MY 350 swap..... - Page 7 - JeepForum.com
post #91 of 220 Old 02-25-2008, 05:03 AM
Jeepfreak81
Jeepfreak81's Avatar
Originally Posted by 1 ton yj View Post
I had the excitier wire to a switched 12v source, and burned up voltage regulators every couple of trips. I then wired it in parallel with the coil positive wire and it's been fine for almost 3 years. The regulator was getting too much power with it's own deticated switched source.
So you wired it to the positive post on the coil?
Never heard of anyone having an issue with just running to switched 12V, I burned up one internal regulator in the 6 years I have had the swap, and it was so soon after the Taurus fan (last year) I attributed it to that. Wondering if I should move my wire now....
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #92 of 220 Old 02-25-2008, 06:24 AM
1 ton yj
1 ton yj's Avatar
No I wired it to the wire that goes to the positive coil post.
1 ton yj is offline
post #93 of 220 Old 02-25-2008, 06:27 AM
Jeepfreak81
That wire is switched 12V? I don't see how it is any different I guess.
post #94 of 220 Old 02-25-2008, 11:56 AM
1 ton yj
1 ton yj's Avatar
Less current gets to the alternator. Painless includes a resistor with their GM alternator plugs for the same reason.
1 ton yj is offline
post #95 of 220 Old 02-25-2008, 04:44 PM Thread Starter
jeepin1995
jeepin1995's Avatar
called the alternator shop today, he said for about $20, he could switch it to a 1 wire alternator with a self exciting regulator..... sounds like my plan.....
goal for this weekend is to get her wired up and fired off!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #96 of 220 Old 03-02-2008, 08:27 AM Thread Starter
jeepin1995
jeepin1995's Avatar
went and picked up a 231C transfer case yesterday..... tore it apart, and mated the front case half to the rear case half/SYE of my 231J case.....
swapped a few of the guts too..... the "c" case has 6 planetary gears on the 4-lo gear....("j" only has 3) so i used that, also the "c" case has a wider chain, used that.....was able to use the SYE from my "j" case. everything went together perfect.
also fixed the stock jeep transfer case shifter so it will bolt up with the different t-case bolt pattern.
and rigged up a trans mount.
got it all bolted in, and the rear driveshaft is still the perfect length. no DS work needed for this swap!
more work and pictures to come today!
post #97 of 220 Old 03-02-2008, 09:32 AM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
that is exactly what me and rob did, works just fine!
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #98 of 220 Old 03-02-2008, 10:11 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
martin
And what I'm in the process of doing....lol.
Tomb Raider is offline
post #99 of 220 Old 03-02-2008, 10:14 AM
leftlanetruckin
XJ on 37's
you doin the 231 c/j now mate????
thaught the 242 you had was working fine?
post #100 of 220 Old 03-02-2008, 06:43 PM Thread Starter
jeepin1995
jeepin1995's Avatar
got a LOT of small things done..... jeez the small things take twice as long as the big stuff! installed the lokar kickdown cable, made a custom accelerator cable mount, modified my stock skid, rigged the wires for the torque converter lockup, installed the trans filter and pan..... not much to take pictures of, but here's a few anyways.
"new" t-case..... not clocked that bad, camera was tilted. it does angle down more than the jeep case tho.
lockup wiring..... a trans guy told me if i wanted to bypass getting an ecu for the trans, loop the black and white wires back together, then run the red to a source with a fuse.....this way it will always lock-up in overdrive..... we'll see how that works!
lokar kickdown cable:
trans pan Whoop dee doo.....
my favorite..... the incognito chevy symbol.....
next weekend is the B&M shifter, t-case shifter, starter and wiring, and the exhaust..... gonna be busy!
post #101 of 220 Old 03-10-2008, 10:48 PM
e-tek
lookin good. makes me all sorts of giddy to get started. but im close. i might need some help from you here in the near future
1998 green TJ with a 2" bb LIFT.
4.3l v6
e-tek is offline
post #102 of 220 Old 03-10-2008, 10:51 PM
BlackRhino
BlackRhino's Avatar
I like the chevy logo. It's looking very good!
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
post #103 of 220 Old 03-11-2008, 05:22 AM Thread Starter
jeepin1995
jeepin1995's Avatar
thanks! i hope to be done by the end of march..... we'll see how it goes.
post #104 of 220 Old 03-11-2008, 05:44 AM
--chris--
--chris--'s Avatar
This is moving along nicely!
Good work so far
--chris-- is offline
post #105 of 220 Old 03-11-2008, 09:33 AM
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
Hey you got any plans for the end of may? You should take that beast up to URE with us...
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Jakemd98 is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
