My front shackle inverted while offroading - JeepForum.com
post #1 of 21 Old 09-23-2013, 09:21 PM Thread Starter
newfish1
New to Jeeping, and looking for input:
Front (tow) shackles are basically perpendicular to the ground. In my uneducated mind, the lower end of the shackle should extend further (away from the jeep, towards the front) than the upper, thereby preventing inversion.
Maybe I need longer main leafs?
newfish1 is offline
post #2 of 21 Old 09-23-2013, 09:28 PM
Norcal_chris
Norcal_chris's Avatar
Turn the shackles around so the triangle is facing the rear of the jeep. Move the crosstie to the tip of the triangle if you dont have an extra bolt/sleeve. This will stop the inversion as it will hit the frame and stop it. Use them like a boomerang shackle, since that is basically what that is
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #3 of 21 Old 09-23-2013, 09:45 PM
timatoe
timatoe's Avatar
I'm not sure what your question is. Those shackles are designed that way to hook a tow bar to them. Are you getting inversion?
timatoe is offline
post #4 of 21 Old 09-23-2013, 11:34 PM
fratis
fratis's Avatar
This is a common problem with aftermarket springs. If it were mine I'd slide the front mount backwards. To eliminate the inversion and keep the shackles you have you can weld a small triangle of 1/4" steel to the frame mount as a stopper.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #5 of 21 Old 09-24-2013, 07:37 AM Thread Starter
newfish1
Thanks for the input. I like the idea of welding a stopper, as reversing the shackles would inhibit the ability to connect a tow bar from the center of the shackle.
@Timatoe, What I meant was- if there was a way to modify the springs or get a longer main leaf, this would theoretically force the front shackles to hang at approx. a 15 degree angle, with the bottom end protruding out, away from the front of the vehicle.
newfish1 is offline
post #6 of 21 Old 09-24-2013, 11:56 AM
vadslram
If you went with a longer leaf then on compression you would force the tow point of the triangle up into the frame/bumper and force the spring to S curve....bad juju
Best bet would be the stopper. It wouldn't even have to be that herky since the only force on it would be the axlle droop wieght.
vadslram is offline
post #7 of 21 Old 09-24-2013, 12:00 PM
vadslram
I bet you could market a "anti inversion tow shackle" basically instead of a triangle that you have now it would be square plates the front would connect to the tow like now and the back would act as a stop on the frame to prevent inversion
If you make millions I want a new old jeep for my idea
vadslram is offline
post #8 of 21 Old 09-24-2013, 01:18 PM Thread Starter
newfish1
That's a great idea. All of it…
newfish1 is offline
post #9 of 21 Old 03-12-2014, 08:51 PM Thread Starter
newfish1
Found what seems like a GREAT shop in Escondido, CA. Old school machinist and knows a LOT about leaf spring suspensions. There was already a red YJ in his shop- doing an SOA conversion with custom springs (must've been a 10 [thin leaf] pack; I didn't count) and double shackles. HUGE lift (way too much for my comfort). But whatever- The guy knows his stuff and was very helpful. Gave me a tour of his shop and his passion for the craft was obvious.
Wish i could afford an SOA conversion. What he's going to do for me to eliminate the shackle inversion is move the shackle mount points back, add shims (I know that isn't the right term) between a couple of the leafs, and buttons on leaf #3, as there currently aren't any. I didn't take "before" pics but will share the "after" pics when I get it back. You can see my current shackle position in the first post on this thread.
newfish1 is offline
post #10 of 21 Old 03-12-2014, 10:41 PM
Norcal_chris
A good amount of travel will come fron relocating the shackle mount a little back. You will be pleased.
But LOL at the "knows a lot about leaf suspension" and "double shackle" in the same sentence
post #11 of 21 Old 03-13-2014, 05:48 AM Thread Starter
newfish1
?? It wasn't.
newfish1 is offline
post #12 of 21 Old 03-13-2014, 09:04 AM
Dake
Dake's Avatar
What kind of 5in lift do you have?
Waiting on my Rough Country lift to sag!
Dake is offline
post #13 of 21 Old 03-13-2014, 09:25 AM Thread Starter
newfish1
I'm still new to this, and have owned this jeep for approx. 10 months. I THINK it's a 4" lift from the springs, and 1" from the taller shackles.
BTW, in my earlier post, when I used the term "double shackles"- I believe the proper term is "drop shackles".
newfish1 is offline
post #14 of 21 Old 03-13-2014, 09:32 AM
bpounds
bpounds's Avatar
I don't know why you would want to modify your frame mounts. It'll then be screwed up for any off the shelf springs. Your problem is with those mystery springs. I suggest you leave the frame alone and pick up some quality springs from a respected manufacturer. In fact, I insist you do that!
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1,GM HEI Ign, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline
post #15 of 21 Old 03-13-2014, 10:43 AM
Norcal_chris
When I had 4.5 RE extreme duty springs I moved my shackle hangar. It made a huge difference for the better
