My 1988 YJ Project BIGHEEP - Page 4 - JeepForum.com
post #46 of 51 Old 11-18-2011, 06:12 PM
superj
damn, that is sweet. your jeep came out as nice as anything a person could want and it looks like you get to actually use it for what its built to do
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #47 of 51 Old 12-12-2011, 05:44 PM
PA_YJ19
Hey man, what type of welder did u use for the body work...my friend it doing my frame work since he is a fabricator but I'm looking to get one for just small sheet metal and body work as I only have a big ac/dc stick right now. Just wondering what others r using on their rigs.
PA_YJ19 is offline
post #48 of 51 Old 12-13-2011, 05:51 PM Thread Starter
BIGHEEP
I used my 115V 130A mig welder with solid core wire and argon/co2 gas. I just kept it at a low setting. Running thinner wire can help too.
1981 Scrambler, Vortec 350,4L60e,D300, Currie 9" F&R
19xx YJ/CJ/TJ/XJ/Waggy thing 4.0L H.O., AW4,
NP231 w/HD SYE,D44 locked/D44 w/LSD,4.09 gears
Build thread
North East Willy Jeep Organization
BIGHEEP is offline
post #49 of 51 Old 12-13-2011, 07:55 PM
BIGJoe29
i was wondering if u think it is possible to do the flat fendering to stock flares
2.5L w/ AX-5, NP231J w/ Rugged Ridge SYE and XJ front driveshaft, open D30 and D35 w/ 4.10 ratio, stock JK 18in wheels w/ Spydertrax 1.25in spacers and 32in toyo at, 2.5in RC lift with .5in shackles(BESRK), rear TJ flares. 8.8 rebuild soon
BIGJoe29 is offline
post #50 of 51 Old 12-14-2011, 08:52 AM Thread Starter
BIGHEEP
It could be done I guess but you would have an empty gap where the factory side marker goes. Also TJ flares are taller and longer. If you raised up the stock flare to meet the top of the fender it would leave a gap on the bottom not to mention you would not be gaining more tire clearance towards the rear.
Build thread
BIGHEEP is offline
post #51 of 51 Old 12-14-2011, 05:30 PM
BIGJoe29
i'll probably do wat you did.thanks for the help though
BIGJoe29 is offline
Trying to pick a color for my 1988 CJ/YJ Golden Eagle project. Piet Wrangler General Discussion 16 07-05-2009 08:13 PM
1988 YJ stalling out arclight YJ Wrangler Technical Forum 12 04-27-2009 02:09 PM
Project Green Monkey...a.k.a. Project Empty Pockets - '97 TJ Sport build thread Poobah TJ Wrangler Technical Forum 20 12-14-2008 08:30 PM
looking at 1988 yj - what to look for? jfalken YJ Wrangler Technical Forum 5 09-05-2007 10:25 AM
