My brakes suck! help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My brakes suck! help
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 06-05-2009, 05:24 AM   #1
bcameron1974
My90 yj brakes suck...They stop in all but there not that great. I looked at front pads and there in good shape..Thats all I really know...Where do I start and all that..I was goin try to bleed the brakes to see if they just need bled but there kinda rusty didnt wanna break the line. I have 33s on it also there not quite as good even tho they sucked on 31s..should i try putting new rears on..they also act diff when there wet..they stop real quick..
If im goin kinda fast and wanna slow down quick they pull some so I have to pump and there just not quite as comfy as a nwer vehicle where they stop smoothly..
my build thread.http://www.jeepforum.com/forum/f12/my-sahara-rebuild-thread-1990-a-784008/1990 YJ 4.2 nuttered-mc2150-team rush-4 inch RC-1.5''-Shackles-1 1/2''-15x10 American Racing Atlas Wheels-33x15x12.50 Goodyear A/T-Hella Offroad Winshield Lights-Black Met/Gold Paint -Custom Gold Decals
bcameron1974 is offline   Reply With Quote
Unread 06-05-2009, 05:36 AM   #2
ExNeph
Did you check the rear pads at all? Take the tires off and see if there's any buildup of brake dust or rust on the rotor. If they work a little bit better when wet, that would be my thought as to why. As for not stopping smoothly.. I'm running 31's, and they're nowhere near as stiff as the brakes in my father's Dodge Ram. I literally have to push my foot to the floor if I have to stop pretty quick. Which brings up another little question that I'm unsure of: Do YJ's have ABS?
Before you bleed the lines, check if the fluid is good. Personally, I'd just keep a good stopping distance in mind. I don't think if you're running anything bigger than a 31 that you should try and quick stop.
Jeep owned for over 1 year.
Parts broken/blown up: Engine, clutch, transmission synchros, wheel joint, wheel bearing, front driveshaft u-joints, front shaft oil seal, radiator, water pump, belt, passenger door latch, cat-back exhaust system, front fender flares, front axle seal, transfer case output seal, rear driveshaft u-joints, parking brake..
ExNeph is offline   Reply With Quote
Unread 06-05-2009, 06:24 AM   #3
BPJOOP93
My brakes suck too. just the nature of the beast i guess. and no yjs do not have abs to my knowledge, just tjs.
BPJOOP93 is offline   Reply With Quote
Unread 06-05-2009, 06:26 AM   #4
TJMunky
my TJ doesnt have ABS. my brakes suck too. 5 set of lifetime pads from the dealership going ceramic on sunday. the metallic pads keep shattering so new rotors too.
NIGHTCREW (RIP 01/28/09 - 07/22/09) #135
SILVER JEEP CLUB #120
TJMunky is offline   Reply With Quote
Unread 06-05-2009, 06:28 AM   #5
shockwave562
2009 JK Wrangler
now you know what a YJ is like. I remember I replaced my master cylinder, drums, brake pads, everything and still that thing couldn't stop for anything. fortunately I had a 2.5 so it was slow enough that I didn't hurt anyone.
I don't think the TJ was much better to be honest. I know on the JK they finally made the brake caliper bigger to get more stopping power.
'09 JK Rubicon
'01 TJ Sport
'08 JK Sahara
'99 WJ Laredo
'94 YJ SE
Join our Colorado Jeep Club on facebook:
[url]http://www.facebook.com/home.php#/group.php?gid=55632382649&ref=ts[/url]
shockwave562 is offline   Reply With Quote
Unread 06-05-2009, 07:08 AM   #6
bcameron1974
well not really betteer when wet..but if u hit the breaks and it rained before it will slam the breaks on..It will only do this for maybe 5 min then after that back to normal..
my build thread.http://www.jeepforum.com/forum/showthread.php?t=7840081990 YJ 4.2 nuttered-mc2150-team rush-4 inch RC-1.5''-Shackles-1 1/2''-15x10 American Racing Atlas Wheels-33x15x12.50 Goodyear A/T-Hella Offroad Winshield Lights-Black Met/Gold Paint -Custom Gold Decals
Unread 06-05-2009, 07:50 AM   #7
Old4X
1990 CJ7
It is a physics problem. The larger the diameter of your tires, the less braking power you have.
If you want top braking power, go back to 215-75-15s. Or put 3/4 ton axles and brakes under your YJ.
Carter BBD feeding 4.2 Nuttered 6 banger = 22 MPG Hwy
If it was easy, everyone would be doing it.
Old4X is offline   Reply With Quote
Unread 06-05-2009, 08:52 AM   #8
bryris
The 1995 saharas have ABS. Mine does anyhow.
1995 YJ Sahara
bryris is offline   Reply With Quote
Unread 06-05-2009, 09:13 AM   #9
BadAddetude
Some YJs had it, some dont. My 95 Sahara doesn't. It was a buyer option.
