My front shackle inverted while offroading - Page 2 - JeepForum.com
post #16 of 21 Old 03-13-2014, 11:06 AM
fratis
fratis's Avatar
Originally Posted by Norcal_chris View Post
But LOL at the "knows a lot about leaf suspension" and "double shackle" in the same sentence
This isnt a new technique. They do shackles at both ends and links. The spring at that point is only supplying elevation and the links do the locating of the axle.
Originally Posted by bpounds View Post
I don't know why you would want to modify your frame mounts. It'll then be screwed up for any off the shelf springs. Your problem is with those mystery springs. I suggest you leave the frame alone and pick up some quality springs from a respected manufacturer. In fact, I insist you do that!
He has off-the-self springs. Every lift kit spring, particularly in the 4" range, is too short. Have yet to see one fit a YJ properly and they all suffer from the vertical shackle syndrome.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #17 of 21 Old 03-13-2014, 11:27 AM
Norcal_chris
Norcal_chris's Avatar
I got the imression he was talking about this setup
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #18 of 21 Old 03-13-2014, 11:52 AM
bpounds
bpounds's Avatar
So all the engineered kits are wrong, and a few JF guys are right?
Got it.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,CRT HEI Ign,AX15 ext slave conversion, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #19 of 21 Old 03-13-2014, 12:52 PM Thread Starter
newfish1
I was. I knew it wasn't "new" technique, but had never seen it before. Moving the mount points won't inhibit the ability to mount "off the shelf" items, unless I did a shackle reversal with stock springs. That's how I see it, anyway.
newfish1 is offline
post #20 of 21 Old 03-13-2014, 11:06 PM
fratis
fratis's Avatar
Got it.
No its an economics thing. They take the same springs and put a larger arch in them. This makes them shorter from eye to eye. There are some companies that dont even make a spring larger then 2.5." No matter how it happens a shackle that is completely or near vertical is wrong.
fratis is offline
post #21 of 21 Old 03-24-2014, 08:12 PM Thread Starter
newfish1
Well, I finally made time to take a pic of the new front shackle(s) position. Mount points moved back approx. 3/4˝.
Also, when the springs were taken off, there were signs of wear in several spots across the #2 leaf, so the shop added pads to each end.
Jeep rides "softer" now and has less bump steer symptoms. For now, this will do for me. incidentally, I finally scored a decent set of stock YJ springs, for an SOA conversion in the future. I don't know if this will require moving the mount points back to "home", but I'm okay with that. SOA isn't in immediate future plans.
newfish1 is offline
