My 1987 Jeep YJ with pics
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
| View Poll Results: So you like what I'm, doing | |||
| Yes |
195 | 77.38% |
| No |
19 | 7.54% |
| Kinda |
38 | 15.08% |
| Voters: 252. You may not vote on this poll | |||
#1 | |
I decided to start a thread on my 87’ YJ build as I have done quite a few things to it since I got it In April of 2008 til now and I have quite a bit planed for it.
I hope you all find this interesting and I look forward to both positive and negative feedback as I go down this long expensive road in restoring the beast that it is. I paid $3,000.00 for this jeep with it having no rust, a straight body and 133k miles on it. The 33” tires on it were worn and it had only a 3” shackle lift, 2” body lift for the suspension and upgraded ProComp wheels. Here’s a picture that I took just after I took delivery of it. This was taken after I removed the full soft top as the entire thing was fogged and cracked. I did replace it with a strapless bikini top and replaced the tires with ProComp Mud terrain tires for this pic. Try and see if yuou can notice the FORD mini van seats that it had… ![]() Shortly after having it for about a month and a half and not really doing much to it I had the large 3” shackles snap the frame hanger bracket. So, I have to remove it and replace it with a new mopar stock hanger. Ahhh, the joys of a shackle lift. ![]() After the whole shacke ordeal, I decided to take some measures and at least make the interior somewhat comfortable and decent. So, I removed the Ford Minivan seas and installed new Bestop recliner seats that I got from jcwhitney. At the same time I ordered a center consol. It’s just a cheap “ultimate center consol” that will suffice for now. While the seats were all out I decided to Hurculine the entire inside of the Jeep. I also had to replace the driver and passenger seatbelts as the previous owner mutilated them some how. Not sure but, they were killed! ![]() Did you notice the lame broken steering wheel… Yeah, so it was upgraded to a nice new steering wheel.. ![]() With the whole shackle thing that happened I was scared that I was going to snap the other side or worse kill my jeep. A lessonto all and one learned that shackle lifts are dangerous and not worth installing at all… so, I was forced to install a new suspension lift faster than I anticipated. I decided to go with a ProComp 4” suspension lift with the standard ES 9000 shocks. of course, I had to replace the shackles, I went with stock M.O.R.E. greasable shackles. Installing this kit was an experience for me as this was the first time that I’ve done this. I am extremely mechanically inclined and had no real problems. Thanks to all you on here it made things a lot easier after reading up on everything that’s been posted on suspension installs here in the forums. I bought oversized and tall jack stands, a large oversized floor jack, a good torque wrench and stock in PB; lol. I used PB on pretty much every part of the undercarriage a good 2 days before hand to make the removal easier. The install went smooth other than the SNAFU of ProComp not labeling the springs correctly which made me swap the leafs. I did install the tracbars but not the swaybar. The trackbars may be coming off sooner than later... ![]() Now that I have the lift installed, I decided to work on a few cosmetic things. The large gaudy tubular bomber and rocker guards have to go. Mainly because the rocker guards stick out like a sore thumb because of the body lift and just look out of place. The front bumper is just huge and ugly! Besides we all know that this tubular stuff is not worth the aluminum that it’s bent with. So off they came… ![]() Then of course off the front bumper. ![]() Next I think that I’m going to remove and replace the stock steering stabilizer with a new one. Probably wither rancho or ProComp, not too sure yet. I’ve finally decided on the paint job that I want. So, I’m now researching body and paint shops around the local area and comparing prices and quality. I’ve decided to go with the 2007 Corvette orange with extra metallic. Here’s the color that I want to paint thanks to a fellow member cjinpa for helping out in the decision, I like the way this CJ looks… Not too sure how my grey interior will look with the orange. But, I think it’ll loo good and give it it’s own personality. ![]() After the paint job I plan on replacing the rocker guards with something nice and tight to the body… Any suggestions..? Then of course getting some front and rear bumpers. I desperately need to get the spare off the tailgate! That’s it for now, and I’, sure there’s more to come later
#2 |
Nice jeep and paint job.
I have to say that I like the Camo paint job better since my last vehicle I painted army green. You did choose a good color. How about some under the hood pictures? Keep up the good work.... |
#3 |
looks like it is coming along a little better than mine. But I plan on changing that this month looks good except I might look for a little less burnt orange than that corvette one. I think a brighter color would look better with the gray interior. Just suggesting, and good luck in whatever you decide.
1987 Wrangler YJ RED 4.2 5-speed, NP231, BFG 31x10.5R15 AT/KO on 15x8 gambler wheels. Caution!!! Under construction!!!!!! Caution!!! Finishing a 4.0 Cyl.head swap, Just got an AX-15 NP231J combo to replace the busted t-case and craptacular BA10/5. Adding Nutter bypass. Probably more to come before it is back as a DD! |
#4 |
Kinda
Love the roll bar, paints just okay, and the auto sucks.
Everything else is good.
"It's just about going fast...that's all..." |
#5 | |
You're definitely right. I think that I'm going to brighten up the color a bit and then add in extra metallic. Still up in the air on that one. |
#6 |
#7 |
Actually I like the camo paint job. It's really catchy.
#8 |
It's nice but the previous owner who did it did a really bad job. It's statring to crack at seams and angles. Then on the hood there's some specks of brown rust starting....
The only problem is everyonw thinks I'm a Marine right off the bat.!.! |
#9 |
Easy way to fix that...go join the marines!
Nah, but you are definitely making great progress. I really like what you've done with it so far. I'm diggin that paint job. I think you should keep the paint job, it looks really rugged. Good work. ![]()
94 YJ - SOA 2.5" OME Springs, 8.8, 4.88's, 35in ProComp MT's on 15x10 ProComp StreetLock Wheels Semper Fidelis War Eagle! |
#10 |
Keep going, i like the camo, but the corvette orange will be a very unique twist, and look good!
1989 Wrangler (Color:White) 1986 Chevy Custom Deluxe (Color:White) 1987 Honda Hurricane (Well color wisee it looks like a hurricane) 1999 Suzuki Gsxr 750 Power Commander (Color:Blue & White Scheme) |
#11 | ||||
![]() I LOVE the camo job... not in favor of the orange at all! Just my opinion. Nice rig overall.
"Si Vis Pacem Para Bellum" Quote:
#12 |
not a fan of my torque flight. bad breather location. and it sounds horrible with any decent exhaust system installed.
#13 |
#14 |
I like the camo look. The corvette orange is a sweet color. I had my mustang painted that color with grey interior. It didn't look to bad.
#15 |
Agreed. Auto sucks. Rest looks really cool! Hate that front bumper though.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
