My 88 Jeep snorkel setup - Page 3 - JeepForum.com
post #31 of 44 Old 01-13-2007, 07:10 PM
Daniel-YJ
looks good!
greetings from germany
Daniel-YJ is offline
post #32 of 44 Old 02-04-2007, 10:01 AM
Weekender1969
I followed a signature link here and it is intresting reading .
You got me thinking with this write up . I understand the concept and all, but my real question is. Do you guys actually get in water that deep? If so what do you do about the dash i.e., radio, gauges, controls, and not mention, driver and passengers? Do you have the tub all sealed up or just try to go through as fast as you can before the tub floods?
Just curious in case I ever get to much liquid courage in the vicinity of a pond or mud hole.
Dale
Weekender1969 is offline
post #33 of 44 Old 02-15-2007, 04:57 PM
jaw41272
jaw41272's Avatar
my quesation is, how do you go about sealing up the rest of the crap under the hood, distributor, fuse box and all that stuff, my last truck was so damn tall I wouldnt have thought about crossing water deep enough to swamp it, so I am a little dumb on this
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #34 of 44 Old 02-15-2007, 05:00 PM
Skeezer
Coat all electrical, spark plugs, sensors, etc. with Dilectric Grease. This will waterproof everything electrical. You can silicone around the distributor if needed.
2005 Rubicon
Skeezer is offline
post #35 of 44 Old 02-19-2007, 06:34 PM
jaw41272
jaw41272's Avatar
Originally Posted by speedfreak331
I finally got some pics of my snorkel setup. If anyone is thinking of doing the same thing, i would definitely recommend a K&N air filter to help the engine breathe. Also you have to relocate the overflow bottle for the radiator. I havent done that yet, but i am using a 1 quart catch can from my race car.
^^^^^AS YOU CAN SEE IN THE ABOVE PIC, THE SNORKLE SETUP WORKS.
THE WATER STAIN ON MY SOFT UPPER DOORS WAS WHERE THE WATER WAS.
P.S. I picked this 94 YJ for $700 Do you think it was worth it?
I am going to attempt to install one similar to this on my 91 4.0, except since my hood is already got a scar on the right front, I was thinking of sealing up the factory intake hole in the front of the airbox and going straight out the side of the airbox in the space right by the left rear hold down clamp for lid and then coming straight out thru the hoodmaking a 90 back and then following the windshield frame up, I already have a K&N drop in, and I think I can cut the hood and roll the lip back so there aren't any sharp edges, and possibly use some rubber to seal the gap around the hole and the tubing. This way I don't make any holes in the body, and don't have to relocate the overflow bottle.
Can anyone think of any negative effects this may have? Because I truly cannot.
Here is a rendering of how I plan to set it up.
http://www.cardomain.com/ride/2571663/2
jaw41272 is offline
post #36 of 44 Old 02-19-2007, 06:40 PM
jeepwrnglr92
2015 JK Wrangler
very cool. I was looking at them and they like $360 for a set up like that.
2015 Jeep Wrangler JKU "Tank" Sport S
2002 Avalanche: To many mods to list
jeepwrnglr92 is offline
post #37 of 44 Old 04-11-2007, 07:58 PM
xwildman138x
xwildman138x's Avatar
1995 XJ Cherokee
Does Skip sell that Dilectric Grease?
"Yo ho yo ho a pirate's life for me"
xwildman138x is offline
post #38 of 44 Old 04-26-2007, 02:20 PM
bulljeeper
bulljeeper's Avatar
has anyone made a snorkel like this for the motorcraft 2100 carburetor
bulljeeper is offline
post #39 of 44 Old 04-26-2007, 06:44 PM Thread Starter
KrwlinTJ
KrwlinTJ's Avatar
You can use the setup i made for the mc2100. all you have to do it get a longer hose that goes from the air hat to the air box, or make one yourself.. it is pretty straight foward...
1997 Jeep TJ
JEEP= Just Empty Every Pocket.
Doing things that people say can't be done.
KrwlinTJ is offline
post #40 of 44 Old 04-27-2007, 09:26 PM
Dadude1083
Ok, so a couple questions:
1st: How do you know what to connect the snorkel to under the hood? What specifficaly does it attach to in order for the engine to breath?
2nd: How do you switch from belt to electric fan (list of what else you have to do before deep diving)
3rd: What would you have to do with your radio, CD player, etc. inside ? If water were to get that high, it would ruin it..
-Thanks
Dadude1083 is offline
post #41 of 44 Old 04-27-2007, 10:32 PM Thread Starter
KrwlinTJ
KrwlinTJ's Avatar
if you read all of the above post and if you click on the link in my sig you will see what you need to get and use to connect your snorkel.
if you do a search on electric fan setups you will find many ways of hooking up and setting up an electric fan in your rig.
if you tub is pretty tight and you have all holes and stuff sealed you dont have to worry about too much water getting into the jeep, also these setups are designed to help you get across deep water crossing and not designed for a jeep to do deep sea diving, if that is what you are planning then i would suggest getting a submarine,, and if you plan on driving in water that deep for a long time then i think your radio, cb, etc should be placed into a water tight compartment and sealed, just like a black box found on air planes.
if you look or search thru some of the pictures that i have and others have, you will see that i went thru some deep stuff and i have never had any problems with my electronics. and if i was to get stuck in deep water and was to fill my tub that high , i would be looking for a new radio, cb, etc. at least my motor would be safe and i would be able to make it home, once i got my jeep out of the water and dried off.
1997 Jeep TJ
KrwlinTJ is offline
post #42 of 44 Old 02-14-2008, 01:08 PM
justjimmyit
I was wondering how much this set up would cost you roughly?
justjimmyit is offline
post #43 of 44 Old 02-14-2008, 10:46 PM Thread Starter
KrwlinTJ
KrwlinTJ's Avatar
This setup cost me about $75.00 dollars, and that is with all the stuff from the junkyard..
1997 Jeep TJ
KrwlinTJ is offline
post #44 of 44 Old 02-15-2008, 03:52 AM
98formulaLS1
98formulaLS1's Avatar
including the Jeep? lol
1994 XJ---1994 Honda Civic---2000 Honda CBR600 F4
98formulaLS1 is offline
YJ 350 TPI Snorkel Setup? 350TPIYJ YJ Wrangler Technical Forum 2 03-12-2011 10:13 AM
New intake/snorkel setup, want some feedback Nickb1907 TJ Wrangler Technical Forum 11 09-29-2006 06:21 AM
Snorkel kit w/ dual battery setup? countryboy4ya TJ Wrangler Technical Forum 4 01-30-2006 03:58 PM
Snorkel on a Weber setup? Eriq35 YJ Wrangler Technical Forum 2 06-25-2004 06:15 PM
What Snorkel will fit 4cyl jeep?? NoktrnalJeep13 YJ Wrangler Technical Forum 5 06-09-2004 12:17 PM
