My 1995 Red 2.5L YJ Rebuild - JeepForum.com
post #1 of 13 Old 03-23-2012, 04:31 PM Thread Starter
JimmyFW1
OK Guys & Dolls, here's my attempt at a rebuild thread...
I am not doing a frame-off restoration, like some people.
I am not doing my work in a fully stocked shop, like some people.
I am not doing a unlimited budget rebuild/upgrade, like some people either.
But what I AM doing is a rebuild to get my beloved YJ back on the road & safely as my daily driver. I bought it in 2000 from one of those Buy Here/Pay Here places in Jacksonville, FL that had it up on their show rack & I saw it coming home from the beach one day. The PO was a NJ resident that towed it from NJ to FL & back every year behind their RV. Bought it on the spot. Factory air, 50k miles on the dash & clean as it could be...
I did very little to it other than drive it until I moved to SC. The interstate driving from FL to SC for our relocation killed the little 2.5L. It has sat for a few years until I could muster up the courage to attempt the rebuild.
The pic below is from the last time it was drivable.
MORE TO COME
'95 Red YJ, 4-Banger... Nothing special yet, but stay tuned: More to come...
'04 Black KJ Limited, 3.7L, 17" Factory Chrome, pretty much bone stock, bought to be a family carrier, and has become a problematic BEE-YOTCH as of late...
JimmyFW1 is offline
post #2 of 13 Old 03-23-2012, 04:40 PM Thread Starter
JimmyFW1
Here's the 32*11.50*15's that are going back on it.
They have sat for a year & I was scared they were flat on one side.
I pumped them back up to 35psi & they rounded right back out.
Will drive them for a week or so to see if they are in need of replacement...
JimmyFW1 is offline
post #3 of 13 Old 03-23-2012, 04:42 PM Thread Starter
JimmyFW1
And here's most of the stuff that's going into it & what's being replaced...
JimmyFW1 is offline
post #4 of 13 Old 03-23-2012, 04:47 PM Thread Starter
JimmyFW1
I love my wifey ! ! !
And this is the reason that I'm attempting all this.
My wife bought me a new air compressor & a new set of air tools for an early birthday present.
AND my Brother-In-Law is coming down from TN next week for us to tackle the engine work. (He's a lifetime mechanic)
20120320100208.jpg   470409_3516737518923_1286521153_33477964_1090810582_o.jpg
JimmyFW1 is offline
post #5 of 13 Old 03-23-2012, 04:56 PM Thread Starter
JimmyFW1
These I'm most embarrassed of. I've let it sit under an oak tree & used it as a storage unit for parts for more than a year...
JimmyFW1 is offline
post #6 of 13 Old 03-23-2012, 05:10 PM
Spazze
Looks nice. Good luck w/ the work.
Spazze is offline
post #7 of 13 Old 03-23-2012, 05:17 PM Thread Starter
JimmyFW1
Here's the start to finish on the rear brakes.
Yes, those were cob webs embedding to the drums.
I took a wire brush & an air gun to everything to clean it up.
Rinsed it all down with non-chlorinated brake cleaner & coated everything with Rustoleum Rust Converter.
New shoes (replaced for FREE under lifetime warranty) & put it all back together...
20120320095958.jpg   20120320115712.jpg   20120320122837.jpg   20120320121445.jpg   20120320142624.jpg
JimmyFW1 is offline
post #8 of 13 Old 03-23-2012, 05:31 PM Thread Starter
JimmyFW1
Front Brakes
Didn't get a chance to take a pic of the condition of the front rotors & calipers. I was too much in SHOCK.
There was a bird's nest inside one rotor & there was a dead mouse stuck inside the other caliper.
But here's the before & after atleast...
I took the rotors to have them turned. Just had very light surface rust.
New pads courtesy of another lifetime warranty replacement.
Again, wire brushed & air gun'd the debris away & a light coating of Rust Converter...
JimmyFW1 is offline
post #9 of 13 Old 03-23-2012, 05:37 PM Thread Starter
JimmyFW1
Shocks
This is an easy one, but I took the pics...
so you shall see it...
And yes, that is a Chrysler emblem (A.K.A. OEM shocks). Yeah, they were shot. 17 years old & 130K miles... DONE
And before I get flamed for my shock choice, they are the Pro-Series Gabriel's. I chose them based on the price & the warranty. I paid $30 each for them & am getting a $20 rebate per shock...
JimmyFW1 is offline
post #10 of 13 Old 03-23-2012, 06:14 PM Thread Starter
JimmyFW1
Rear Brake Light Relocation
OK, so this isn't a primary part of my rebuild, but it's SO freakin' easy & cheap, WHY would ANYONE buy a kit to do this...
$9.63 in hardware from ACE Hardware & no my Rear Brake Light is 1.25" higher to clear my spare tire...
And I don't have to look at those Torx bolts anymore.
20/20 Hindsight, I should've gotten 4 more washers to have between the bolt head & brake light bracket...
20120323184615.jpg   20120323184624.jpg   20120323184738.jpg   20120323184855.jpg   20120323185854.jpg
JimmyFW1 is offline
post #11 of 13 Old 04-01-2012, 01:43 PM Thread Starter
JimmyFW1
And in the More to Come category...
OK, I just discovered that I suck at doing a build thread while I'm working with someone else. I did not manage to take a SINGLE pic while were were dismantling the donor engine or while installing ANY parts into my Jeep. I was too focused on the tasks at hand...
But I can tell you this, the process went SUPER smoothly. We had the donor broken down & the majority of the parts back in my Jeep within a day.
I've got new shocks, new brakes, a professionally rebuilt head, a properly wired & mounted electric fan now (& no Clutch Fan), & we even fixed a few leaks along the way.
I still need to drain & flush the old oils. drain & flush the cooling system, finish changing out the differential fluids, and check into the 5th gear repair (I still barely have a 5th, but it won't be long by the sound of it), check & replace all the steering hardware as needed (tie rods look bad) & fix the A/C (I have a replacement compressor & clutch in the box waiting, but my blower assembly went out awhile back)...
Will take a few pics this afternoon of what we actually did, and try to document any more work as I get it done...
JimmyFW1 is offline
post #12 of 13 Old 04-01-2012, 02:03 PM
crackedcornish
of course you know you shouldn't use compressed air to clean old brake parts, because of the possible danger of putting asbestos dust into the air that you're breathing...you did know that, right?
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #13 of 13 Old 04-07-2012, 11:03 AM Thread Starter
JimmyFW1
Good Thing I had ceramic pads on there then... I ordered them years ago when I was a PSM @ Auto Zone, since I got them at 20% off for being a manager...
But I do appreciate you bring up that point. People need to be careful. I wasn't, and I"m not always.
But like I said, Thank You. Hopefully someone else will read this & think about taking the precaution...
JimmyFW1 is offline
1995 , rebuild , red , YJ
1995 yj jonclark YJ Wrangler Technical Forum 7 08-03-2011 02:58 PM
1995 yj jayboe YJ Wrangler Technical Forum 10 01-27-2011 02:37 PM
yo rebuild or not to rebuild that is thi question njdpb22 YJ Wrangler Technical Forum 22 12-01-2010 08:07 PM
Jeep Engine to Rebuild or Not to Rebuild booyia TJ Wrangler Technical Forum 31 10-02-2009 01:16 PM
My New 1995 YJ HanksRide YJ Wrangler Technical Forum 29 12-26-2008 07:36 PM
