My 4wd wont work - JeepForum.com
post #1 of 11 Old 08-06-2013, 09:55 PM Thread Starter
jimhill
My 4wd wont work
My 4wd won't work and a friend said I could just turn the vacuum around and it will work. What does this mean? And how do I do it?
jimhill is offline
post #2 of 11 Old 08-06-2013, 09:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There's a link inside this thread
http://www.jeepforum.com/forum/f12/t...80/?highlight=
You may need to have your driveshaft up front balanced if you've got some vibrations.
Luck Favours The Prepared
Anticanman is offline
post #3 of 11 Old 08-06-2013, 10:08 PM Thread Starter
jimhill
Thanks and I just got a new driveshaft
jimhill is offline
post #4 of 11 Old 08-07-2013, 06:02 PM
tdewit
Also something I may point you at:
http://www.jeepforum.com/forum/f12/4...nally-1534273/
tdewit is offline
post #5 of 11 Old 08-07-2013, 07:15 PM
Old4X
1990 CJ7
Probably just rotted out vacuum lines. 25 years old is way past their expire date.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #6 of 11 Old 08-07-2013, 07:19 PM Thread Starter
jimhill
Thanks ill look into that to
jimhill is offline
post #7 of 11 Old 02-11-2014, 03:51 PM Thread Starter
jimhill
What is the fluid that comes out of my shift motor?
jimhill is offline
post #8 of 11 Old 02-11-2014, 04:20 PM
XJ93
You mean the vacuum motor? That is just gear lube, don't worry about replacing the small amount that leaks out, but I would do a drain and refill of the front and rear diffs just to get a look at the gears and make sure everything looks good.
XJ93 is offline
post #9 of 11 Old 02-11-2014, 04:41 PM Thread Starter
jimhill
How would I do this?
jimhill is offline
post #10 of 11 Old 02-14-2014, 03:45 PM
brianandcara
1987 YJ Wrangler
Put a pan under the diff and pull the bolts. Clean the old gasket/rtv off, install new gasket/rtv. Remove fill plug and fill it up with gear oil till the oil runs out of the plug hole. Also you can pull the shift cover off the axle, pull the clip off the shaft that holds the fork in place (carefull the things are easy to loose) slide the fork over, re-install the clip, slide the shift collar to the engaged position and re-install shift cover.
brianandcara is offline
post #11 of 11 Old 03-17-2014, 02:34 PM Thread Starter
jimhill
I ended up getting posi lok
jimhill is offline
