Quantcast my 4WD wont engage - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > my 4WD wont engage
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 01-29-2008, 07:31 PM   #1
88YJ D-port
my 4WD wont engage
I have a 88 YJ and my 4wd does not want to engage at all. I dont know what the problem is, if any one has any tips or suggestions I'd appreciate it.
88YJ D-port is offline   Reply With Quote
Old 01-29-2008, 07:54 PM   #2
93jeepREDSOX
Does the light turn on? Check the vacume lines, then you motor, if it is not that then it might be the shift fork inside the axle.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline   Reply With Quote
Old 01-29-2008, 08:26 PM   #3
88YJ D-port
no the light doesnt turn on
Old 01-29-2008, 08:56 PM   #4
sitdwnandhngon
1987 YJ Wrangler
time for a posi lok, i cringe alittle everytime i shift into 4wd, my vaccum lines still work but i know someday theyll quit on me and ill have to order the posi lok kit
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline   Reply With Quote
Old 01-29-2008, 09:53 PM   #5
masterfu
2011 JK Wrangler
So I've got a question along the same lines as this. I've got a spare vacuum locker that came with my YJ, and I'm not even sure if the one that's in it currently is dependable or not, so I'm considering taking a route that I've heard some people take. Is it fairly difficult to rig up a couple cables through the firewall that you could pull that would be connected to the locker to engage/disengage it by drilling two holes in it, one on each end? If someone has a better way of getting around the YJ vacuum reliability issue I've seen, I'd love to hear about it.
/l , [____],
l---L--[]lllllll[]
()_) ()_)--o--)_)
masterfu is offline   Reply With Quote
Old 01-29-2008, 10:04 PM   #6
crb577
well the vacuum motor just engages your 4wd no locker. because the passenger side of the axle is much longer up until 1995 they used a vacuum motor to engage two shafts together to make it be in 4wd. that being said you can do it both ways they sell a kit which is the posi-lok or there is a homebrew version they do make a posi-lok kit for stock vehicles and for lifted vehicles so if you decide to buy it be sure to choose the one that will best suit you
homebrew write up
http://home.earthlink.net/~stevenschreiber/jeep/tech/cabledis.htm
cheapest posi-lok kit
http://www.discountjeepparts.com/product_info.php/cPath/2880_238_1855/products_id/1949
1993 Jeep Wrangler
4.0L Tom Woods rear HD shaft
D30 w/yukon alloys, lock right, jb4x4 bracket, Rusty's HD tie rod 8.8w/ LSD,5" BDS, homemade greasable boomerang shackles, SS braided lines, rubicon flares, 1" prothane body lift, 35" TrXus M/T, smitty built XRC, armor and a paint job soon to come.
crb577 is offline   Reply With Quote
Old 01-29-2008, 10:11 PM   #7
masterfu
2011 JK Wrangler
Thanks crb577, that homebrew kit is pretty much what I was thinking of doing, but just a little more organized.
/l , [____],
l---L--[]lllllll[]
()_) ()_)--o--)_)
Glock Forum
