My 1st Jeep and Build 1993YJ - Page 4 - JeepForum.com
post #46 of 1648 Old 01-03-2010, 12:52 PM Thread Starter
1993BlackYJ
Originally Posted by ROADDOG516 View Post
That new cowl seal does look too thin, I got one from Quadratech and had the opposite problem as it was real thick and it DID match the original in size. After a few months it forms darn good and absolutely no leaks. So maybe try quadratech because the replacement you have does look off.
Do you remember what it cost? This one was $30 to $40. I don't like it.
1947 CJ-2A
1953 CJ-3B "Ray"
1957 CJ-3b "Jeep with no Name" Parts Donor
1971 CJ5 "Dorothy" 225 Dauntless V6
1993 Black YJ 4.0L, 5 speed, Posi-Loc, 35x12.50 MTZ, 4" Skyjacker lift, Ramsey 8500 Winch, OBA, Front Aussie Locked, 8.8 ARB Rear, 4.10s
My 93 Build Thread Over 700pics :
My 71 "Dorothy" Build Thread Lots of pics :
My 53 CJ-3B "Ray" Build:
Jesus Christ is my Lord and Savior
1993BlackYJ is offline
post #47 of 1648 Old 01-03-2010, 02:05 PM
Lambo3244
I got my factory cowl seal from Dont Fear the Jeeper. I think it was around $100 but well worth the money. I replaced my cowl seal first with a Rugged Ridge for $30 but it simply was not thick enough. Dont Fear the Jeeper has some great stuff on there that are not full dealer price, even tho they are factory parts!
Lambo3244 is offline
post #48 of 1648 Old 01-03-2010, 03:06 PM
ROADDOG516
I think it cost $25.00 from Quadratech, part #12501.11. It goes all the way outside the hinges and intial fit is real tight, works great double check the part #, good luck.
YJ=THE LAST REAL JEEP!
1966 Willys
1993 YJ
2013 JKU Sahara
ROADDOG516 is offline
post #49 of 1648 Old 01-03-2010, 05:35 PM Thread Starter
1993BlackYJ
Originally Posted by jojojeep1 View Post
buddy if you want to sell your old shackles let me know at joeylep@optonline.net thank you
My neighbor took them for his Trailer build. sorry
1947 CJ-2A
1953 CJ-3B "Ray"
post #50 of 1648 Old 01-04-2010, 01:20 PM Thread Starter
1993BlackYJ
I just got my Flywheel back today $25 to have it turned. I also need a .0025 Shim to go between Flywheel and Block. I'm glad Sam at the machine shop metioned this because I wouldn't have known to do it. Makes perfect sense though.
1947 CJ-2A
1953 CJ-3B "Ray"
post #51 of 1648 Old 01-05-2010, 01:18 PM Thread Starter
1993BlackYJ
I called around to find this 25thousand shim to put behind the Flywheel and no parts store has them so I called the Jeep dealer. The man in parts told me I don't need to worry about it. Is this right? I'm an electrician not a mechanic. I can't see what difference it would make personaly, but know I have two different people saying to different things. Anyone have any input?
1947 CJ-2A
1953 CJ-3B "Ray"
post #52 of 1648 Old 01-05-2010, 05:32 PM Thread Starter
1993BlackYJ
Clutch came in today. It has a spline grease packet in the box. Is this for the Pilot bearing? The alinement tool? Do I just pack the Pilot bearing with regular grease like any other bearing? Instructions are vague.
1947 CJ-2A
1953 CJ-3B "Ray"
post #53 of 1648 Old 01-05-2010, 07:35 PM Thread Starter
1993BlackYJ
Thanks, Ill be following your build I love the black 93's. You seem pretty handy you should fab a rear bumper with swingout, I just finished mine, had it powder coated and I mounted it yesterday, gotta say it looks pretty cool, hated those bumperettes....
Thats is the next thing. I want to be able to carry a 33 spare with out screwing up my tail gate. How did you do the locking mechanism?
1947 CJ-2A
1953 CJ-3B "Ray"
post #54 of 1648 Old 01-05-2010, 07:46 PM Thread Starter
1993BlackYJ
Originally Posted by HilltopperYJ View Post
and btw were did you get the new cowl seal ?
I got it locally from a 4X4 Shop. He had it in stock. I not real pleased with it. I will probably put the old one back on till I find a different one.
1947 CJ-2A
1953 CJ-3B "Ray"
post #55 of 1648 Old 01-05-2010, 08:11 PM
msprooch
Nice Jeep tag.
msprooch is offline
post #56 of 1648 Old 01-05-2010, 09:17 PM
black954
1978 CJ7
man, your build is going great and right along the lines of what I think a perfect YJ is. The spline grease is to be lightly applied to the splines on the input shaft of the transmission. The pilot bearing uses regular axle bearing grease, but don't pack a ton of it in there as it will fling out and get on the clutch. Also, MAKE SURE YOU PUT THE CLUTCH PLATE ON IN THE CORRECT DIRECTION, the rubber cushions face the transmission, not the engine. Just a reminder since ALOT of people put it in backwards.
black954 is offline
post #57 of 1648 Old 01-06-2010, 02:18 AM
Fhajad
There's a lot of different ways to tackle it. Some just use a pin into a hole, like a door. Others use a latch. Really, just look at some that you can buy commercially and find a locking mechanism that works for you, then copy that sucker!
Fhajad is offline
post #58 of 1648 Old 01-06-2010, 02:36 AM
bob1726
For my Glock 26 I prefer the appendix carry, not small of the back as in the photo of you on your garage floor. Rolling over might be uncomfortable.
bob1726 is offline
post #59 of 1648 Old 01-06-2010, 05:46 AM
HUNTER_DENTON07
nice build
DRIVE IT LIKE YOU STOLE IT
HUNTER_DENTON07 is offline
post #60 of 1648 Old 01-06-2010, 06:21 AM Thread Starter
1993BlackYJ
Thanks, I'm have always wanted a YJ and this is the 1st time I have been able to get one and not own on it. I saved my money and did alot of side work this past summer to get it done. Looked for 3 months at every Jeep that was for sale, saw this one and knew it was the one. This tranny was something I knew would come up I was just hoping later on down the line. On the grease input. Thats what I figured but I've learned its better to ask than do it wrong.
1947 CJ-2A
1953 CJ-3B "Ray"
1993YJ 5speed 1993BlackYJ YJ Wrangler Technical Forum 8 12-28-2009 10:13 PM
My kid wants to build a jeep, I need help. Knottymaid YJ Wrangler Technical Forum 28 03-08-2009 07:23 AM
Totaled Jeep #1, Now its time to build up Jeep #2... Stik TJ Wrangler Technical Forum 17 01-30-2008 12:35 PM
Jeep re-build '99xjlimited TJ Wrangler Technical Forum 0 11-21-2007 03:40 PM
My jeep build pics THANKS TO JEEP FORUM need4spd YJ Wrangler Technical Forum 10 10-21-2006 11:07 AM
