muffler hangers caught fire - JeepForum.com
post #1 of 6 Old 09-13-2011, 11:56 PM Thread Starter
steveohh22
I have a 1991 4.0 that has been a pain in the butt this last month. im a newb to jeeps so please feel free to correct me.with that said as of now my exhaust pipe runs really hot to where the floor board is hot as hell and at one point the rubber hangers holding the muffler caught fire. I had a clogged cat but changed that and the muffler too. after driving 20 miles at 65 got home and the rubber hangers melted off. I was told my jeep was running rich. here's a list of everything I have did to it this month.
changed:
spark plugs
spark plug wires
IAC valve
exhaust manifold(had a crack)
fuel filter
o2 sensor
my problem is that I'm getting 5 to 10 mpg and i can really feel the heat from under wial driving . the thing that throws me off is that it drives great and has power .
steveohh22 is offline
post #2 of 6 Old 09-14-2011, 07:24 AM
raynmaker
cat converter backed up maybe
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #3 of 6 Old 09-14-2011, 07:30 AM
USAFYJ
Wow, that sounds like a rough problem. Why not replace the whole exhaust with something more free-flowing while you're down there? Shouldn't be too expensive, you have to replace the hangers anyway, and the cherry on top is the sound.
USAFYJ is offline
post #4 of 6 Old 09-14-2011, 09:03 AM
4.7stroker
Running rich will kill your new cat converter fast.
You need to find the source of the over rich condition fast.
Almost any engine sensor can cause it to run rich as can a leak in the exhaust before the O2 sensor.
What fuel pressure do you have?
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #5 of 6 Old 09-14-2011, 12:09 PM Thread Starter
steveohh22
well all this happened a little after I purchased a new cat and muffler so the muffler shop would not replace my clogged cat because it was my fault the jeep was running rich. so since I just got it smoged I took the cat off and welded a straight pipe to the muffler. the jeep runs good but there's no back pressure on the tail pipe. today my buddy's coming over with a fuel pressure tester so ill have that figured out today.
post #6 of 6 Old 09-14-2011, 12:10 PM Thread Starter
steveohh22
oh an it still gets really hot underneath but I try not to drive more then a 20 min drive lol
