MY 350 swap..... - Page 6 - JeepForum.com
post #76 of 220 Old 02-23-2008, 08:18 PM Thread Starter
jeepin1995
jeepin1995's Avatar
send me the diagram if you will..... jeepin1995@aol.com. thanks!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #77 of 220 Old 02-23-2008, 08:30 PM
93jeepREDSOX
Nice work man, i eventually want to do this with my yj, so I am definatly taking notes.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #78 of 220 Old 02-23-2008, 08:30 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
sent!
let me know if you need any others. alldata is a SOB to find stuff on, but everything is there somewhere.....
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #79 of 220 Old 02-23-2008, 08:46 PM
Jeepfreak81
Jeepfreak81's Avatar
IIRC I only used the main power wire on the back of the alternator, and one wire from the 2 pronged plug, the other was taped off.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #80 of 220 Old 02-23-2008, 08:53 PM
leftlanetruckin
XJ on 37's
just gotta figure out the exciter wire for the alt. the other small wire doesnt need to be used, as you correctly said!
martin
post #81 of 220 Old 02-24-2008, 08:37 AM Thread Starter
jeepin1995
jeepin1995's Avatar
martin
how would i go about finding out which is the "exciter" wire???
also, leftlane, i never got that e-mail.....
post #82 of 220 Old 02-24-2008, 09:11 AM
KrwlinTJ
KrwlinTJ's Avatar
here is a pic from all data to try and help you out.. this is from a 91 Gmc truck setup, so the fuse box is different from th jeep, but you can use the picture to help determine which wire is used for the exciter on the alternator/generator..
1997 Jeep TJ
JEEP= Just Empty Every Pocket.
Doing things that people say can't be done.
KrwlinTJ is offline
post #83 of 220 Old 02-24-2008, 10:46 AM Thread Starter
jeepin1995
jeepin1995's Avatar
thanks for that.
although, it didn't really help me. like i said i'm dumb when it comes to electrical..... (one of the reasons i'm going carbed at first.....) very minimal wiring.
is there anybody who's done a carbed 350 swap that can tell me what's what?
sorry for the ignorance, but i'm dead set on not hiring a shop to do it.....i'm a do-it-yourself kinda guy!
post #84 of 220 Old 02-24-2008, 11:32 AM
gimme mud!
the Three-wire Alternator uses a battery wire, ignition/warning light wire and voltage sensing wire
95 wrangler, SOA 4" springs, 35's, 400sb chevy, muncie 465, np205, GM corp 14 bolt full floater rear, dana 60 front 5.13's
gimme mud! is offline
post #85 of 220 Old 02-24-2008, 12:26 PM
leftlanetruckin
XJ on 37's
rob posted the diagram i emailed to you, dunno why you didnt get it!
maybe rob can look and see which wire he put where? i am in california right now, so i cant look for ye myself. i know he told me the secret...so maybe he will share
martin
post #86 of 220 Old 02-24-2008, 12:55 PM
coyote_94yj
coyote_94yj's Avatar
You know you can take the alternator down to a starter/alternator shop somewhere and they can convert your alternator to a single wire setup. Then all you have to do is run the wire to the battery. I've been runnin mine that way since 02.
My
Chris
coyote_94yj is offline
post #87 of 220 Old 02-24-2008, 01:18 PM
Jeepfreak81
Red wire to switched 12V
BIG red wire on back, tape off white wire.
I wanted to solder that connection anyway so I went and tore it apart.
post #88 of 220 Old 02-24-2008, 02:33 PM Thread Starter
jeepin1995
jeepin1995's Avatar
My
Chris
thats an idea..... i'm assuming you have the internal voltage regulator? does it work normal? i know we have a forklift at work that had a gm alternator put on it, and you gotta rev the motor everytime you start it to get the voltage regulator to kick in.....
again, thanks for ALL replys! helpful or not! still learning! when it comes to wrenching, i can do almost anything...... but anything electrical or electrical related is 100% foreign!
post #89 of 220 Old 02-24-2008, 08:33 PM
coyote_94yj
Yes I have a plain old GM alternator with an internal regulator. It works like normal. I haven't paid much attention to whether or not I have to run the RPMs up to excite the alternator or not but I would guess mine is that way.
Chris
post #90 of 220 Old 02-24-2008, 09:47 PM
1 ton yj
1 ton yj's Avatar
I had the excitier wire to a switched 12v source, and burned up voltage regulators every couple of trips. I then wired it in parallel with the coil positive wire and it's been fine for almost 3 years. The regulator was getting too much power with it's own deticated switched source.
1 ton yj is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
