my header is cracked - JeepForum.com
post #1 of 5 Old 08-17-2009, 10:16 AM Thread Starter
92renegade
How hard is it to remove the exhaust manifold on a 92 renegade 4.0. Does the intake have to come off? It looks like there are only 2 bolts, is there more that I'm missing? I see that the after market header is cracked where the pipes go into the collector. I bought the jeep with the header on it, I don't know the brand but the welds look real shotty. I also noticed there is no flex joint in the exhaust system at all. Does anyone suggest adding this in? Maybe right off the header on the down pipe? This would be out of the way when off roading,yet give some flex in the system so this won' happen again.
92renegade is offline
post #2 of 5 Old 08-17-2009, 10:25 AM
idaholtby
Yes, the intake manifold has to come off as well. The intake and exhaust manifold share the same gasket and in many areas the same bolts and or studs. Seeing how you are in the rust belt, I would start soaking the bolts/studs with PB Blaster for several days before removal. Before beginning the work, inspect to see if any are missing so that you can have replacements in hand when you begin. There are replacement OEM style exhaust manifolds that come with baffles built in to help relieve the stress. This is a common problem with the exhaust manifolds cracking at the collector on the 4.0Ls.
idaholtby is offline
post #3 of 5 Old 08-17-2009, 10:28 AM Thread Starter
92renegade
Thanks for the info. I will start by soakng everything for days.How long do you think this would take with out air tools? Seeing that everything is rusted on this rig.
post #4 of 5 Old 08-17-2009, 10:33 AM
idaholtby
I don't think air tools will be an option. There just isn't enough room to get to most of the bolts. You need to be some what of a contortionist and use box wrenches and ratchets with universals. It will take a couple of hours and some choice words to get r done. Hopefully you won't break any of the bolts in the process, so budget time for that scenario before you begin.
post #5 of 5 Old 08-17-2009, 10:34 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Yea, avoid air tools for this. Hand tools will get it done, just take your time.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
Header Bow cracked.. MacK JK Wrangler Technical Forum 6 03-22-2010 02:30 AM
Cracked header......AGAIN!^*&%&^%#%$! stuartgray TJ Wrangler Technical Forum 28 06-16-2008 11:07 PM
98 TJ cracked header tjaggie TJ Wrangler Technical Forum 20 06-06-2006 03:15 PM
Cracked Header jisl YJ Wrangler Technical Forum 9 05-16-2003 11:11 AM
Cracked Header 2High4U YJ Wrangler Technical Forum 1 10-25-2001 08:22 PM
