Is My Clutch Going Out? - JeepForum.com
post #1 of 11 Old 03-25-2002, 11:45 PM Thread Starter
St.LJustin
St.LJustin's Avatar
What kinds of things are good indicators of whether or not my clutch is going out? For some reason, I have this strange feeling that it is acting strangely but I can't quite figure what it is. Thanks.
Black 95 4.0 YJ, RE Extreme Duty 4.5" with 33x12.5 BFG MTs and Much Much More
Member #5 of the Black Jeep Club
St.LJustin is offline
post #2 of 11 Old 03-26-2002, 07:05 AM
Atropine
Atropine's Avatar
um.. if you give it gas and have the clutch all the way out and your're not going anywhere but you smell burning clutch... Thats usually an indication that something is wrong.
93' YJ
00' TJ
02' KJ
04' Dodge Ram
"Jeep mechanic wanted: must be able to put square peg in round hole"
Atropine is offline
post #3 of 11 Old 03-26-2002, 08:23 AM
Bob K
Bob K's Avatar
Or difficult to shift into first or reverse without grinding, or clutch engaging at end of travel. The test is to get into 4th or 5th gear at about 25 mph try to accelerate. If the revs go up without the Jeep accelerating as it should then your clutch is slipping . There's a chance it is the hydraulics or linkage, but not so likely.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #4 of 11 Old 03-26-2002, 10:25 AM
JeepBeep
Doh....That's me Bob K.....First is hard to get into, just physically hard to push it in, and I can get into reverse without it grinding by pressing the accelerator slightly.
'01 XJ BONE STOCK (Not for Looong)
'95 YJ 2.5L 3" Sus.
ProComp MT 33s"
JeepBeep is offline
post #5 of 11 Old 03-26-2002, 11:11 AM
LNDSRK
I had a similar problem late last year... I couldn't shift into 1st gear, at least not all the time. Downshifting was a terror on the ears as well (I would grind in 1st and 3rd), 2nd / 4th / 5th were alright though.
1995 YJ - Some mods...with more to come (Just Emptied Every Pocket)
LNDSRK is offline
post #6 of 11 Old 03-26-2002, 12:28 PM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
go up a hill, and if it slips and revs up and ur not going anywhere. THis is the start, you might not be able to tell going on flat land
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #7 of 11 Old 03-26-2002, 01:21 PM
sk8pr0
JeepBeep: I had the same problem. check your fluid level for the clutch. It is probably the hydraulic throwout bearing. At least that is what I had to do when I couldn't get it into first. It is a good idea to replace the clutch and the pressure plate at the same time as the throwout bearing, if that is what needs to be done. Hope this helps, if you have any questions post here or email me @ sk8pr0@onebox.com
Hope this helps
Red 93 YJ
30/9.5" tires
Lift and Lock soon (just need the $)
sk8pr0 is offline
post #8 of 11 Old 03-26-2002, 04:13 PM Thread Starter
St.LJustin
St.LJustin's Avatar
Thanks guys and girls. I guess it's just me loving my Jeep.
post #9 of 11 Old 03-26-2002, 08:52 PM
Keymaster
Keymaster's Avatar
Definately check your fluid level. I had this problem when I first got my Jeep. If the fluid level gets too low you'll suck air into your lines and even if you fill the master cylinder back up it won't fix it. You'll have to bleed the system and refill it. It takes two folks to do it but my dad and I did it in about 15 minutes. I think I still have a slow leak on mine somewhere but I check it about once every couple of weeks to make sure it doesn't get too low and it has been fine for the last year.
1997 F-150
2000 Ford Explorer
Looking for a YJ!
Keymaster is offline
post #10 of 11 Old 03-27-2002, 01:03 AM
BigDaddESean
I noticed mine was low a few weeks ago. My friend said "dude it should never go low unless there is something wrong." But eventhough I know that, my pig headed self shrugs it off and keeps driving. Then I fill it up, and a couple of days later out of nowhere poof I have no clutch pressure. When i fill it, i can pump it three times and all the fluid is out again. So now time to drop the tranny and replace the slave. I'll check out everything else while it's out. <a href="http://hometown.aol.com/goofy2k8" target="_blank">Sean's Jeep Page</a>
89YJ. '97 4.0HO, 4" lift, 33" General Grabbers, Header, no cat, glasspack AR rims
BigDaddESean is offline
post #11 of 11 Old 03-27-2002, 11:13 AM
sk8pr0
Well good luck, and like I think I said before. Most books that you look at will tell you to replace clutch and pressure plate while the tranny is out. I would highly suggest that, because it is better to drop it once and fix it all rather than have to do it again in a few thousand miles. Just my opinion.
Red 93 YJ
30/9.5" tires
sk8pr0 is offline
TJ AX-15 is difficult to shift! Replace clutch, clutch & rebuild, or just suck it up! NORCALROOTS TJ Wrangler Technical Forum 38 12-12-2015 10:07 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 01:39 PM
clutch whirrring/squealing noise - but stops when I press on clutch dirtyjpwrangler JK Wrangler Technical Forum 12 09-28-2009 09:55 PM
Question about destroying clutch plate WITH CLUTCH PEDAL DEPRESSED JeffB TJ Wrangler Technical Forum 12 07-20-2009 11:29 AM
great! More AX5 Clutch problems!!!!! hooray for internal clutch slave cylinders! Big-n-Broke-YJ YJ Wrangler Technical Forum 6 08-19-2008 03:14 PM
