.
pasinbuy is offline
post #5 of 18 Old 06-09-2008, 02:59 PM
ChasY
I had the same problem. It was just the switch
91 YJ 350-sbc/th350/np231 RC 4inch, 1inch homebrew boomerangs, 35 MTRs, D30/8.8=4.10s, tj flares.
00 VW Jetta TDI 45mpg
ChasY is offline
post #6 of 18 Old 06-09-2008, 03:11 PM
pushead
Yup was this switch on mine as well.
Its not a jeep if it dont have 4wd.
pushead is offline
post #7 of 18 Old 06-09-2008, 03:20 PM
admisgd
admisgd's Avatar
2016 JK Wrangler
Gonna agree with all the switch people The part is relatively inexpensive and only takes about 5 minutes to replace. On a side note you should probably replace it asap it really is no fun when you are on some back country road at 10:00 at night 60miles from your house and it finally decides it is done for good. Don't ask me how I know.
93 YJ Renegade, I6, 4" RC Lift, K&N intake, Tuffy Trunk & Console, 10k lb Winch, Dana 30 Assuie Locker
admisgd is offline
post #8 of 18 Old 06-09-2008, 03:44 PM
Gurrenteed555
Happened to me too... And it was the switch.
Gurrenteed555 is offline
post #9 of 18 Old 06-09-2008, 05:50 PM
Jeeeeeeeeeeeeep
Either the switch or maybe your just blinking your eyes really slow
Jeeeeeeeeeeeeep is offline
post #10 of 18 Old 06-09-2008, 05:51 PM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Dare I say, the switch
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #11 of 18 Old 06-09-2008, 06:05 PM Thread Starter
YJ_95
ok thanks everyone for the advice. by the way when it was happening, it was raining heavily and my windshield was all foggy. It was pretty scary. I will get the switch switched right away.
YJ_95 is offline
post #12 of 18 Old 06-09-2008, 06:55 PM
timatoe
timatoe's Avatar
I had it happen on an S10 I had, also was the switch. I believe Jeep used a very similar switch in the YJ.
timatoe is offline
post #13 of 18 Old 09-04-2015, 09:03 PM
TITO3
Question what is this switch called??
TITO3 is offline
post #14 of 18 Old 09-04-2015, 10:44 PM
deathtrap
you guys that have replaced them, have any preferred brand or source for these? Or are they all the same quality?
deathtrap is offline
post #15 of 18 Old 09-05-2015, 04:52 AM
Mike Romain
The headlights switch.... If it burned out the breaker, you need to find out why. Usually it is from overpowered lights. The stock switch can only take stock lights, no more. If you add a relay to the lights so they get fused battery power direct and the switch only has to trigger the relay, you can power up as big or as many lights as you want.
Mike
Mike Romain is offline
Rear Tires Sway Back N Forth When Turning stillbrandon70 JK Wrangler Technical Forum 20 08-07-2009 07:16 PM
How do I stop the headlights from turning on when I remote unlock? HappyTrails JK Wrangler Technical Forum 10 04-28-2009 01:30 PM
Headlights go on, radio goes off. Headlights off, radio back on gary1 YJ Wrangler Technical Forum 10 10-29-2008 09:07 PM
Headlights delay in turning on RGregory TJ Wrangler Technical Forum 5 10-22-2008 02:02 PM
Turning back the clock FatBuoy JK Wrangler Technical Forum 24 01-15-2008 09:11 AM
