My build thread.:) - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My build thread.:)
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 06-05-2008, 11:41 AM   #31
Douglas S.
I feel your pain (though it wasn't as bad)
I went from this
to this
to this
Don't have a finished pic of the drivers side, but you get the idea
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S, Lightforce 240's, OME 2.5", 34" Toyo MT's, OEM Snorkel
1987 YJ Laredo
Douglas S. is offline   Reply With Quote
Unread 06-12-2008, 02:40 PM   #32
ImportEater
Well its been abit and Im still working on the rust. Lots and lots of rust. After this build I never want to see rust again. But Im a realist and no that I will be overjoyed when my next rust adventure. (place sarcasim here)
I have discovered my frame only has 3 dime shaped holes. Easy fix. The only rust issues Im concerned with are the small hole in the frame in the rear shock mount perch. Not a big hole, but its going to be fun fixing.
I started grinding all the rust off with my trusty 4 1/2" grinder and wire wheel. I stopped today and thought, HF has a bunch of different snad blasters for under $100, so Im ordering one. Ill use my buddies air comp and get this really going. Ill only need it for this project and figure Ill sell it after and get most of my money back from it.
Heres some more pics from last weekend and today...
ImportEater is offline   Reply With Quote
Unread 06-12-2008, 02:43 PM   #33
ImportEater
And some more...
Unread 06-12-2008, 02:50 PM   #34
ImportEater
And some more...
Think I need a new exhuast???
I thought my passanger half door was trashed, had some rust rot, like everything else.
I cut the old rust out and discovered I dont need new doors. Yippy!
My old seats, green and tan. I need to sell these and get some black ones...
Another shot of the paint.
Ill post some more pics in afew days.
Thanks for looking.
Unread 06-13-2008, 12:57 PM   #35
ImportEater
You know you wanna comment on this, dont cha? Give me some advice or critizism...
What do you all think???
Unread 06-13-2008, 04:28 PM   #36
ZIMSJEEP
Good luck man, that looks like a lot of work. A bunch of guys on here I had my doubts about in the begining and they turned out great (see The Boxmans thread)
Not to be a total buzzkill and all but painting the rollbar and hood latch would be the least of my worries at this point.
I think you're heading in the right direction now going with the sand blaster and grinding all that sh*t off your frame and body. Just take your time and get as much of it off as you can. Don't rush and you'll more then likely be happy with the finished product.
3.5" Fabtech lift, 5/8" MORE Boomerang Shackles, Brown Dog Motor Mounts, 33x12.5 Mikey Thompson Baja Claws, MT 15x8 Classic II Alloys, JKS swaybar disco's, Rancho RS 5000 stablizer, Skyjacker Hydro 7000 shocks, Warn Bumper w/ pre runner, On board air, Grant Wheel, PIAA Windshield mounted lights, Herculined Interior
ZIMSJEEP is offline   Reply With Quote
Unread 06-13-2008, 07:19 PM   #37
ImportEater
Thanks zimsjeep. I jumped on the roll bar and hood latch to see if this is the paint scheme I really want. I figure see it on alittle stuff and it should give me an idea of what Ill be looking at when done. I agree about not jumping ahead of myself and all.
I have read boxmans thread and several others. The only reason I even thought to tackle this beast was their insperation from their builds. I have never done anything like this before, but this wont be my last time either. Im really liking this stuff.
Well today I removed all the hard fuel lines from the frame rail and the hard brake line to the rear, also the e brake cable. Started to drop the gas tank, (stock poly 20 gallon tank) and realized it was topped off. What fun! Also removed the fuel reg and the skid for it on the bake of the frame.
Found afew more small holes in the frame. Around the rear crossmember and both rear shock mounts. Not bad or anything, but more to fix.
Ill get some more pics tomorrow when I remove the gas tank and rest of the exhuast system. Still have on the cat to the header. Which also needs to be replaced.
I love Jeeps.
Unread 06-13-2008, 09:41 PM   #38
Matt Graham
Originally Posted by ImportEater View Post
I love Jeeps.
It's a good thing you do! No but really though, it'll all be worth it when you finish and you'll be so proud of it. Keep up the good work & keep the pictures coming. . . .
2001 TJ 60th Anniv. Ed., Silver, I6 4.0, Auto, 3.25" RC Progressive Suspension lift, JKS 1.25" BL, JKS 1" MML, JK wheels (17" x 7.5") & 255/75/17 Goodyear Wranglers (32 x 10.04), SB Front bumper & rock sliders, but saving to replace them w/ Poison Spyder, H4 headlights, LED guages & interior lights.....
Matt Graham is offline   Reply With Quote
Unread 06-14-2008, 04:57 PM   #39
ImportEater
Well today I removed the gas tank and the gas tank skid. Fun times with a full tank.
Next Im going to yank off the track bars and sway bar. Then the rear driveshaft. (Have to change my tcase rear oil seal and bushing)
Then Ill start cleaning up the rear of the frame. May need a new rear crossmember. Not 100% sure but it looks about beat.Im sure with enough grinding Ill get it cleaned up, but not sure on how trustworthy itll be.
Also going to finish removing the rear ebrake cables. The passanger side cable got all chewed up so I guess Ill just replace everything from the cab back. More money to spend.
By the time this rig is done I think itll be pretty much better than from the factory. Im going through everything and replacing whats in need and changing simple stuff that THEY couldnt do from the gate.
Ill go outside and get some more pics to post, I know you guys are like crack addicts for pics.
(so am I.)
Unread 06-14-2008, 06:00 PM   #40
durangoyj
I admire your dedication. There are plenty of guys on here that have worked with the same as you and have come out with a nice jeep. Good luck and anxious to see more pics!
Colorado Jeep Club Member # 176
\m/(..)\m/ "Rock on!"
durangoyj is offline   Reply With Quote
Unread 06-14-2008, 06:41 PM   #41
ImportEater
Thanks for the kind words. Its my first attempt at anything this major. So far its been a blast.
More pics? We dont need no stinking pics... Oh, wait, yes we do.
Here's the gas tank removed...
The removed fuel lines...
Rear passenger section of the frame...
Gas tank skid...
Unread 06-14-2008, 06:48 PM   #42
ImportEater
Chewed up passenger side rear ebrake cabel...
Fuel reg and skid...
Rear hard brakeline, and the rear shock mount hole... Yippy! Driverside.
Rear shock mount rust hole... Passenger side.
Unread 06-14-2008, 06:57 PM   #43
ImportEater
Very small (dime size) rust hole in pass side frame rail. Easy fix.
My very first fix on my Yj, when I was leaking gas everywhere...
Gas tank skid straps...
Rear driveshaft...
This is my leaky tcase rear oil seal...
Front driveshaft,greaseable...
I have 2 rust holes in the front of the frame, on the pass side by the shackle location...
Since the front of the frame is already rusted, Ill cut this whole section off and replace it with nice fresh metal...
Unread 06-14-2008, 06:59 PM   #44
ImportEater
The tcase andd whats left of the exhaust system, to be ripped out tomorrow...
The grill all cleaned up, afew small problem areas. Going to fix with fiberglass and body filler...
Stay tuned, more to follow later...
(Gee I hope I remember how to put this $%$@%$ back together...)
Unread 06-15-2008, 07:26 AM   #45
tazzzdvil
1987 YJ Wrangler
After this, I'm so glad the old body of mine is scrap.
Btw how's your HF sandblaster working out? I thought about one, but they all seemed to have huge air consumption that my lil pancake wouldn't keep up with.
tazzzdvil is offline   Reply With Quote
