my engine cries - JeepForum.com
post #1 of 2 Old 05-17-2001, 08:59 AM Thread Starter
jeromy
my engine cries
I just noticed a weird noise coming from my engine when I slow down.Sounds like a whinning cry while decelerating.So I cracked open my hood and checked my belts and that wasn't it,but is sounds real close to the pwr steering pump.This is really driving me nuts here.Can someone point me in the right direction.Thanks to all in advance
jeromy is offline
post #2 of 2 Old 05-17-2001, 06:20 PM
Tonka
2015 JK Wrangler
My idler pully caused a whine for a while, then started grinding. Replaced it, and solved the problem.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline
Engine code p1281, engine cold for too long....which temperature thermostat to use? ShadowLawz TJ Wrangler Technical Forum 11 11-25-2014 11:23 AM
Engine wont turn over, solenoid clicks, hammer tapping starter gets the engine turnin zpmada YJ Wrangler Technical Forum 26 08-16-2011 07:00 PM
Service engine light on!! Is it from H20 in radiator & engine coolant compartment?? chaznad TJ Wrangler Technical Forum 12 04-24-2005 08:57 PM
Check engine light and engine sthal after cleaning battery posts AirborneSilva TJ Wrangler Technical Forum 4 05-26-2003 11:43 PM
my engine cries jeromy YJ Wrangler Technical Forum 0 05-17-2001 08:59 AM