Perhaps if your brakes are very weak, look into replacing your MC/Booster. If you haven't already. I had a MC that was leaking into the booster, which filled it with fluid, making the pedal spongy. New MC and got all the fluid from the booster, and I noticed a bit of a difference.
Or, get an anchor and some rope...
1995 YJ: 4.0, 700R4, 231 C/J case, TeraFlex SS SYE/CV shaft, 8.8 with 3.73 gears, 136 Amp Alternator, Trans Cooler, Pavement Ends Flip-top/H-T, 2'' BDS Suspension Lift, MORE 5/8' Greasables, Sony GT-210 Xplode Head.
Under the Knife! See the build thread: http://www.jeepforum.com/forum/f12/badaddetudes-build-project-hrp-602142/
BadAddetude is offline   Reply With Quote
Unread 06-05-2009, 09:18 AM   #10
northjeep
Jeep parking ONLY
northjeep's Avatar
33's are no problem for me...all four corners will lock up if I need them to...on pavement, or ice.
Now this is to all of you who've posted saying something like "welcome to the yj" or "only the jk have good brakes". YOU HAVE SOMETHING WRONG WITH YOUR BRAKING SYSTEMS.
Honestly, there's no physical reason to say the stock calipers and rotors IN GOOD WORKING ORDER won't lock up the fronts...
The rears don't normally do very much in the first place...until you apply enough brake force to overcome the proportioning valve...then they really kick in.
So for all you folks who are thinking there's nothing you can do... I say WTF...give it another try.
Safety Safety Safety.
Yes larger tires will demand increased brake force for the same rotor/drum size.
I dunno maybe I'm just really particular when it comes to rebuilding my brakes...but I never have had a problem locking them all up. In fact I locked up on dry pavement so hard once that I popped a steel line. 'm kinda glad I did...kuz that was just one more weak link gone...
Anyway, I can offer more to the OP here....My guess is that (among other things) the rubber lines are giving.
There are 3 stock, 2 front and 1 rear as I recall. Replace or upgrade to braided stainless (I run stainless in the front, made the pedal stiffer).
Good luck
-NorthJeep - >> Just Enough Essential Parts
RED Jeep Club member - YJ Club - 258's Unite
northjeep is offline   Reply With Quote
Unread 06-05-2009, 09:30 AM   #11
jbolty
ISO 9001 Compliant
jbolty's Avatar
If it has not been done already replace all the hard lines. They are might be rusty and gunked up plus it's a good chance to replace all the fluid. Made a noticable difference for me.
There is no good reason to mess around diagnosing brake problems. the parts are cheap enough to just replace everything. wheel cylinders, calipers, springs, pads, shoes, drums and lines can all be swapped for ~$200-$300
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Unread 06-05-2009, 07:28 PM   #12
laybackman
laybackman's Avatar
My first guess would be that the rear brake shoes that are 'self adjusting' aren't self adjusting. So your front discs are doing all the work. Even if the rear shoes are good, my guess is that the rear adjusters are frozen. I have never seen anyone who does brakes professionally every take the rear adjusters apart during a brake job and clean the threads on the self adjusters then lube them with never seize.
Getting brakes to lock up only puts you into slide mode. With 33's you need more square inches of brake surface on each corner of your Jeep and I strongly suggest disc brakes front and rear.
Life is like a coin. You can spend it any way you wish...but you can only spend it once.
"If we cannot afford to take care of Veterans, then we should stop making them."
David C. Wilker Jr. USAF (RET)
laybackman is offline   Reply With Quote
Unread 06-05-2009, 07:37 PM   #13
Luckyduck
The brakes in my TJ were terrible till I redid them. I put in new pads and I turned the rotors myself (front only). now the jeep stops on a dime
If I can get there I can wheel it!
CentralMass4wd.com
1993 Ranger 2wd - dd
1999 wranger 2.5 - it gets used for something
1978 international scout - being built
1998 Cherokee sport 4.0 auto
1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/showt...54#post5168554
Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900
my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/
Luckyduck is offline   Reply With Quote
Unread 06-05-2009, 08:55 PM   #14
4.7stroker
Just install a dual diaphram booster and they will not suck any more.
Dwayne
4.7stroker is offline   Reply With Quote
Unread 06-06-2009, 04:07 AM   #15
Joe Dillard
Electric Chair Operator
I was way overdue to upgrade my brakes. I did change a few minor things, but in the end, this is what I did (Vanco big brake kit, plus duel diaphram booster & matching master). This doesn't come cheep, but I wanted to completely solve my marginal brake system with something that provides superior results.
12" rotors:
48MM duel piston calipers & ECB yellow pads (pads not shown)
New knuckles with mounting brackets for the new calipers & master cylinder:
Booster:
Joe Dillard is offline   Reply With Quote
