-   -   MY 350 swap..... (http://www.jeepforum.com/forum/f12/my-350-swap-518364/)
jeepin1995 02-09-2008 09:57 PM
MY 350 swap.....
it's my turn..... this will serve as my official 350 swap thread. i'll use it to post updates, ask and answer questions. the end result is going to be a 350/700R4/231 combo.....first pics!!
Before.....
http://i36.photobucket.com/albums/e5...p/100_1215.jpg
during pulling of 4 cyl.....
http://i36.photobucket.com/albums/e5...p/100_1222.jpg
two hours later she's out!!
http://i36.photobucket.com/albums/e5...p/100_1226.jpg
look at all that room!
http://i36.photobucket.com/albums/e5...00_1230_00.jpg
perfect place for a fat guy to stand.....
http://i36.photobucket.com/albums/e5...p/100_1231.jpg
this is the bolt-in V8 saddle mount i got from advance adapters.....
http://i36.photobucket.com/albums/e5...00_1260_00.jpg
thats all for today..... not much technical stuff..... i'll definitely make up for it soon!:cheers2:
learfxr 02-09-2008 10:22 PM
Watching to see how ya do. I have a different style mounts for mine. It will be a while before I try to tackle mine.
jeepin1995 02-09-2008 10:38 PM
i'm actually not as nervous as i thought i would be..... we'll see!:cheers:
Tomb Raider 02-09-2008 10:43 PM
Very nice bud. Lemme know if I can help out in any way. At least as much as over the internet as I can.
BlackRhino 02-09-2008 10:45 PM
That's pretty cool. I hope I can afford to do that to my Jeep eventually.
jameskjeep 02-09-2008 10:52 PM
looking good pete let me know if you need any help. Want be able to do much but will help you any way I can.
later man
jeepin1995 02-09-2008 10:55 PM
actually..... selling off my old trans and motor has pretty much paid for the big ticket items..... engine mount, fuel cell, exhaust headers and the shifter..... i think i only have $100 out of pocket (trans)
tomb raider..... i got a feeling you're gonna be my best friend thru this!
learfxr 02-09-2008 11:20 PM
You going to run carb or injected? Is the donor from an injected vehicle? I just had a block handed to me for free, so with no injection parts I'm thinking propane, pretty cheap to build from scratch.
jeepin1995 02-09-2008 11:34 PM
it's actually a 350 out of a emergency generator from the local power co..... it got struck by lightning and fried the generator (also free)..... motor runs good, only 500 hours and runs off of propane..... not really my cup of tea, i'm ditching that for a carb for now.....gotta start off easy.....:thumbsup:
1 ton yj 02-10-2008 10:02 AM
What headers are you using?
Jeepfreak81 02-10-2008 11:07 AM
Same exact swap I did quite a long time ago, good luck!
Don't skimp on the radiator, I bought a standard conversion radiator instead of going aluminum and have hated myself ever since for it.
I know you mention carb, if your buying a new one you can do a junkyard TBI for about the same price and have fuel injection, also worth it. I have a carb, and I love it most of the time though, but I have tinkered with carbs for a lot of years.
If your planning on buying an adapter to your t-case don't... Buy a 231C for $100 instead. You have to switch to a electric speedo (Autometers anyone) and you still come out ahead of the $500 adapter.
Keep an eye on the oil filter, if you don't have enough lift under full compression the driveshaft can make contact (also depends on your motor mounts), same with the exhaust depending on the headers you use. I kept the manifolds and got around this problem, though I have enough lift now, so if I ever need a new exhaust it will get headers.
I am sure you have already researched all that though. The upgrade is well worth it.
tank29 02-10-2008 12:54 PM
What are the advantages or diadvantages of the AA motor mount cradle set-up over their weld-in motor mounts? I know the cradle set-up is about $80 more but was just wondering if one way is better then the other.
Goo luck with the swap. I hope to start mine this summer.
:cheers:
Todd
Jeepfreak81 02-10-2008 12:55 PM
:cheers:
Todd
The bolt in mount forces you to put the motor in a certain spot, the weld in will allow you to place it where ever you want it.
xcannibalx 02-10-2008 02:07 PM
Very cool, I'm in the middle of doing the exact swap, with the same mounts (came with the jeep when i bought it). I'll be watching this thread closely, keep us up to date whats working, and whats not. Keep it up.
1 ton yj 02-10-2008 02:14 PM
OK my experience with the drop-in cradle is that it places the motor very low in the frame. I also had problems melting motor mounts because that cradle put them very close to my blockhugger headers. I eventually wound up going to the weld-on style mounts to aleviate the motor mount issue and also to raise the motor to provide more clearance for my steering ram.
If you are using rear dump shorty headers/manifolds or you have long tube headers, and also have the clearance below the motor, the drop-in style mount will work fine. Personally, I prefer the weld-in style because it gives you more options in final position of the motor.
The time now is 11:42 AM.
