MY 350 swap..... - Page 4 - JeepForum.com
post #46 of 220 Old 02-12-2008, 07:44 PM Thread Starter
jeepin1995
jeepin1995's Avatar
got the carb, need some info on it.....not sure what it came off of..... it's a holley 4 bbl.....number on it reads
LIST-3310-2
0963
here are some pics..... please help!!! i need a rebuild kit!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #47 of 220 Old 02-12-2008, 08:21 PM
1 ton yj
1 ton yj's Avatar
It's a Holley 750 4bbl with vaccum secondaries. Can't tell you much more than that, and what I did tell you I got off of Google.
Sorry, my experience with carburetors is setting the idle then taking them off to put on EFI.
1 ton yj is offline
post #48 of 220 Old 02-12-2008, 08:34 PM Thread Starter
jeepin1995
jeepin1995's Avatar
hmmmmm..... my experience with them is ZERO..... never dealt with one.....maybe somebody can "dumb down" what you just said..... if rebuilt and adjusted properly, is it a decent carb?
post #49 of 220 Old 02-13-2008, 07:40 AM
ovrlnd
if your gonna wheel and use a holley get a truck avenger. otherwise put a q-jet on there. street carbs are only going to give you headaches on the trail
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
ovrlnd is offline
post #50 of 220 Old 02-13-2008, 07:47 AM
KrwlinTJ
KrwlinTJ's Avatar
too solve your problems, I would just do fuel injection. This is one of the best mods i did when i did the 4.3 conversion in my jeep. I have now removed the 4.3 and putting in a 350 tbi into my jeep. No more starting problems and it will idle thru the roughiest terrain...
1997 Jeep TJ
JEEP= Just Empty Every Pocket.
Doing things that people say can't be done.
KrwlinTJ is offline
post #51 of 220 Old 02-13-2008, 07:52 AM
1 ton yj
1 ton yj's Avatar
Sounds like he's using the carb because it was free or close to it. Holley, Q-jet, edlebrok, whatever. None of them are worth anything in the woods but the holley will get him driving until he can get fuel injection together.
1 ton yj is offline
post #52 of 220 Old 02-13-2008, 06:12 PM Thread Starter
jeepin1995
jeepin1995's Avatar
which is exactly what i'm doing..... i obviously don't wanna stick with the carb, i do want fuel injection, but thats kinda pricey right now plus i haven't decided how i wanna go about it......the carb and intake cost me nothing.....
oh yea, figured out the specs on the carb plus some..... 1 ton, you were right on. thanks!
post #53 of 220 Old 02-14-2008, 08:35 PM Thread Starter
jeepin1995
jeepin1995's Avatar
picked up a rebuild kit for the carb today....... that's gonna be a job in itself!
also ordered the shifter and radiator. my goal for this weekend is to get the "new" motor cleaned up, new gaskets and seals, get it mated to the trans, cut my rear fenders for the comp cut, and of course rebuild the carb.... any pointers on that by the way???? (first timer!)
whats best to clean the carb when building it? just regular carb cleaner???
tomb raider, i saw you mounted your stock sending unit in your fuel cell..... hard to do?
could i run the carbed 350 off of the stock fuel pump??
look for tons of pics after this weekend!
post #54 of 220 Old 02-14-2008, 09:20 PM
coyote_94yj
coyote_94yj's Avatar
You cannot use the stock fuel pump by itself on the carb. You need a fuel pressure regulator inline to drop the pressure between 5 and 8 psi.
Chris
coyote_94yj is offline
post #55 of 220 Old 02-14-2008, 11:24 PM Thread Starter
jeepin1995
jeepin1995's Avatar
ok, so if i get a regulator, i can keep the stock pump?
post #56 of 220 Old 02-15-2008, 06:01 AM
Jeepfreak81
Jeepfreak81's Avatar
Chris
Depends on the carb... Edelbrocks are supposed to have a maximum of 6.5psi unless that changed recently. I am not sure what the Holley requires.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #57 of 220 Old 02-15-2008, 09:59 AM
1 ton yj
1 ton yj's Avatar
Sounds like you want to drop the YJ sending unit in the 2161 cell? Take the pump off the sending unit and put it in the goodie drawer in your toolbox, put a peice of hose in its place. Cap the return line on the sender and run the supply line to the factory mechanical pump on the side of the block.
That way you can easily convert back to EFI down the road (you will want to, trust me) by putting the pump back on the sender and running a return line.
1 ton yj is offline
post #58 of 220 Old 02-15-2008, 11:25 AM
coyote_94yj
No it hasn't changed. Its still 6.5psi for edelbrock carbs. That is what I'm running now. They are mfg specific. I just don't know what the others run because I've never ran anything but edelbrock.
Chris
post #59 of 220 Old 02-15-2008, 05:41 PM Thread Starter
jeepin1995
jeepin1995's Avatar
[QUOTE=1 ton yj;4819680] run the supply line to the factory mechanical pump on the side of the block.
QUOTE]
only issue i've seen with the engine cradle is that i need to use an electric fuel pump.....
post #60 of 220 Old 02-16-2008, 05:37 PM
1 ton yj
1 ton yj's Avatar
Another reason not to use the cradle.
You're going to need a regulator in that case. Aeromotive makes a nice one, should be in Summit, Jeg's, ect.
1 ton yj is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 05:11 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 02:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 04:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 04:28 PM
