my 95 yj is neutral when in fifth gear - JeepForum.com
post #1 of 6 Old 07-23-2011, 03:45 PM Thread Starter
yoyoyo109
2015 JK Wrangler
Today while driving on the freeway, my jeep all of a sudden heavily lurched while in fifth gear. When I released the clutch its almost as if the gear is gone because the engine just revs, no acceleration. What happened and how do I fix it?
Its a manual 6cyl 95 yj
Any help would be appreciated
yoyoyo109 is offline
post #2 of 6 Old 07-23-2011, 04:26 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
http://www.jeepforum.com/forum/f12/a...emoval-908252/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 07-24-2011, 01:23 PM Thread Starter
yoyoyo109
2015 JK Wrangler
Are the ax5 and ax15 transmissions the same fix? I drive a 6cyl 95 so its paired with the ax15
post #4 of 6 Old 07-24-2011, 01:53 PM
Mark05059
they are the same fix
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 6 Old 07-24-2011, 03:36 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
They would indeed have the same fix, if that's the issue.
I have never seen it happen to an AX-15, but it is certainly possible.
Max
Mean Max is offline
post #6 of 6 Old 09-27-2011, 11:08 PM Thread Starter
yoyoyo109
2015 JK Wrangler
To wrap this thread up, it's a bit late but it turned out my gear completely sheared off and since then i have had it rebuilt and its good as new
engine , gears , transmission
gear shifter stuck in neutral ax-15 angryjohnny TJ Wrangler Technical Forum 6 06-19-2014 09:29 PM
Gear shift hard to move in neutral when hot spshultz YJ Wrangler Technical Forum 15 02-02-2013 11:02 PM
Wont shift into gear from neutral? Duncan71 YJ Wrangler Technical Forum 0 01-19-2009 06:56 PM
5 gear a neutral? 1bad92yj YJ Wrangler Technical Forum 7 06-03-2008 06:49 PM
Loud gear chatter in neutral... help! SmithersGS TJ Wrangler Technical Forum 9 10-25-2004 08:34 AM
