My 1st Jeep and Build 1993YJ - Page 51 - JeepForum.com
post #751 of 1648 Old 02-01-2011, 08:51 PM Thread Starter
1993BlackYJ
New and old shaft. The shorter one is the new one
1947 CJ-2A
1953 CJ-3B "Ray"
1957 CJ-3b "Jeep with no Name" Parts Donor
1971 CJ5 "Dorothy" 225 Dauntless V6
1993 Black YJ 4.0L, 5 speed, Posi-Loc, 35x12.50 MTZ, 4" Skyjacker lift, Ramsey 8500 Winch, OBA, Front Aussie Locked, 8.8 ARB Rear, 4.10s
My 93 Build Thread Over 700pics :
My 71 "Dorothy" Build Thread Lots of pics :
My 53 CJ-3B "Ray" Build:
Jesus Christ is my Lord and Savior
1993BlackYJ is offline
post #752 of 1648 Old 02-01-2011, 08:58 PM Thread Starter
1993BlackYJ
Heres the 2nd of my patented ideas for the night. I had to remove the needle bearings as the new shaft doesn't take them. So I made me a press out of a 8.8 rotor, (2) 4x4s , (1) piece of oak 2x6, socket, and a C-clamp. Worked great.
1947 CJ-2A
1953 CJ-3B "Ray"
post #753 of 1648 Old 02-01-2011, 09:01 PM Thread Starter
1993BlackYJ
Heres where I quit for the night. I spent an hour trying to get the silly clip on that holds the gears on the shaft. I got tired of fooling with it so i'm going to the 4x4 shop where I bought the SYE for help or advice.
1947 CJ-2A
1953 CJ-3B "Ray"
post #754 of 1648 Old 02-02-2011, 08:43 PM Thread Starter
1993BlackYJ
Before I could finish the SYE I needed to change the seal on the Front output.
1947 CJ-2A
1953 CJ-3B "Ray"
post #755 of 1648 Old 02-02-2011, 08:48 PM Thread Starter
1993BlackYJ
Front seal installed, installed the main shaft and the oil pick-up tube in the rear housing. It was very tricky getting the tube pushed up into the pump.
1947 CJ-2A
1953 CJ-3B "Ray"
post #756 of 1648 Old 02-02-2011, 08:51 PM Thread Starter
1993BlackYJ
The speedo gear has two keepers. One in front and one behind
1947 CJ-2A
1953 CJ-3B "Ray"
post #757 of 1648 Old 02-02-2011, 08:55 PM Thread Starter
1993BlackYJ
Rear housing installed, rear and front yoke installed, speedo installed. tomorrow night I will torque the yokes and fill it up with fluid.
1947 CJ-2A
1953 CJ-3B "Ray"
post #758 of 1648 Old 02-02-2011, 08:58 PM Thread Starter
1993BlackYJ
Last item of the night was to remove the shims on the springs. Hopefully 5Head is coming by after work tomorrow to help me set the 8.8 up on the springs.
1947 CJ-2A
1953 CJ-3B "Ray"
post #759 of 1648 Old 02-02-2011, 09:17 PM
gsharum
I just finished my SYE and installing the transfer case. Before putting on the front drive shaft, I started up the Jeep and ran it in 2H, 4H, N and 4L and nothing flew apart so I guess I did it right. I submitted my measurement for my Tom Woods drive shaft and I hope to get it next week.
gsharum is offline
post #760 of 1648 Old 02-02-2011, 09:22 PM Thread Starter
1993BlackYJ
I think I am going to price having one built at Larry's Drive Shaft on 29th street in the Fort. What does the TW cost?
1947 CJ-2A
1953 CJ-3B "Ray"
post #761 of 1648 Old 02-02-2011, 09:28 PM
Krochus
Bring one of your kids and have em play with Larrys shop cat while you negotiate.
I got mine done so cheap I almost felt bad.
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #762 of 1648 Old 02-02-2011, 09:30 PM Thread Starter
1993BlackYJ
Thats an idea. Is he open on Saturdays?
1947 CJ-2A
1953 CJ-3B "Ray"
post #763 of 1648 Old 02-02-2011, 09:31 PM
gsharum
$199 for the SYE and 295 for the drive shaft. I was told by someone who has worked with Larry's in the past it would probably run 200-250 for them to build a CV drive shaft. So, you should get off cheaper using them.
gsharum is offline
post #764 of 1648 Old 02-02-2011, 09:36 PM
Krochus
Are you gonna have them build one from scratch or are you going to have an XJ front driveshaft shortened?
Krochus is offline
post #765 of 1648 Old 02-02-2011, 09:45 PM Thread Starter
1993BlackYJ
Not sure. Are there any advantages to the XJ other than maybe cost? What price would I have to buy the XJ shaft at to come out ahead with paying for the modifications?
1947 CJ-2A
1953 CJ-3B "Ray"
1993YJ 5speed 1993BlackYJ YJ Wrangler Technical Forum 8 12-28-2009 10:13 PM
My kid wants to build a jeep, I need help. Knottymaid YJ Wrangler Technical Forum 28 03-08-2009 07:23 AM
Totaled Jeep #1, Now its time to build up Jeep #2... Stik TJ Wrangler Technical Forum 17 01-30-2008 12:35 PM
Jeep re-build '99xjlimited TJ Wrangler Technical Forum 0 11-21-2007 03:40 PM
My jeep build pics THANKS TO JEEP FORUM need4spd YJ Wrangler Technical Forum 10 10-21-2006 11:07 AM
