My 2.5 surges then stalls - JeepForum.com
post #1 of 7 Old 11-12-2011, 08:15 AM Thread Starter
grivera
I bought this Rio Grande 5spd which hadn't run in about 2 years. It would crank but not start or sputter. I replaced the crank sensor and it fired up. The idle is usually a little rough but consistent (about 800 rpm), but sometimes if I rev it up just a bit, it will surge higher to about 1800 and stall. I drove it a bit and when I came to a stop, the rpm's surged to 2k and stayed a while before coming down. This is an intermittent issue.
The only code present is 12 (disconnected battery) and 33 (N/A because no A/C). The fuel supply line is leaking where it connects to the metal line near the fuel tank- I'm not sure if how that relates to the surging/stalling issue. I plan on replacing the line today. It still has the old fuel, so I don't know if that could cause the problem. I'm at a loss here, any help would be greatly appreciated.
grivera is offline
post #2 of 7 Old 11-12-2011, 09:19 AM
johnny27030
Replace the line and the fuel, and let us know if you still have the issue. Both could cause strange issues like this.
johnny27030 is offline
post #3 of 7 Old 11-12-2011, 04:04 PM Thread Starter
grivera
Had to pull the tank to get to the line, poor design with rubber all the way to the pump. It's gonna be a bear getting the rubber line through the rubbr block that sits between the frame and body
grivera is offline
post #4 of 7 Old 11-13-2011, 02:33 PM Thread Starter
grivera
Finished doing so today and added fresh fuel- no difference. I removed the TB and will clean it along with the IAC. Hope to have it reassembled by Wed.
grivera is offline
post #5 of 7 Old 11-21-2011, 10:54 PM
reynolds6506
My yj was doing something similar to what urs is doing. It ended up being the o2 sensor
reynolds6506 is offline
post #6 of 7 Old 11-24-2011, 04:58 PM
johnny27030
Are you still having this issue?
post #7 of 7 Old 11-25-2011, 10:10 AM Thread Starter
grivera
I have wose issues now. After replacing fuel lines and cleaning TB, I used Seafoam. Now, it will start and idle for a short while (sometimes the idle speed varies), then die. I have a separate thread going titled: "won't start after seafoam"
grivera is offline
Jeep surges under load Farmkid TJ Wrangler Technical Forum 11 08-22-2011 05:36 PM
90 YJ w/carb surges at idle and stalls out? help.. welker YJ Wrangler Technical Forum 7 12-19-2008 02:36 PM
4.0 w/auto. surges and stalls???? besmith TJ Wrangler Technical Forum 7 09-26-2008 10:03 AM
Surges Douglas S. YJ Wrangler Technical Forum 1 08-05-2007 12:35 AM
Hopping surges bryris YJ Wrangler Technical Forum 4 11-10-2006 08:36 AM
