MY 350 swap..... - Page 9 - JeepForum.com
post #121 of 220 Old 04-27-2008, 04:06 PM Thread Starter
jeepin1995
jeepin1995's Avatar
bear with me! so the three small wires..... one is by itself, the other two are on the same connector..... can i just cut the one that goes to the neutral safety switch and leave the other onehooked up?
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #122 of 220 Old 04-27-2008, 04:18 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i think what i did on mine, was trace the wire from the ignition switch itself, tha twent to the starter. then put that onto the small connector on the chevy starter.
the big connector will goto the battery.
i dont "think" i have any other wires from the jeep on there. there was 1 wire from the painless harness that went to the starter, but that was it.
so i guess yes, just cut the neutral wire and give it a shot!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #123 of 220 Old 04-27-2008, 04:20 PM
Jeepfreak81
Jeepfreak81's Avatar
I had to bypass the stock starter circuit, the Chevy V8 starter would overload something in the stock jeep wiring and if I cranked it longer then a second I wouldn't be able to crank it again for a half hour or so, I was always jumping the starter with a screwdriver until I bypassed it.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #124 of 220 Old 04-27-2008, 05:21 PM Thread Starter
jeepin1995
jeepin1995's Avatar
how did you bypass it?
post #125 of 220 Old 04-27-2008, 05:40 PM
Jeepfreak81
Hidden 12V switch on the Distributor, and a Starter button under the dash. All you need is 12V to the dizzy and momentary 12V to the starter solenoid when you want to start it to run the engine. (other then the battery cable attached to the starter)
Kinda hack, but no one knows how to start my jeep and that is nice.
I left the factory wiring in place though because 90% of the time it starts right away, I just have to flip the dizzy switch.
The switch on the left is the electric fan, black pushbutton is the starter.
post #126 of 220 Old 04-27-2008, 05:56 PM Thread Starter
jeepin1995
jeepin1995's Avatar
This is going to be my last resort, so bottom line is you ran a wire from battery to distributor with a switch to cut power. then ran cable from battery to big post on starter, and wired from one post to the other (on starter) with a switch for starting. correct? what gauge wire did you use for the starter? dist?
Thanks!
post #127 of 220 Old 04-27-2008, 06:06 PM
Jeepfreak81
Yep, I have a 12AWG (IIRC) wire from the battery or fuse box (I don't recall) to a switch in cab that goes to the dizzy.
The push button switch also is 12awg (IIRC) and goes from the fuse box to the push button to the small post on the starter.
The battery cable goes from the large starter post to the battery.
post #128 of 220 Old 04-27-2008, 06:24 PM Thread Starter
jeepin1995
jeepin1995's Avatar
thanks a bunch!! i'll let you guys know what works and which way i go!
post #129 of 220 Old 04-28-2008, 06:56 PM Thread Starter
jeepin1995
jeepin1995's Avatar
thanks martin!!! i had them hooked up like that at least 7 times yesterday..... all a no go..... got to picking around at it today..... realized when a friend and i were pulling the 4 cyl, i asked him to unplug sensors and stuff..... well he unplugged EVERYTHING..... hooked a big plug back together and voila!!! cranks with the key!!! definitely shooting for firing up this weekend!!
list of things remaining:
exhaust
trans cooler
electric fan switch
modifying skid to accept trans mount
fill anti-freeze
fill trans
wire fuel pump
mount power steering pump
have alternator converted to a 1-wire setup
belts
i think thats it!! we'll see how it goes!
post #130 of 220 Old 04-30-2008, 06:22 PM
leftlanetruckin
XJ on 37's
congrats!!!!!!
feels good doesnt it mate!
keep us posted!
martin
post #131 of 220 Old 04-30-2008, 07:58 PM Thread Starter
jeepin1995
jeepin1995's Avatar
definitely will!!! hoping to have it fired up this weekend sans exhaust.....(that'll be next week) she'll be a loud one!
post #132 of 220 Old 04-30-2008, 08:22 PM
leftlanetruckin
XJ on 37's
yeah it will....
i started mine, and drove it down to the exhaust shop with only @6" of downpipe coming out of the manifolds....
only reason it had that was to protect the wiring etc...... sounded obnoxious to me, but some liked it i was told....
martin
post #133 of 220 Old 04-30-2008, 08:52 PM Thread Starter
jeepin1995
jeepin1995's Avatar
only driving mine will see without ehxaust is onto a trailer then off at the muffler shop. and the initial start-up of course!
post #134 of 220 Old 05-02-2008, 09:01 AM Thread Starter
jeepin1995
jeepin1995's Avatar
another question.... trying to decide on what to do for fuel delivery..... my two options are:
stock jeep fuel pump with a regulator..... will it go that low?
or a new low pressure pump.
opinions?
post #135 of 220 Old 05-02-2008, 08:11 PM
leftlanetruckin
XJ on 37's
i used a chevy s10 fuel pump in my yj tank. it fits, just......
a good swap in my mind, is where the donor motor still thinks it is in the donor vehicle, so try to use as much of the chevy stuff as possible. as an added bonus, you can get chevy parts anywhere!
martin
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
