MY 350 swap..... - Page 3 - JeepForum.com
post #31 of 220 Old 02-11-2008, 10:12 AM
TrailWorthyFab
TrailWorthyFab.com
TrailWorthyFab's Avatar
What fuel cell are you going to use?
BUY IT DONT' BUILD IT!! You will be money and time ahead. (Flip off)
TrailWorthyFab is offline
post #32 of 220 Old 02-11-2008, 05:46 PM Thread Starter
jeepin1995
jeepin1995's Avatar
the headers i got are designed to run inside the frame rails.
on the fuelcell, probably a 15 gallon aluminum RCI from summit.....
(1 TON, appreciate the offer on the headers, but mine will be delivered tomorrow.)
erik..... the pane's gotta go..... just a personal preference!
"IF YOU CAN'T DAZZLE THEM WITH FACTS, BAFFLE THEM WITH BS"
jeepin1995 is offline
post #33 of 220 Old 02-11-2008, 09:02 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
The biggest thing with the radiator:
Make sure it's centered on the fan. If the fan is higher or lower than the rad, you run the risk of heat issues. I got lucky on my build I guess....the fan is within 1/2" of being centered both top/bottom and left/right. I have zero heat issues. This is of course assuming your using a mechanical fan. The electric fans you can just attach to the rad, no big deal.
Tomb Raider is offline
post #34 of 220 Old 02-11-2008, 09:29 PM
coyote_94yj
coyote_94yj's Avatar
Originally Posted by 1 ton yj View Post
My buddy Tim put a SBC in his Jeep and used ram-horn style manifolds. He's got the same weld-on motor mounts as I do.
I've been running the exact same setup as your buddy since 2002. It works great.
Originally Posted by Tomb Raider View Post
That radiator looks identical to the one I got from Advance Adapters. Never had a problem with it.
Chris
coyote_94yj is offline
post #35 of 220 Old 02-11-2008, 09:51 PM
e-tek
hey guys im at the start of a similar swap but im missin two pistons.... lol
im doing a 4.3l/700r4/231c conversion in my 98 tj can i use that same bolt in mount? and let me know how the engine sits in the bay when you get it set. what parts should i take from the jeep t case? the whole back half? sorry dont mean to ninja your thread lol just got lots of questions. thanks for any help. good luck on your conv looks like its commin along nice
1998 green TJ with a 2" bb LIFT.
4.3l v6
e-tek is offline
post #36 of 220 Old 02-12-2008, 04:43 AM Thread Starter
jeepin1995
jeepin1995's Avatar
i haven't done it yet, but i think you take the front case half of the 231c and mate it to the back half of the 231j.....
another radiator question.....would a 2 row radiator be sufficient or do i need a 3 row???
post #37 of 220 Old 02-12-2008, 06:35 AM
1 ton yj
1 ton yj's Avatar
Two row is fine. Aluminum will cool better. Don't limit yourself to radiators that are 100% bolt-on. The universal ones can be adapted very easily and usually cool better.
1 ton yj is offline
post #38 of 220 Old 02-12-2008, 07:04 AM
Jeepfreak81
Jeepfreak81's Avatar
FWIW my 2 row bolt in conversion radiator has always been on the edge. I will be switching to aluminum.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #39 of 220 Old 02-12-2008, 08:22 AM Thread Starter
jeepin1995
jeepin1995's Avatar
this is the radiator i am looking at.....
http://store.summitracing.com/partde...5&autoview=sku
post #40 of 220 Old 02-12-2008, 10:11 AM
e-tek
are you using a mech fan or bringin in an electric?
4.3l v6
e-tek is offline
post #41 of 220 Old 02-12-2008, 10:14 AM
1 ton yj
1 ton yj's Avatar
That will work fine. It will probably come with holes in the top and bottom lips for mounting but if not you can drill them yourself.
Also, a peice of 2" wide strap or box tube fits in between the lips top and bottom so you can get creative with you're mounts if you want.
1 ton yj is offline
post #42 of 220 Old 02-12-2008, 11:01 AM Thread Starter
jeepin1995
jeepin1995's Avatar
i've got an electric fan that i've been meaning to install..... for about 2 years now..... guess it's time!
post #43 of 220 Old 02-12-2008, 01:51 PM
Timbojackson
I am in the middle of the same swap but 350/th350/np205 I am using the novak MM. It appeared the aa cradle would interfere with my three link. Ill be watching your thread closely, Good Luck!!
1979 Formula Firebird
1989 YJ SOA in rear Custom 3 link front
Dana 44 front lockrite and rear 44 welded
Chevy 350/th350/np205
Timbojackson is offline
post #44 of 220 Old 02-12-2008, 02:05 PM
Michael_94YJ
This may be somewhat of a stupid question but where do you guys get your transfer cases from? Do you use ford or chevy or does it depend on what axles you're using?
1994 YJ 4.0L 5 spd.
flowmaster,15x12 wheels & 35x15 TSLs, sway bar discos, 3.5" leaves SOA + shackles, 2" body lift, JB steering bracket, SYE, M.O.R.E. anti-wrap bar, Bilsteins 5125s up front & BDS Hydros out back, axles in the works
Michael_94YJ is offline
post #45 of 220 Old 02-12-2008, 02:33 PM
gimme mud!
1 ton yj i agree with ya on the cradle and having yer engine mounts baked real easily. that cradle puts my engine in nicely but ya i could use a little more height to lower my tranfercase to get my drive angle better about the motor mounts i still use the cradle but decided to use solid engine mounts with it
95 wrangler, SOA 4" springs, 35's, 400sb chevy, muncie 465, np205, GM corp 14 bolt full floater rear, dana 60 front 5.13's
gimme mud! is offline
Another 4.0 Swap question...head swap vs. full engine swap Mol YJ Wrangler Technical Forum 11 10-18-2010 04:11 AM
Dana 30 diff. swap vs. gear swap BBCAT YJ Wrangler Technical Forum 2 02-28-2009 01:17 PM
HVAC Control Swap: Swap just the lower ac/heater housing, or all of it? Justin Brimm TJ Wrangler Technical Forum 5 12-20-2007 03:29 AM
TJ axle swap - d35 to d44 will brake assemblies swap birdman52 TJ Wrangler Technical Forum 11 08-27-2005 03:28 PM
