My hand throttle install - JeepForum.com
post #1 of 7 Old 01-23-2008, 05:18 PM Thread Starter
YJames90
YJames90's Avatar
I bought the Rubicon Express hand throttle kit from Quadratech
This is a very simple install, it only took less then an hour
[IMG][/IMG]
To make the clamp fit tight I used two pieces of air line doubled on top of each other with slits down the side so they can be put over the stick shift.
Then I covered the hose in electrical tape
I then drilled a hole in the fire wall to feed the cable through trying to make it match the route of the pedal throttle cable
[IMG][/IMG]
I bent the angle bracket that came with the kit to make it flat then bolted the cable tensioner to the spring frame bracket. Ranr the cable through the tensioner,looped it around the throttle and crimped the cable loop tight.
I still have to snip off the extra cable. I didnt want to have it wrong and end up short if I had to change the routing of the cable
[IMG][/IMG]
[IMG][/IMG]
I went for a test drive and it works perfect, no binding or interfereance with the gas pedal.
Now I can set the idle when using my OBA.
I highly recommend this easy , cool mod
My 2.5 to 4.3 swap thread
YJames90 is offline
post #2 of 7 Old 01-23-2008, 05:46 PM
nic99007
looks good.
nic99007 is offline
post #3 of 7 Old 01-23-2008, 07:47 PM
pasinbuy
Anyone with a stick needs a hand throttle. Getting up a incline when you need to clutch and brake at the same time is a bear without a hand throttle.
pasinbuy is offline
post #4 of 7 Old 01-24-2008, 03:32 PM
Berb_15
This is awsome, I didnt know they actually made kits for this... this is one of those things I've always thought, what if... and now I know it's been done!!
"Lock tite!!
Mans best friend cuz your dog won't keep your jeep from falling apart."
Berb_15 is offline
post #5 of 7 Old 01-24-2008, 07:38 PM
Jimj
Great mod, just the way I like them, useful and cheap. I used a Bicycle break lever for the control. It has a built in cable adjuster and a longer control, for finer adjustments.
91YJ 2.5L ax5
Jimj is offline
post #6 of 7 Old 01-24-2008, 08:43 PM
Berb_15
Hey Jimj what is that piece of aluminum/metal you used to clamp the brake handle onto??
"Lock tite!!
Berb_15 is offline
post #7 of 7 Old 01-25-2008, 07:00 PM Thread Starter
YJames90
YJames90's Avatar
Yesterday leaving work it was 25 degrees. I didnt let the jeep warm up and drove down the road. The throttle wanted to stay open at arount 3000rpm once I got going until it warmed up a bit.
This didnt happen before the hand throttle. That morning i let the jeep warm up and there wasent a problem. Is this from the choke or idle sensor with extra tension from the hand throttle?
YJames90 is offline
Hand throttle yj35s YJ Wrangler Technical Forum 8 11-20-2008 06:03 PM
Hand throttle anyone? TJamz TJ Wrangler Technical Forum 6 12-19-2007 06:53 PM
Hand Throttle Install FlyersFan2009 TJ Wrangler Technical Forum 10 04-12-2005 04:38 PM
My hand throttle install (Pics) Sia YJ Wrangler Technical Forum 2 07-31-2003 06:42 PM
Hand Throttle Q's SpilledMilk TJ Wrangler Technical Forum 21 12-10-2002 07:52 AM
