My 94 YJ Power Steering Conversion - JeepForum.com
post #1 of 56 Old 06-10-2013, 10:57 PM Thread Starter
94_Yeti
I'm new here guys and gals so let me introduce myself. Excited to get in with the community, you guys seem to have a nice one. I'll get right to it. Bought a Jeep that seems to be most of the way there but I'm finding the deeper I dig the more I realize this is a 20 yr old vehicle and that most people probably don't take care of their rigs in quite the same OCD manner that I do (not that I don't understand what Jeeps are for ) . Either way, the first thing that caught my attention on the drive home was that there was an excessive amount of play in the steering wheel and that it was pretty hard to steer, especially at lower speeds. Come to find out, it doesn't have power steering. I know understand that this was fairly common but was surprised nonetheless. So first project will be just this. Replacing the steering box and adding power steering. Hopefully Ill figure out how to upload these pictures. I went the the JY and got the steering box off of a 1996 Grand Cherokee and a pump/ pulley they happened to have on the shelf. Also got the hoses and a few brackets. I was hoping I could kind of use this thread to keep track of my own progress and get some advise from as many of you as possible who may have some insight. So here goes..
94_Yeti is offline
post #2 of 56 Old 06-11-2013, 07:50 AM Thread Starter
94_Yeti
Going to the yard today to get a new reservoir. Anyone know if I need a new belt? Also, still not sure what I have to do to get the old pump off (which I guess is just the manual steering pump???) and put the new one on. Don't have a tension meter and never messed with pulley's. Any ideas? More pics to come later today.
94_Yeti is offline
post #3 of 56 Old 06-11-2013, 08:18 AM
crackedcornish
there is no pump involved in a manual steering set up
fill out your Jeep profile so we all know what you have...it's easier for us to help you out that way
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #4 of 56 Old 06-11-2013, 08:55 AM
Lemoore-on
That is an idler, and you dont need a tension meter, the serpintine belt has pre-set tensioner, and yes you will need a belt for you model with power steering.
Mike
92YJ with some stuff done to it.
Lemoore-on is offline
post #5 of 56 Old 06-11-2013, 04:40 PM
PA_YJ19
I think they sold u the wrong pump. That pumps looks to be the type that matches up to the 99+ intake manifold on the newer 4.0s. If the bolt holes in the pump itself do not have threads then its not the pump u want. U need a pump from a 98 or down 4.0 as they had threads in the holes and bolt to a bracket that connects to the manifold. Where as the one u have has holes and the bolts slide threw the holes and screw directly into the newer style of manifold.
PA_YJ19 is offline
post #6 of 56 Old 06-11-2013, 08:20 PM
caoboy
Do you have a 2.5 or a 4.0. There is a big difference in the way the pumps are setup. 4.0 has a built in reservoir on the pump. 2.5 has a remote reservoir. You'll need the right pump.
You will need a new belt, for one with PS.
You'll need the right size lines (length) that correspond with the 4.0 or 2.5
caoboy is offline
post #7 of 56 Old 06-11-2013, 08:50 PM
PA_YJ19
4.0 and 2.5 use the exact same pump, regardless if the resevoir is remote or attached. They r both the same pump. Only thing that has ever changed is the mounting of it is diff on 99+ due to the manifold change.
PA_YJ19 is offline
post #8 of 56 Old 06-11-2013, 09:52 PM
caoboy
The OP still can't use a pump with an attached reservoir if he has a 2.5L.
caoboy is offline
post #9 of 56 Old 06-12-2013, 06:37 AM
crackedcornish
my '88 2.5L has a power steering pump with an attached reservoir
post #10 of 56 Old 06-12-2013, 09:20 AM
caoboy
Oh that's right. The mpfi manifolds won't fit the pump with the built in reservoir.
caoboy is offline
post #11 of 56 Old 06-12-2013, 08:26 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
It looks like the right pump to me.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #12 of 56 Old 06-14-2013, 11:23 PM Thread Starter
94_Yeti
Took a few pics today lets see if I can do this right.....
So I think I've got everything I need. I understand that I'll need to have my hoses remanufactured as I don't think they'll work as is. I guess my big question to you guys is whether or not that pulley on that ps pump looks a little big. I think compared to the one that is on there now it seems like I may have a problem getting the bigger one on. Also does that affect to rate at which that belt is turning is that going to screw with other stuff on the engine?? Advice appreciated. ALso if you guys think Im missing something please feel free to chime in. I still feel like im going in fairly blind on actually attaching the pump to the block in place of the (idler??)....
94_Yeti is offline
post #13 of 56 Old 06-14-2013, 11:25 PM Thread Starter
94_Yeti
I've got a gear box and lines from a 96' grand cherokee and a pump off the shelf that they said would match to the YJ's. The reservoir is just a remote res I found at the JY from an 07 wrangler 4 door.
94_Yeti is offline
post #14 of 56 Old 06-15-2013, 12:57 AM Thread Starter
94_Yeti
bumpity bump..
94_Yeti is offline
post #15 of 56 Old 06-15-2013, 07:21 AM
Mr.B
Mr.B's Avatar
I guess I should have read your post closer. The pulley looks fine, but are you sure the pump will mount up? Here is what my pulley looks like.
If it fits, you will need a new belt. And I'm pretty sure you will need new hoses, designed to fit your engine configuration. I do like the reservoir. Much nicer than my Volvo reservoir.
Ham license:
Everyone is Welcome
Mr.B is offline
