MY 350 swap..... - Page 5 - JeepForum.com
post #61 of 220 Old 02-16-2008, 05:03 PM Thread Starter
jeepin1995
jeepin1995's Avatar
i wasn't worried about it, i planned on NOT using the mechanical fuel pump from the git-go..... found an electric fuel p[ump i'm gonna use today, pumps at 4-7 PSI.
made progress today, got carb rebuilt, new motor has all new gaskets and a fresh coat of paint..... hope to get it and the trans set in tomorrow. will have pics then!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #62 of 220 Old 02-16-2008, 05:38 PM
Rolling/Stone
I am in the process of doing the same mod on my 89. I have the same mounts, and so far they have been great. I am not an experienced mechanic, but I think this project is coming along nicely. You obviously have many more resources available to you, than I do for this type of work, and will probablly finish before me, but I have learned a few things. First, put the engine back as far as the mounts will allow, this will give you a full inch front to back travel. Fan/Water Pump clearance is a problem when you put in the radiator, mine is a "Be Cool", up to your electric fan. With the engine in the mid range position my single electric fan was too close to the water pump assembly. I did some mods there, I have pics if you need them, but a dual fan assembly would have made it all much easier. My headman headers are fine with clearance on the frame, oil filter/ and everything else I can see so far. Good luck!
Rolling/Stone is offline
post #63 of 220 Old 02-17-2008, 08:46 PM Thread Starter
jeepin1995
jeepin1995's Avatar
here it is!!!! got the motor cleaned up, new gaskets, mated to the trans and set in the jeep! now the fun of wiring begins!
mmmmm 4-bolt main.....
all cleaned up!
ready to go in.....
there she is.....
post #64 of 220 Old 02-17-2008, 10:01 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Lookin damn good bud.
Tomb Raider is offline
post #65 of 220 Old 02-19-2008, 08:55 PM
e-tek
damn thats sick. how is that mount? happy with where it sat?
good clearance and access to everything?
1998 green TJ with a 2" bb LIFT.
4.3l v6
e-tek is offline
post #66 of 220 Old 02-20-2008, 04:23 AM Thread Starter
jeepin1995
jeepin1995's Avatar
so far it seems ok, haven't hooked everything up yet.....
post #67 of 220 Old 02-20-2008, 04:41 PM
twistedfred87
wow. Lookin' VERY nice
1990 Jeep Wrangler YJ
4.2L Jasper Rebuild
Ax-15 Manual Tranny with new Bellhousing(Jasper Rebuild)
5.5" suspension lift, 2" body lift, 35x12.50 BFG MTRs
New Clutch
HD SYE/CV
twistedfred87 is offline
post #68 of 220 Old 02-20-2008, 04:58 PM
1 ton yj
1 ton yj's Avatar
Originally Posted by jeepin1995 View Post
What is that blue thing bolted to the cylinder head on the passenger's side? And where is the steering pump?
What did this motor come from?
1 ton yj is offline
post #69 of 220 Old 02-20-2008, 08:06 PM Thread Starter
jeepin1995
jeepin1995's Avatar
it's a secret..... but really..... the motor came from an emergency generator for the local power company, generator was struck by lightning..... motor still ran perfect. it's 350 with 4-bolt main..... not 100% on the year, somewhere around early 80's is my guess. has only 532 hours on it..... if you multiply that by 55 MPH it would be equivilent to about 30,000 miles or so. ANd it was run on propane, so it's clean as the day it was made.
the blue thing is some sort of automatic throttle or something to that effect. power steering pump..... haven't gotten one yet.....
post #70 of 220 Old 02-21-2008, 06:46 AM
1 ton yj
1 ton yj's Avatar
That's interesting. Every generator I've ever seen was diesel, but the fact that yours was propane leads me to believe that it was run indoors.
1 ton yj is offline
post #71 of 220 Old 02-21-2008, 05:28 PM
x99j
we got a 25kw koehler nat gas at work, with a pinto 2300 (2.3L) in it. and it was purchased in 2001.
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #72 of 220 Old 02-21-2008, 06:07 PM Thread Starter
jeepin1995
jeepin1995's Avatar
it was run outdoors..... IIRC the operating RPM for the generator was around 1400 RPM..... this thing has had an easy life..... but it's about to get much harder!
post #73 of 220 Old 02-21-2008, 07:08 PM
1 ton yj
1 ton yj's Avatar
those look like small port heads, valves should float around 5200-5500. you wont hurt anything.
let er rip!
1 ton yj is offline
post #74 of 220 Old 02-23-2008, 07:25 PM Thread Starter
jeepin1995
jeepin1995's Avatar
i'm dumb as a box or rocks when it comes to electrical..... although, i have only one part of the VERY minimal wiring left to figure out..... the alternator. it's a GM 3-wire alt. what wires go where????? there's a bigger wire then 2 smaller..... we'll call them drivers side and pass side for easy clarification.......... help!!!
post #75 of 220 Old 02-23-2008, 07:37 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
i have alldata for the 4.3 i put in my junk, it is showing the 3 wire alternator too.
here is how i am reading the diagram (cant post up here, sorry)
black/red - battery
brown - hot in start, showing a 3amp fuse. also shows this as being the charge indicator wire.
pink/black - i am thinking this is hot in start and run, but cant trace the wires easily. maybe someone will chime in on that one...it should goto pin 39 of the bulkhead fitting.
hope this helps? if you need me to email you a pic of the diagrams, let me know and send me your email addy.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
