Multiple Shock Questions... - JeepForum.com
post #1 of 10 Old 01-05-2007, 12:10 PM Thread Starter
atomicmoose
Just call me Moose
atomicmoose's Avatar
So, I have a set of 5" BDS springs that I plan on putting on soon. I am assembling other parts for the lift as we speak. This will be a SUA setup with boomerang shackles front and back most likely.
What is the proper way to measure for shock length? I was planning on staying with the OEM shock towers if at all possible, but this is not set in stone.
I would actually like to move the axle shock mounts to the top of the axle tubes. Any problems with doing this? Pros/Cons? Should I rotate the mount 45 degrees for better performance at full droop? Reducing bind?
I am also looking for shock recommendations. I am not rich, so nothing very costly. I have been looking at Deotsch Techs. They seem nice for the price. Any other budget selections out there I should be looking at?
TIA
atomicmoose is offline
post #2 of 10 Old 01-05-2007, 03:26 PM
fratis
fratis's Avatar
first decide where your mounts will be. try to configure them so you can use the longest shock possible. the problem with moving the lower shock mount to the top of the tube is you are reducing the amount of potential travel. this is particularly the case with the very constrictive mount locations in the rear. the rear shocks almost always are the single limiting factor in terms of flex. shock eye orientation will contribute to bind free flex, however, if you are not going to the time and expense of reworking the upper mounts to use a longer shock then the gains from turning the eye 90* will be pretty moot.
once you have that then put the frame on stands, remove the tires, and droop the axle. i throw a bunch of sandbags on the axle to simulate the weight of the tires. measure and order based on extended length. dont bother with any shock or shock distributer that wont or cant give extended and compressed specs. "for 4" lift" etc. etc. isnt good enough.
rear upper mount mocked up.
lowers
lowers in place.
fratis is offline
post #3 of 10 Old 01-05-2007, 04:29 PM Thread Starter
atomicmoose
Just call me Moose
OK, I hear what you are saying about the upper mount points. Do the shocks come at a more extreme angle with the upper mounting system you pictured? Do you have any other pictures of the upper mount with the shocks installed?
For the record, this will be the first lift I am personally installing and I just want to get things correct the first time around. I don't want to have to deal with shock binding and the like. And I know with 5" of lift, these are things to consider if you want it to be done right.
Did you make those lower shock mounts? They are sharp looking!
post #4 of 10 Old 01-06-2007, 03:02 PM Thread Starter
atomicmoose
Just call me Moose
And also, what about the front?
post #5 of 10 Old 01-06-2007, 03:56 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I have an easier theory/system for determining shock length. I figure the up travel is determined by the fenders and bump stops, and the shocks are usually right near the bump stops, so just measure the bumpstop gap when it's parked (say it's 5"). You need a shock that has just over that amount of compression travel (say 5.5", to prevent bottoming out) when sitting in the driveway. Any more rod showing is wasted capability. Now measure the at rest total shock length. Buy the shock with a compressed length 5.5" shorter than your at rest mount distance (so you have to expand it 5.5" to mount it). If you feel that shock's remaining extension capability is too short to allow sufficient droop, you would need to move the mounts further apart to allow a longer shock. But even that longer shock should still only have that 5.5" extension rod showing at rest. This all assumes normal install, not angled shocks.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #6 of 10 Old 01-06-2007, 05:17 PM
fratis
fratis's Avatar
yes the idea is to mount them on an angle so for every inch the axle moves movement on the shock shaft is less, say 3/4" i have yet to measure this in detail i just know they cover the range of axle movement . the consequence for this is less dampening and a bit more body roll.
yeah i made the mounts. those are 3/4" nuts and gussets.
the front lowers are similar and for the uppers i made tubular hoops that put the shock mount just below the fender. if i were to do it again id use BTF shock towers.
fratis is offline
post #7 of 10 Old 01-06-2007, 08:01 PM Thread Starter
atomicmoose
Just call me Moose
Wanna make me some?
post #8 of 10 Old 01-06-2007, 08:08 PM Thread Starter
atomicmoose
Just call me Moose
OK, this makes sense as well and it a good tip. Thanks, Don!
Do you all feel that angled shocks allow for more downward droop? Is this even going to be a concern? I'm not going to be coil sprung or anything like that. I would assume that 5" springs, not matter who makes them are going to be somewhat stiff and may not allow all that much axle travel. I hope I am wrong about this, but I am prepared to be right.
The axle I am putting in the rear has a LS. (I was not comfortable running a full locker in the 35 for obvious reasons.) The front is a D30 and will have a Detroit locker in it. I am hoping that I can get away with less suspension travel with more traction at all four corners. That being said, if I can get my suspension to move correctly, that is a plus in my book.
Don, are you still running the monoleafs? Do/did they flex well? They have a 6" arch if I remember correctly. Did you get downward movement out of your suspension, or was it stiff? (edit: Just checked your sig and saw that you went SOA. My questions still apply though if you wouldn't mind answering them. Thanks.)
post #9 of 10 Old 01-06-2007, 09:11 PM
JeeperDon
JeeperDon's Avatar
Originally Posted by atomicmoose
Don, Do [monoleafs] flex well?
Not really. I could stuff the wheel wells well enough, but they are pretty much 'factory drooped' as much as they are going to get. They obviously did droop somewhat, but I had one leg in the air a lot. Look at the first pic in my 'gallery' here on JF. You can see that the left front is not too far from the fender at all. That was the monos.
Web Admin for
post #10 of 10 Old 01-09-2007, 09:37 AM Thread Starter
atomicmoose
Just call me Moose
Any other thoughts or suggestions?
Building my 97 TJ: Multiple questions Katoom119 TJ Wrangler Technical Forum 10 02-01-2009 07:25 PM
Multiple questions on equipment CWilson0913 YJ Wrangler Technical Forum 6 08-13-2008 05:55 AM
TJ hood pins??? (multiple questions) Jakemd98 TJ Wrangler Technical Forum 5 01-14-2008 08:16 AM
Multiple rim options for the JK, here...+ some questions.... THANKS mickfluff JK Wrangler Technical Forum 0 10-28-2006 08:07 PM
Multiple Questions hittinbombs YJ Wrangler Technical Forum 9 04-06-2004 03:32 PM
