My 88 YJ rides like a rock! - JeepForum.com
post #1 of 19 Old 03-20-2013, 10:54 PM Thread Starter
Helo425
My 88 YJ rides extremely rough. I installed new Sky Jacker softride shocks but that only improved the ride slightly. I suspect that the leaf springs are not stock or possibly shot. How can I troubleshoot this?
Helo425 is offline
post #2 of 19 Old 03-21-2013, 04:59 PM
jbolty
jbolty's Avatar
http://www.jeepforum.com/forum/f6/ne...forum-1426268/
jbolty is offline
post #3 of 19 Old 03-21-2013, 09:58 PM
jojojeep1
mine ran hard also 33 by 12.5 i took the air down to 20 pounds its like night and day, rember they say 35 pounds but thats on a 7000 lb truck our jeeps are light trucks so 20 pounds wont hurt.
jojojeep1 is offline
post #4 of 19 Old 03-21-2013, 10:25 PM
demonz0
Some lifts, add a leaf springs can just be rough like a wagon. Tire pressure is massive as I've learned recently. 20 psi to 45 psi it was just nasty. That'll shake the living crap out of you.
99 Cherokee 4.0L | 4.5in Lift | 33x12.5
94 YJ 4.0L | 4in RC Lift | 33x12.5
demonz0 is offline
post #5 of 19 Old 03-22-2013, 01:19 AM
NonRubicon
Trac bars. If you have them on, try riding with them removed.
NonRubicon is offline
post #6 of 19 Old 03-22-2013, 06:14 AM
JST42LN
Check the spring mount bolts. when I bought mine PO had used an air inpact to tighten them. there is a turqe spec. that and air preassure.
89 YJ 4.0L stroked, 4" springs, auto,35's, custom front and rear fenders
95 ZJ 5.2L 3.5 IRO 31's
JST42LN is offline
post #7 of 19 Old 04-03-2013, 11:08 PM Thread Starter
Helo425
Thanks folks!I did lower the tire pressure but I don't think I went low enough, I'll try some more. I did discover one thing the other day, I was hauling some sound equipment for our band (3 good sized amps and some other misc sound gear) and what a difference some weight in the back made! I thought I might throw some sand bags in the back unless somebody has a better solution.
Helo425 is offline
post #8 of 19 Old 04-03-2013, 11:38 PM
rambo3489
I say your leafs are poo poo. There's a big difference between cheap and quality springs in terms of ride comfort and performance.
Sent from my phone because I'm doing something "more important"
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #9 of 19 Old 04-03-2013, 11:54 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
Look through these threads. You shouldn't have to under-inflate your tires to get an acceptable ride. I run 25 to 28 lbs.
https://www.google.com/search?q=jeep...w=1366&bih=643
Post a pic of your current suspension so we can see your set up.
Using sandbags to correct a bad suspension? I'm not sure I like that idea!
Either your stock springs are wheezed or someone bought el-cheapo junk springs.
GET OFF MY LAWN!
Chrisnvegas is online now
post #10 of 19 Old 04-04-2013, 12:24 AM
SnowdogMarc
X2^ I run 28 psi in my 33X12.5's and I can go over RR tracks at 40k and not even feel them....the crossings not Dukes of Hazzard style LOL.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #11 of 19 Old 04-04-2013, 07:27 AM
Siva283
Wow you have one fast Jeep
Ask me how I know...
Siva283 is offline
post #12 of 19 Old 04-04-2013, 08:53 AM
HaskiE
HaskiE's Avatar
x2 this made it much better for me too
#theneverendingaxe
HaskiE is offline
post #13 of 19 Old 04-04-2013, 11:13 AM
dukeryder
It's gotta be your leaf springs, I had some Superlift Springs on my '66 CJ5, I was running 32"s and tried all kinds of tire pressures, loosened all shackle bolts to 35 ft/lbs, greased everything and even put on on some Rancho RS9000 set to the softest settings and the ride OFF ROAD was still unbearable. The ride was so rough a kidney belt was almost needed!
I'm running BDS springs on my YJ now with the BDS Shocks and the ride is much better than the old CJ with those crap lift springs. In the future I'm planning on swapping out the BDS shocks for some Bilstein 5100s for an even better ride.
dukeryder is offline
post #14 of 19 Old 04-04-2013, 12:02 PM
pasinbuy
Again, track bars will give you the buck board ride. Take both off and you will be happy.
pasinbuy is offline
post #15 of 19 Old 04-04-2013, 12:42 PM
JakeMurray24
It could be lots of things.. Main thing being its a YJ. Loosten and re torque your spring bolts to the proper ft/lb, could grease them while your at it, tire pressure is also a big thing. In my 33" goodyear mtr/k i have 19psi which was decided after many chalk tests, shocks i find dont play much part in ride on leafs
and Ditch the track bars, and sway bar like Pasinbuy said! they are both useless.
1989 YJ Candy apple Green, D30front, 8.8rear, 4:10's, Lock right front, 4"RC springs rear, 3.5"BDS springs front, SYE with double cardian shaft custom made, home made rockers, 33" goodyear mtr/k, smittybilt stinger, home made light bar, marine stereo, cobreau baja jp seats
JakeMurray24 is offline
