Quantcast MY 350 swap..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > MY 350 swap.....
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 02-09-2008, 10:57 PM   #1
jeepin1995
jeepin1995's Avatar
MY 350 swap.....
it's my turn..... this will serve as my official 350 swap thread. i'll use it to post updates, ask and answer questions. the end result is going to be a 350/700R4/231 combo.....first pics!!
Before.....
during pulling of 4 cyl.....
two hours later she's out!!
look at all that room!
perfect place for a fat guy to stand.....
this is the bolt-in V8 saddle mount i got from advance adapters.....
thats all for today..... not much technical stuff..... i'll definitely make up for it soon!
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
WWW.FLATLANDROCKCRAWLERS.COM
350 in my YJ.....
http://www.jeepforum.com/forum/f12/my-350-swap-518364/
build thread:
http://www.jeepforum.com/forum/f22/yj-dana-60-70-build-1122902/
jeepin1995 is offline   Reply With Quote
Old 02-09-2008, 11:22 PM   #2
learfxr
Watching to see how ya do. I have a different style mounts for mine. It will be a while before I try to tackle mine.
1989 YJ Islander
TBI350 4L60E BDS lift.
Wag axles, 38 TSL's, 4.56 gears
1995 ZJ Orvis Edition 5.2L
3" lift and 32's.
learfxr is offline   Reply With Quote
Old 02-09-2008, 11:38 PM   #3
jeepin1995
jeepin1995's Avatar
i'm actually not as nervous as i thought i would be..... we'll see!
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
350 in my YJ.....
http://www.jeepforum.com/forum/showthread.php?t=518364
build thread:
Old 02-09-2008, 11:43 PM   #4
Tomb Raider
MyJKRocks!
Very nice bud. Lemme know if I can help out in any way. At least as much as over the internet as I can.
Tomb Raider is offline   Reply With Quote
Old 02-09-2008, 11:45 PM   #5
BlackRhino
That's pretty cool. I hope I can afford to do that to my Jeep eventually.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline   Reply With Quote
Old 02-09-2008, 11:52 PM   #6
jameskjeep
looking good pete let me know if you need any help. Want be able to do much but will help you any way I can.
later man
2005 Black Jeep Wrangler X 6 speed
Python Security System With remote locks
7 Speaker sound system + 2 12" MTX Thunder 6000 Subs
1.25 JKS BL
2.5 OME HD Sup Lift 1 inch JKS MML 32" BFG MUDDS
MT Classic 2 15x8
jameskjeep is offline   Reply With Quote
Old 02-09-2008, 11:55 PM   #7
jeepin1995
jeepin1995's Avatar
actually..... selling off my old trans and motor has pretty much paid for the big ticket items..... engine mount, fuel cell, exhaust headers and the shifter..... i think i only have $100 out of pocket (trans)
tomb raider..... i got a feeling you're gonna be my best friend thru this!
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
350 in my YJ.....
build thread:
Old 02-10-2008, 12:20 AM   #8
learfxr
You going to run carb or injected? Is the donor from an injected vehicle? I just had a block handed to me for free, so with no injection parts I'm thinking propane, pretty cheap to build from scratch.
1989 YJ Islander
3" lift and 32's.
Old 02-10-2008, 12:34 AM   #9
jeepin1995
jeepin1995's Avatar
it's actually a 350 out of a emergency generator from the local power co..... it got struck by lightning and fried the generator (also free)..... motor runs good, only 500 hours and runs off of propane..... not really my cup of tea, i'm ditching that for a carb for now.....gotta start off easy.....
______
/l,[____],
l---L -[]lllllll[]
()_) ()_)---)_)
98 TJ stock for now
350 in my YJ.....
build thread:
Old 02-10-2008, 11:02 AM   #10
1 ton yj
What headers are you using?
1 ton yj is offline   Reply With Quote
Old 02-10-2008, 12:07 PM   #11
Jeepfreak81
Same exact swap I did quite a long time ago, good luck!
Don't skimp on the radiator, I bought a standard conversion radiator instead of going aluminum and have hated myself ever since for it.
I know you mention carb, if your buying a new one you can do a junkyard TBI for about the same price and have fuel injection, also worth it. I have a carb, and I love it most of the time though, but I have tinkered with carbs for a lot of years.
If your planning on buying an adapter to your t-case don't... Buy a 231C for $100 instead. You have to switch to a electric speedo (Autometers anyone) and you still come out ahead of the $500 adapter.
Keep an eye on the oil filter, if you don't have enough lift under full compression the driveshaft can make contact (also depends on your motor mounts), same with the exhaust depending on the headers you use. I kept the manifolds and got around this problem, though I have enough lift now, so if I ever need a new exhaust it will get headers.
I am sure you have already researched all that though. The upgrade is well worth it.
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies TRAIL TESTED (currently under the knife)
1946 CJ2A, 225 V6. mild lift - TIME TESTED
1966 M416 1/4 ton Military Trailer -- WAR TESTED
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline   Reply With Quote
Old 02-10-2008, 01:54 PM   #12
tank29
Yeah, It's A Jeep Thing!!
tank29's Avatar
What are the advantages or diadvantages of the AA motor mount cradle set-up over their weld-in motor mounts? I know the cradle set-up is about $80 more but was just wondering if one way is better then the other.
Goo luck with the swap. I hope to start mine this summer.
Todd
2007 JK Unlimited "X"
TeraFlex 3" Kit with 4 Arm Flex Kit, TeraFlex HD F & R Adj. Track Bar, Rock Krawler Spring Levelers, Yukon 5.13 Gears, Black Rock Soft 8 Steel Wheels 16x8 (4.25" BS), Cooper Discoverer STT 315/75/16, XRC Rear Bumper w/Tire Swing, Rugged Ridge Front w/Stinger, AEV Snorkel, Cobra 75, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fender Flares
tank29 is offline   Reply With Quote
Old 02-10-2008, 01:55 PM   #13
Jeepfreak81
Todd
The bolt in mount forces you to put the motor in a certain spot, the weld in will allow you to place it where ever you want it.
Old 02-10-2008, 03:07 PM   #14
xcannibalx
Very cool, I'm in the middle of doing the exact swap, with the same mounts (came with the jeep when i bought it). I'll be watching this thread closely, keep us up to date whats working, and whats not. Keep it up.
xcannibalx is offline   Reply With Quote
Old 02-10-2008, 03:14 PM   #15
1 ton yj
OK my experience with the drop-in cradle is that it places the motor very low in the frame. I also had problems melting motor mounts because that cradle put them very close to my blockhugger headers. I eventually wound up going to the weld-on style mounts to aleviate the motor mount issue and also to raise the motor to provide more clearance for my steering ram.
If you are using rear dump shorty headers/manifolds or you have long tube headers, and also have the clearance below the motor, the drop-in style mount will work fine. Personally, I prefer the weld-in style because it gives you more options in final position of the motor.
Glock Forum
