My 89' YJ is missing something.......... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > My 89' YJ is missing something..........
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 07-31-2013, 10:19 AM   #1
joespanova
The previous owner ( which one who knows ) decided to remove some device which is near the battery with about 8 wires ( which are now connected to nothing ). These wires are coming from the main wiring harness in the plastic sleeve.
What WAS mounted here? Anyone have a clue . The 2 relays (?) are still mounted next to the battery , but apparently there was something else electrical , mounted near the battery?
joespanova is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 10:29 AM   #2
bpounds
bpounds's Avatar
If it's on the outer side of the battery, that might be the diagnostic connectors which are missing. No big loss there, since they are not OBD anyway.
On the firewall toward the engine side of the battery, the starter solenoid has a bunch of wires connected to it, but I don't see how that could be missing.
bpounds is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 12:36 PM   #3
jbrown73
pic?
jbrown73 is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 03:01 PM   #4
jsipe007
Pics would help. If it runs fine, my guess is that it is the diagnostic plug as bpounds suggested.
jsipe007 is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 03:19 PM   #5
Rproject
1987 YJ Wrangler
OP, what do you think is missing? Here are a few pics of the same area in my '87.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline   Reply With Quote Quick reply to this message
Unread 07-31-2013, 03:32 PM   #6
bpounds
bpounds's Avatar
Perfect pictures. Those yellow caps are what I was referring to. As I understand it, those are not OBD anything. But they are diagnostic, and various sensor voltages can be read directly there. That's why I said no big loss if you don't have those connectors, but you would want to be sure that the remaining wires cannot short out on something.
Unread 07-31-2013, 03:53 PM   #7
joespanova
OK , sorry I took so long to get back...I'll get pics later if ness.
The connectors with the caps , as shown in the pics , are there and still wired as OEM. The OTHER pair ( black in the pic ) are NOT. This bundle of 8 wires w/ spade terminals has 1 ( or poss. 2 ) heavy red wires and its evident that one of them got hot ( shorted ) at some point. These wires all come out at the same point as the "diagnostic terminals?" with the caps removed in pic.
Unread 07-31-2013, 04:06 PM   #8
Rproject
1987 YJ Wrangler
So, OP, what you're saying is that these two relays are not present in your engine bay?
1996 White ZJ
Unread 07-31-2013, 04:10 PM   #9
Rproject
1987 YJ Wrangler
If that's the case, look at this thread: http://www.jeepforum.com/forum/f12/plug-does-1522824/
You'll see that one of the relays is the fuel pump relay!!!
1996 White ZJ
Unread 07-31-2013, 04:16 PM   #10
bpounds
bpounds's Avatar
Fuel pump is mechanical. But that thread is a good one anyway, and it appears those relays would be 1) manifold heater relay and 2) idle speed up relay. Jeep would run fine without those, but I can't guess why someone removed them.
Unread 07-31-2013, 04:19 PM   #11
Rproject
1987 YJ Wrangler
You're right. I don't know what I was looking at. One too many hits with the snake, as the Genie once said.
1996 White ZJ
Unread 07-31-2013, 06:51 PM   #12
joespanova
Correct
Unread 07-31-2013, 06:56 PM   #13
joespanova
Thanks ....I like it!
Unread 07-31-2013, 10:39 PM   #14
Anticanman
RIP one good jeeper
Anticanman's Avatar
Aladdin reference. Love it.
Luck Favours The Prepared
Anticanman is offline   Reply With Quote Quick reply to this message
